Comp 829 safe open pressure limit?
#1574786
02/06/14 04:03 AM
02/06/14 04:03 AM
Posts: 51 1.5 miles west of Jacksonburg ...
Ohio Joe
Can a Comp 829 roller lifter safely handle 800 lbs open pressure ? This is the first time I have used a roller cam and I want it to be right. I will more than likely go with PAC 1326 springs and 3/8 Smith Brothers pushrods. My question is can the lifters handle it.
66 Dart GT " Rat Racer"
Re: Comp 829 safe open pressure limit?
[Re: Ohio Joe]
#1574787
02/06/14 04:10 AM
02/06/14 04:10 AM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
I am using the 99550-16 cranes...on my 572 hemi. Tim
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
[Re: Ohio Joe]
#1574796
02/07/14 12:51 PM
02/07/14 12:51 PM
Posts: 6,446 NJ-USA
HPMike
NJ-USA
Id use Isky EZ Rolls....bushed lifter bores as well..but thats me... I havent used an 829 in a while, I hope they redesigned how the pushrod seat is retained in the lifter body...The ones I had here used only an o ring to retain the seat...Some actually came out of the lifter just from the oil tension when pulling a pushrod out...on a fully assembled engine... MB
