68 barracuda with 275-60-15 tires
#1575564
02/07/14 06:58 PM
02/07/14 06:58 PM
Posts: 3,101 cincinnati ohio
mcat4321
cincinnati ohio
stock length and location on everything... what size wheel? what back spacing ? to tuck the tires in tight, so the car can be low. i don't care to roll the fender lip if i have too, or run a spacer for optimum fit. thanks guys
Re: 68 barracuda with 275-60-15 tires
[Re: 6bblgt]
#1575566
02/07/14 09:28 PM
02/07/14 09:28 PM
Posts: 4,943 WI
Dcuda69
WI
Thant's a big tire for an uncut a-body - my brother has a '69 & I'll guess it can't be done! Who'll prove me wrong? Bring the pics.
But I'm open to ideas! I have a '69 with 245/60-15 on 8" Cragers with 4.5" backspace. They clear fine and a 255 would probably fit(tight)but I'm very skeptical on a 275 unless you're gonna jack it up and let them stick out....not my cup of tea though.
[Re: SSAAHemiFan]
#1575571
02/08/14 07:30 PM
02/08/14 07:30 PM
Posts: 17,516 Las Vegas, NV
6bblgt
Las Vegas, NV
I had bias ply 275-60 -15 on my 69 Barracuda - 15x7 steel H wheels - super stock springs in the stock location - no issues
The bias ply were true 275-60-15 most radials are a little narrower - I mentioned the factory H wheels because for the life of me I cannot remember the backspace right now - They were 70 E-body Hemi steel wheels
..... but were those tires in the wheel wells or below them?
[Re: 6bblgt]
#1575572
02/08/14 08:46 PM
02/08/14 08:46 PM
Posts: 1,033 Madison, Wisconsin
chrisnben
Madison, Wisconsin
You'll probally only get a 255/60 in there on a 4" BS on a stock spring. The best for both fitting a 275/60 & actually getting traction- is to put a set of Super Stock springs on #002/#003 for $250 & an offset kit. Then you'll have the best of both. PM me- I've got a brand new set of BFG 275/60/15's for sale. What rim and tire do you run now? I have found, as others have said here, 14" wheels are hard to find in the size/style you need/ prefer/ cost. You can grab 15x7 cop wheels cheap- and you'll be set!
'70 Cuda "Badfish 2"- in the works
Home of MoPar University- We school 'em one at a time!!
[Re: 6bblgt]
#1575573
02/08/14 10:57 PM
02/08/14 10:57 PM
Posts: 2,431 USA
SSAAHemiFan
USA
[ ..... but were those tires in the wheel wells or below them?
They would be considered below them - didn't stick out past the body
[Re: OA5599]
#2910743
04/15/21 11:38 PM
04/15/21 11:38 PM
Posts: 699 Cooperstown, NY
jrlegacy23
Cooperstown, NY
I know this is old but I want someone that is doing their researching that 275/60/15 are an easy fit on a 68 Barracuda:
[color:"#00FF00"]68 Fastback Barracuda with some stuff[/color]
[Re: mcat4321]
#2911795
04/18/21 10:10 PM
04/18/21 10:10 PM
Posts: 3,277 West Coast, USA
jbc426
West Coast, USA
I run that size tire on a 15 inch rim with 5 inches of backspacing, if memory serves. Plenty of room, although I did trim and smooth the fender lip just in case.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: 6bblgt]
#2911845
04/19/21 07:35 AM
04/19/21 07:35 AM
Posts: 3,164 Md.
carnut68
Md.
I have a 68 Fastback with 15x10 w/6.5 offset,27x10.5 Hoosier Quick Time Pros. It's a B body rear and offset hangers.
America First!
