Race Tec Pistons ? #1574740
02/06/14 01:07 AM
02/06/14 01:07 AM
Tennessee
steeldust Offline OP
Tennessee
Is any one running them ? I the engine shop said they are great they will be a nitrous piston custom made ? I will be spraying 300 to 450 in my 582 thanks for any help.
Re: Race Tec Pistons ? [Re: steeldust] #1574741
02/06/14 02:11 AM
02/06/14 02:11 AM
Northern Indiana
Dunnuck Racing Offline
Northern Indiana
I started using them for my builds and have been pleased with them. Better tolerances than some of the big name pistons I used in the past.
Keith
Re: Race Tec Pistons ? [Re: Dunnuck Racing] #1574742
02/06/14 01:44 PM
02/06/14 01:44 PM
Delray beach, Florida
P
Performance Only Offline
P
Keith
Can you tell me which "big name" pistons you thought they were better than? The ones I've used were machined more like an entry level piston and priced that way as well. I might've had my hopes too high though in regards to things like ring land finish, skirt thickness, Ring belt thickness and a few other things. I guess they're okay and will run, they in no way compare to Diamond or CP.
Keep in mind this was a year or so ago, so maybe things have changed since then.
machine shop owner and engine builder
Re: Race Tec Pistons ? [Re: Performance Only] #1574743
02/06/14 02:01 PM
02/06/14 02:01 PM
Gilbert AZ
tsanchez Offline
tsanchez  Offline
Gilbert AZ
Race tec was started by the former owner of JE pistons.
Re: Race Tec Pistons ? [Re: Performance Only] #1574744
02/06/14 04:07 PM
02/06/14 04:07 PM
Northern Indiana
Northern Indiana
I'm not going to get into a pissing match on the board.
Keith
Re: Race Tec Pistons ? [Re: Dunnuck Racing] #1574745
02/06/14 04:33 PM
02/06/14 04:33 PM
P
P
Keith
There's no pissing match unless someone turns it into that. I'd look at it as more of a discussion. Are you unwilling to have a discussion? I would hope not since you brought up the topic.
I know of several shops that sell the pistons in question and they do so mostly as a lower cost/ higher margin item. I have no problem with that as long as they work for the application.
Re: Race Tec Pistons ? [Re: Performance Only] #1574746
02/06/14 05:10 PM
02/06/14 05:10 PM
oberlin, Ohio
Rapid340 Offline
Rapid340  Offline
oberlin, Ohio
I have used them in my own motors as well as others. In my opinion they produce a high quality piston. The cost is/was lower than average because they were trying to buy market share until they build up the brand. I know the price has gone up as sales increased. They are overall a good value in my opinion.
1971 Factory Appearing Duster 340 11.000 @ 122 mph
Re: Race Tec Pistons ? [Re: tsanchez] #1574747
02/06/14 08:12 PM
02/06/14 08:12 PM
I was told that the Calvert Bros. started CP pistons 5 yrs. after they sold JE to the current owners
Re: Race Tec Pistons ? [Re: Cab_Burge] #1574748
02/06/14 08:30 PM
02/06/14 08:30 PM
NE Oklahoma
V
Von Offline
Von  Offline
V
NE Oklahoma
My shop uses them in alot of different applications. A custom piston is 650 from them, which seems very dang reasonable to me. This shop build numerous late model, outlaw mod, b mod, some 410 sprints, etc motors. They use the racetecs in all classes. They also have a alky hemi puller. That motor has racetecs in it as well. They seem like a nice piston for the $$$.
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72. Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
Re: Race Tec Pistons ? [Re: Performance Only] #1574749
02/06/14 08:49 PM
02/06/14 08:49 PM
Pa
Hot 340 Offline
Hot 340  Offline
Pa
What RA finish are you looking for and what ra are they machined at? And how are you checking it?
Re: Race Tec Pistons ? [Re: Hot 340] #1574750
02/06/14 10:04 PM
02/06/14 10:04 PM
Toronto
mshred Offline
mshred  Offline
Toronto
Have them in my 408. Got them custom made for a shelf price from Rod at BPE. Only 1 season on them, but they were a nice quality piece and I wouldn't hesitate to buy another set if dealing with Rod
Re: Race Tec Pistons ? [Re: mshred] #1574751
02/06/14 11:40 PM
02/06/14 11:40 PM
Tennessee
Tennessee
I am having the pistons custom made THANKS
Re: Race Tec Pistons ? [Re: Hot 340] #1574752
02/07/14 06:25 PM
02/07/14 06:25 PM
Pa
Hot 340 Offline
Hot 340  Offline
Pa
bump
