Hardened Seats. Necessary? #1573676
02/03/14 07:51 PM
02/03/14 07:51 PM
Tucson AZ,
MadMopars Offline OP
Tucson AZ,
Just curious how many of you guys are running hardened seats. Are they necessary in a street/strip application? What are your thoughts?
[img]https://s9.postimg.cc/6fbjxzfvv/48-2016-_Drag-_Weekend-_Best-_Burnouts-lpr.jpg[/img]
73 GTX *440*727*8 3/4*
69 DART GT *440*4 SPEED*DANA*
73 ROAD RUNNER *451*4 SPEED*DANA*
64 F100 *383*4 SPEED*9"*
75 DODGE D300 *440*4 SPEED*DANA*
99 DODGE RAM 3500 4X4 DUALLY... ON 38"s
Re: Hardened Seats. Necessary? [Re: MadMopars] #1573677
02/03/14 08:01 PM
02/03/14 08:01 PM
MR_P_BODY Offline
MR_P_BODY  Offline
What do you run for fuel... unleaded
Re: Hardened Seats. Necessary? [Re: MR_P_BODY] #1573678
02/03/14 08:05 PM
02/03/14 08:05 PM
Tucson AZ,
Tucson AZ,
Unleaded. No additives.
Re: Hardened Seats. Necessary? [Re: MadMopars] #1573679
02/03/14 08:12 PM
02/03/14 08:12 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
It's not a bad idea to have them added if the heads are being redone , adds maybe $200 to the total bill.
Re: Hardened Seats. Necessary? [Re: MadMopars] #1573680
02/03/14 08:12 PM
02/03/14 08:12 PM
Arlington, Tx.
BJS racing Offline
BJS racing  Offline
Arlington, Tx.
Just use chocolate pudding! It will all be good! Unleaded fuel you will want to run hardened seats.
Back in the swing of things at Painless again! Great to be back!
Re: Hardened Seats. Necessary? [Re: MadMopars] #1573681
02/03/14 08:22 PM
02/03/14 08:22 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Lead was a additive that use to lube and it
saved the seats.. if you put a lot of miles on it
then the seats would help a lot
Re: Hardened Seats. Necessary? [Re: MR_P_BODY] #1573682
02/03/14 08:30 PM
02/03/14 08:30 PM
Oklahoma City, OK
Dave64 Offline
Dave64  Offline
Oklahoma City, OK
Run as is and when its time to rebuild add them ten.
Re: Hardened Seats. Necessary? [Re: Dave64] #1573683
02/03/14 10:58 PM
02/03/14 10:58 PM
S.E.Mich
drew72 Offline
drew72  Offline
S.E.Mich
Only necessary on the exhaust seats. And yes, if the heads are being rebuilt, definitely have them installed now and save yourself the grief.
Re: Hardened Seats. Necessary? [Re: drew72] #1573684
02/04/14 12:41 AM
02/04/14 12:41 AM
warren, mich.
dwayne welder Offline
warren, mich.
HELLO Any cylinder heads casted before 1972, will need hardend seats installed for unleaded fuel!!! After that date they were induction hardend from the factory!! Also if you install larger exhaust valve's, you my need to install hardend seats. Because that take's away the area that was induction hardend!! When you have them install and valve job done, your valve job will last a long time, and mile's!!! Good Luck!!
Re: Hardened Seats. Necessary? [Re: dwayne welder] #1573685
02/04/14 01:06 AM
02/04/14 01:06 AM
S.E.Mich
drew72 Offline
drew72  Offline
S.E.Mich
Of course induction hardening is very superficial. Good for 1 maybe 2 valve jobs. The hardened surface was only about .015" deep. After that it's time for new seats.
Re: Hardened Seats. Necessary? [Re: drew72] #1573686
02/04/14 01:56 AM
02/04/14 01:56 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I did not put hardened valve seats in my old mild 440 street/strip eng. Has been together on the road since 2006 and still working fine. But I only put about 5000 miles a year on it. They are 906 heads I did myself as I put the larger 2.14 and 1.81 valves in them. It may have about 25 to 30,000 miles on it and the valve adjustment is still on the money. It is now in my buddies Duster still going strong and its only run on pump gas unleaded. Ron
Re: Hardened Seats. Necessary? [Re: 383man] #1573687
02/04/14 02:23 AM
02/04/14 02:23 AM
Tucson AZ,
Tucson AZ,
Thanks for the input guys.
I have the opportunity to pick up an old Black and Decker valve/seat grinder setup for a smoking deal. It's cheap enough that I considered picking it up and trying to build a set of heads myself. However, if I still need to have the hardened seats installed then it doesn't do me as much good to have around. Hardened seats aside, does anyone or has anyone ever used one of these old Black and Decker setups? Is the stone wheel method still around or is it outdated? Think its worth saving or let it go?
