Re: how much wider are 275/60 vs 255/60
[Re: 71birdJ68]
#1575878
02/08/14 02:54 PM
02/08/14 02:54 PM
Andrewh
[Re: Andrewh]
#1575879
02/08/14 04:15 PM
02/08/14 04:15 PM
Posts: 1,012 indiana
mcmopars
indiana
[Re: mcmopars]
#1575880
02/08/14 05:00 PM
02/08/14 05:00 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Just be advised that unless you are using the same width rim as the chart you section width will be different. Generally, narrower rims increase the section width and wider rims narrow the section width.
If you are running, for example, a 7" rim with those 275's, a 10" rim may give you your clearance to no longer rub. Of course, it may not and unless you can test fit before you buy you may spend money you needn't have.
[Re: Supercuda]
#1575881
02/08/14 05:19 PM
02/08/14 05:19 PM
Posts: 21,822 Kirkland, Washington
Pacnorthcuda
Supercuda, I think you mean the other way around. A narrow rim will result in a narrower section width.
