Camber-tire wear-street setting? #1572795
02/02/14 10:46 AM
02/02/14 10:46 AM
Ontario,Canada
brads70 Offline OP
brads70  Offline OP
Ontario,Canada
Question, what would you say you can get away with camber wise on the street before you get tire wear? While I understand 2-3 is good on the track but my car will see 90% street cruising and the occasional Sunday afternoons autocrossing. Would a wider tire affect your recommendations? (315/30/18)
I'm guessing keeping it around 1 degree will work?
Re: Camber-tire wear-street setting? [Re: brads70] #1572796
02/02/14 12:51 PM
02/02/14 12:51 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
I've got 245/50/15's. I'm pulling 1.0 degrees camber. I have about 5,000 miles on this setup. Seems like decent wear pattern. Have about 5 road course track days and one autocross on it.
*correction my camber has been 1.0 degrees
Re: Camber-tire wear-street setting? [Re: brads70] #1572797
02/02/14 03:25 PM
02/02/14 03:25 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Since with our typical car set-ups, IMO you can't have enough camber, like 2-3, however from my experience, anything over .5- will not get past 20K on the street.
Re: Camber-tire wear-street setting? [Re: jcc] #1572798
02/02/14 07:09 PM
02/02/14 07:09 PM
Woodinville, WA
Viol8r Offline
Viol8r  Offline
Woodinville, WA
We run .25 on the street and, 2.2 for track.
1968 Pro-Touring Dodge Charger
*2011 Optima Ultimate Street Car Challenge Invitee
http://www.popularhotrodding.com/features/1203phr_1968_dodge_charger/index.html
Re: Camber-tire wear-street setting? [Re: Viol8r] #1572799
02/02/14 07:41 PM
02/02/14 07:41 PM
Ontario,Canada
brads70 Offline OP
brads70  Offline OP
Ontario,Canada
Thanks for the replies everyone!
I currently have .75 on mine( Firestone street tires) and no noticeable wear issues. I think I'll be running Falken 615K's and if I got 20,000 miles from them I'd be more than happy.
Re: Camber-tire wear-street setting? [Re: brads70] #1572800
02/02/14 08:09 PM
02/02/14 08:09 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Like a noted, I've got away with 1.0 degrees. But that is a 245 (9.6") wide tire with a 4.85" sidewall height/thickness.
A 315/30/18 is 12.4" wide tire with 3.75" of sidewall.
IIRC, you have your own alignment equiptment at home. Then I'd try 1.0 degree then watch/measure tire wear very closely.
Re: Camber-tire wear-street setting? [Re: autoxcuda] #1572801
02/02/14 08:25 PM
02/02/14 08:25 PM
Ontario,Canada
brads70 Offline OP
brads70  Offline OP
Ontario,Canada
Thanks. Yes I just have a caster/camber gauge.
Re: Camber-tire wear-street setting? [Re: brads70] #1572802
02/02/14 08:35 PM
02/02/14 08:35 PM
The Netherlands
BigBlockMopar Offline
The Netherlands
I'm running with about 2 deg camber on my daily Dart. Been doing that for a good number of months now since I put on different tires.
There isn't any noticable wear to be seen at the moment, but I don't think that will be very long.
Re: Camber-tire wear-street setting? [Re: brads70] #1572803
02/02/14 09:04 PM
02/02/14 09:04 PM
NorCal
RylisPro Offline
RylisPro  Offline
NorCal
I would not worry about camber as much,
It's the toe that eats up the tires
73 `Cuda
Instagram: @rylispro
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: Camber-tire wear-street setting? [Re: RylisPro] #1572804
02/02/14 09:31 PM
02/02/14 09:31 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
Re: Camber-tire wear-street setting? [Re: brads70] #1572805
02/02/14 09:36 PM
02/02/14 09:36 PM
Sac, CA, USA
N
ntstlgl1970 Offline
ntstlgl1970  Offline
N
Sac, CA, USA
I run 1/2 degree negative with a 265/35 18. It's been good so far, I think I could get away with a little more. maybe 3/4 to 1 on the street.
Re: Camber-tire wear-street setting? [Re: OzHemi] #1572806
02/02/14 09:41 PM
02/02/14 09:41 PM
On The Boat, On The Lake, Wa. ...
amxautox Offline
Still Retired. Still Posting on Moparts. A Lot.
amxautox  Offline
I think his 1/2 degree gauge is off, but only a 'little'.
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
Re: Camber-tire wear-street setting? [Re: ntstlgl1970] #1572807
02/02/14 09:41 PM
02/02/14 09:41 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Off topic, but are you comming down to Spring Fling Speed Festival this year at Willow Spring and test out that camber on the track??
Re: Camber-tire wear-street setting? [Re: autoxcuda] #1572808
02/02/14 09:44 PM
02/02/14 09:44 PM
Sac, CA, USA
N
ntstlgl1970 Offline
ntstlgl1970  Offline
N
Sac, CA, USA
yes and yes, i was just going to post about that....
Re: Camber-tire wear-street setting? [Re: brads70] #1572809
02/03/14 04:04 AM
02/03/14 04:04 AM
St. Louis, MO
mopardamo Offline
mopardamo  Offline
St. Louis, MO
Hello brads70,
So do you have a 315/30/18 under your E body at the front? If so what is your combo?
Damon
Re: Camber-tire wear-street setting? [Re: mopardamo] #1572810
02/03/14 10:18 AM
02/03/14 10:18 AM
Ontario,Canada
brads70 Offline OP
brads70  Offline OP
Ontario,Canada
Hello brads70,
Damon
No not yet. What I'm toying with is buying a new pair of AMD fenders and modifying them to fit .Storing my original fenders so I could put the car back to stock down the road if I wanted? No way stock fenders would work with that size. Right now the front end is off for welding in the US Cartool cowl braces. I finally have saved up enough for new rims/tires etc.... so just weighing my options?
Re: Camber-tire wear-street setting? [Re: brads70] #1572811
02/04/14 01:26 AM
02/04/14 01:26 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Hello brads70,
Damon
So how would those fit in the rear?
Re: Camber-tire wear-street setting? [Re: brads70] #1572812
02/04/14 01:53 AM
02/04/14 01:53 AM
Lethbridge, AB, Canada
dangina Offline
dangina  Offline
Hello brads70,
Damon
what 18" wheels will you be running?
Re: Camber-tire wear-street setting? [Re: brads70] #1572813
02/04/14 10:18 AM
02/04/14 10:18 AM
P
PasiR Offline
PasiR  Offline
P
What brand gauge you guys use for adjustment, how about price of them?
Or is it better to visit at alignment shop?
Re: Camber-tire wear-street setting? [Re: dangina] #1572814
02/04/14 10:20 AM
02/04/14 10:20 AM
Ontario,Canada
brads70 Offline OP
brads70  Offline OP
Ontario,Canada
Going to use these rims...
http://www.team3wheels.com/lt_iii.html
I'll be using 295/40/18 in the rear.
