Indy Crate Hemi??? #1574530
02/05/14 05:56 PM
02/05/14 05:56 PM
Arizona, USA
gsmopar Offline OP
gsmopar  Offline OP
Arizona, USA
While planning out the new bullet, I came to the realization that piecing together a stroker wedge with Victor heads came close to the price of some of the Indy Crate Hemis. To top it off, I noticed in their catalog that they'll deduct $1,000 if you want to assemble the engine yourself.
I'm looking at the 572 Super Street Hemi, upgrade to the 1050 Holley and Indy Roller Rockers. I'm considering the $500 cylinder head upgrade as well.
I'm new to the Hemi World and to Indy. Is this a good deal, any real world experience, does the board have a sponsor that can beat/match this deal?
http://indyheads.com/images/price.2013.5.pdf
Thanks!
Re: Indy Crate Hemi??? [Re: gsmopar] #1574531
02/05/14 06:07 PM
02/05/14 06:07 PM
Northern Indiana
Dunnuck Racing Offline
Northern Indiana
If you are sure you want to go that route, call Indy and ask for Josh King. I'm not a big fan of most crate engines but he is the guy to talk to there and get results.
Keith
Re: Indy Crate Hemi??? [Re: gsmopar] #1574532
02/05/14 06:09 PM
02/05/14 06:09 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Dont deal direct with Indy... call Bob George Racing
(he is a member here) and talk with him about the
engine and build
Re: Indy Crate Hemi??? [Re: MR_P_BODY] #1574533
02/05/14 06:21 PM
02/05/14 06:21 PM
Wind Gap,Pa.
Sammy Offline
Sammy  Offline
Wind Gap,Pa.
PM sasquatch on this board. Todd Marsch is the go to guy with great customer service and he gives you a nice discount as well.
He helped me with my Dart when I needed help. Always answers questions and always calls you back.
Re: Indy Crate Hemi??? [Re: Sammy] #1574534
02/05/14 06:51 PM
02/05/14 06:51 PM
aotearoa
rebel Offline
rebel  Offline
aotearoa
interesting to note that Indy don't use their own block on their NA builds. why is that you think?
Re: Indy Crate Hemi??? [Re: gsmopar] #1574535
02/05/14 07:30 PM
02/05/14 07:30 PM
Mohnton, Pa
DodgeCharger Offline
Mohnton, Pa
Indy Hemi's don't run very well. A friend of mine bought a hemi from them and it dyno'd at over 100 hp less than what it was suppose to make. He never could achieve his performance goals with the Indy hemi heads. Their wedge heads work better than their hemi heads.
I have Stage V hemi heads. I think they are still the best hemi heads available.
Re: Indy Crate Hemi??? [Re: MR_P_BODY] #1574536
02/05/14 07:45 PM
02/05/14 07:45 PM
Taxes & Virus's R-US, NY
Dragula Online content
Dragula  Online Content
engine and build
Do not go thru Indy for a purchase like that. I can tell you from experience...Go thru BG as Mr P explained. Give him your goals and go from there.
I have an Indy Headed Hemi, its only 484 cubes, and the heads need a little to keep up with a set of ported StageV heads, but its all $$$...Mine flow 400cfm ported by me, and a good set of V's flow 420cfm...I am not too upset about that. Another thing to think about is are you ever going to go with T&D/Barton rockers...Some Indy Hemi heads they won't fit like mine, so you have to go with Indy rockers or Stage V....
Other things to consider...Indy Hemi 426-1 heads make the engine 1.5" wider than a standard Hemi..I cannot speak for the Hipo heads, never seen a set. The chamber on the Indy head is smaller, so you need to watch your compression if your going pump gas. Also, the 426-1 heads are heavy. They have cast in rocker stands...
Other things to consider, lighter rotating assemblies that use 2.2 rod journals, and lighter weight .990 pins, and long rods, typically the 7.1" are lighter as well with the 2.2 journals...Standard stroker cranks will add more reciprocating weight, so go lighter if you can. A lot more fun.
I have considered selling mine as I want to move up to a 604 and see what that is like, but for now, I will just keep beating the heck out of this one..
Re: Indy Crate Hemi??? [Re: rebel] #1574537
02/05/14 10:38 PM
02/05/14 10:38 PM
Indy
moparman89 Offline
moparman89  Offline
Indy
Because nobody will pony up the cash to pay for the block, that is why. They get World blocks for pennies on the dollar.
Re: Indy Crate Hemi??? [Re: moparman89] #1574538
02/05/14 10:57 PM
02/05/14 10:57 PM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
Call Bob George and go through him you won't be disappointed. My 605 has a Indy rotating kit and Indy 426SR1 heads. The rotating kit came with a Callies crank with 2.2 rod journels, by all means use the 2.2 size rod journels. 7.1 rods and Diamond pistons. The block will need much less clearancing with the 2.2 rods.Dave
Re: Indy Crate Hemi??? [Re: quickd100] #1574539
02/07/14 02:16 AM
02/07/14 02:16 AM
junction city oregon
V
viperblue72 Offline
viperblue72  Offline
V
I think before you order from Indy, you better do your homework and do some google searches. Many very unhappy customers. Some of the engine builders that use a lot of their parts will get on here and stick up for them, but they are the only ones.
Re: Indy Crate Hemi??? [Re: viperblue72] #1574540
02/07/14 08:29 AM
02/07/14 08:29 AM
Melbourne.....Oz-land
Moparmal Offline
Moparmal  Offline
And that is the salient point - Indy provide a much needed source of diverse performance hardware....however their QA and customer service is " belly up"
I would guess people like BGR understand this and are prepared to "massage" the issues to provide a quality product.
67 RO23 clone with 6.1 SRT Hemi and dual quads. Soon to have Drag Pak induction and Throttle body.
Re: Indy Crate Hemi??? [Re: Moparmal] #1574541
02/07/14 07:18 PM
02/07/14 07:18 PM
Arizona, USA
gsmopar Offline OP
gsmopar  Offline OP
Arizona, USA
Thanks for the replies! I plan to pull the trigger when some stock options mature early next year. I've read the mixed reviews on Indy before, but was hoping that things had changed. Looks like I have a lot of research to do in the next few months.
I'm more in the camp of doing things myself, but the aftermarket support doesn't appear to be at the same level for the Hemi as what is currently available for the wedge (not at all what I expected). Maybe I'm just not hitting the right places. If I were to piece together my own build; are there any choices other than Mopar and Indy? As far as a short block, Muscle Motors is priced cheaper than what I think I can build on my own. Any experience with these guys?
Re: Indy Crate Hemi??? [Re: gsmopar] #1574542
02/07/14 07:48 PM
02/07/14 07:48 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Just offering my opinion......
I know of several friends local to me( near Muscle Motors) who have had shoddy work done and or had work supposedly done that wasn't done.
If it was one person one time, I probably wouldn't say anything. But that isn't the case.
On the other hand, I personally( and know of others) have had top notch work dome by Best Machine, and I would be extremely comfortable giving them a ringing endorsement.
Both the above are Michigan based mainly Mopar shops.
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Indy Crate Hemi??? [Re: B3422W5] #1574543
02/07/14 09:08 PM
02/07/14 09:08 PM
mi
dirty magnum Offline
mi
shop around like a lot of guys have said , stay away from indy.
Re: Indy Crate Hemi??? [Re: dirty magnum] #1574544
02/07/14 11:31 PM
02/07/14 11:31 PM
Salt Lake City
camastomcat Offline
camastomcat  Offline
Salt Lake City
Indy customer service sucks. Another vote for Todd Marsh. The Indy products are as good as who puts them together, Todd is the guy IMO.
Re: Indy Crate Hemi??? [Re: camastomcat] #1574545
02/07/14 11:44 PM
02/07/14 11:44 PM
geezer acres rest home
dakotawilly Offline
dakotawilly  Offline
theres also tom hemphill,hemphill racing engines,quality work....
SFI 25.5 depends,no leak,even at 213 mph....
Re: Indy Crate Hemi??? [Re: Sammy] #1574546
02/08/14 07:52 AM
02/08/14 07:52 AM
A shed in England
Tig Offline
Tig  Offline
A shed in England
Todd's a great guy to deal with
http://mopartsracing.com/index.html
Re: Indy Crate Hemi??? [Re: Tig] #1574547
02/08/14 03:14 PM
02/08/14 03:14 PM
fullmetaljacket Offline
Go with BEST machine in Michigan and don't do things with a Hemi that will cost you more to do it again. In other words, put the correct amount aside to make a Hemi success story not create hemorrhoids.
Re: Indy Crate Hemi??? [Re: fullmetaljacket] #1574548
02/08/14 04:58 PM
02/08/14 04:58 PM
SW Ohio
cgall Offline
cgall  Offline
SW Ohio
That 572 hemi is listed at $16,995.00. Then you have headers and other things to consider. If you are already set up for a wedge, take your money to one of the builders mentioned in these posts and you will have a sturdy wedge with a mega block that will outlive and outperform any hemi of similar size and configuration.
Re: Indy Crate Hemi??? [Re: cgall] #1574549
02/08/14 05:18 PM
02/08/14 05:18 PM
Pa
W
Wv68charger Offline
Wv68charger  Offline
W
Pa
