Re: Camber-tire wear-street setting?
[Re: brads70]
#1572796
02/02/14 12:51 PM
02/02/14 12:51 PM
Posts: 27,471 So Cal
autoxcuda
So Cal
I've got 245/50/15's. I'm pulling 1.0 degrees camber. I have about 5,000 miles on this setup. Seems like decent wear pattern. Have about 5 road course track days and one autocross on it. *correction my camber has been 1.0 degrees
[Re: jcc]
#1572798
02/02/14 07:09 PM
02/02/14 07:09 PM
Posts: 780 Woodinville, WA
Viol8r
Woodinville, WA
Since with our typical car set-ups, IMO you can't have enough camber, like 2-3, however from my experience, anything over .5- will not get past 20K on the street.
We run .25 on the street and, 2.2 for track.
[Re: brads70]
#1572800
02/02/14 08:09 PM
02/02/14 08:09 PM
autoxcuda
So Cal
Thanks for the replies everyone! I currently have .75 on mine( Firestone street tires) and no noticeable wear issues. I think I'll be running Falken 615K's and if I got 20,000 miles from them I'd be more than happy.
Like a noted, I've got away with 1.0 degrees. But that is a 245 (9.6") wide tire with a 4.85" sidewall height/thickness.
A 315/30/18 is 12.4" wide tire with 3.75" of sidewall.
IIRC, you have your own alignment equiptment at home. Then I'd try 1.0 degree then watch/measure tire wear very closely.
[Re: autoxcuda]
#1572801
02/02/14 08:25 PM
02/02/14 08:25 PM
Posts: 813 Ontario,Canada
brads70
Ontario,Canada
Thanks. Yes I just have a caster/camber gauge.
[Re: RylisPro]
#1572804
02/02/14 09:31 PM
02/02/14 09:31 PM
Posts: 104,346 Garden Grove, CA
OzHemi
Penguin-hating Ginger
Garden Grove, CA
I would not worry about camber as much, It's the toe that eats up the tires
[Re: ntstlgl1970]
#1572807
02/02/14 09:41 PM
02/02/14 09:41 PM
autoxcuda
So Cal
I run 1/2 degree negative with a 265/35 18. It's been good so far, I think I could get away with a little more. maybe 3/4 to 1 on the street.
Off topic, but are you comming down to Spring Fling Speed Festival this year at Willow Spring and test out that camber on the track??
[Re: mopardamo]
#1572810
02/03/14 10:18 AM
02/03/14 10:18 AM
brads70
Ontario,Canada
Hello brads70,
So do you have a 315/30/18 under your E body at the front? If so what is your combo?
Damon
No not yet. What I'm toying with is buying a new pair of AMD fenders and modifying them to fit .Storing my original fenders so I could put the car back to stock down the road if I wanted? No way stock fenders would work with that size. Right now the front end is off for welding in the US Cartool cowl braces. I finally have saved up enough for new rims/tires etc.... so just weighing my options?
[Re: brads70]
#1572811
02/04/14 01:26 AM
02/04/14 01:26 AM
autoxcuda
So Cal
Hello brads70,
Damon
So how would those fit in the rear?
[Re: brads70]
#1572812
02/04/14 01:53 AM
02/04/14 01:53 AM
Posts: 1,491 Lethbridge, AB, Canada
dangina
Hello brads70,
Damon
what 18" wheels will you be running?
