Need Cam Help 408 Street / Strip #1572071
02/01/14 01:46 PM
02/01/14 01:46 PM
N. Of Detroit, Mi
733404spdCuda Offline OP
N. Of Detroit, Mi
I知 building a small block 408 and need help picking out a cam that is good for a street / strip Cuda on pump gas or E-85 if required. I知 a little concerned about the compression and know the cam selection is critical. Below are the details of the build:
1974 360 block, .030 over, cylinders race honed with plates, sonic tested, deck trued, line honed.
.030 Diamond pistons part #51026.
Eagle H-beam rods
Eagle Forged 4.00" crankshaft.
Edelbrock #60775 63cc aluminum cylinder heads.
Compression should be between 10.5 and 11 with the 63cc heads (Could I reduce this with Cometic head gaskets?)
Stall is 2600 - 2800 and 3.91 rear
Also looking for a good shop to port the heads that can turn them around in a few months.
Thanks for the help
Re: Need Cam Help 408 Street / Strip [Re: 733404spdCuda] #1572072
02/01/14 02:06 PM
02/01/14 02:06 PM
Q
Quicktree Offline
Quicktree  Offline
Q
Porter racing heads / Dwayne- fast68plymouth on the board
comp 308R cam, nice roller for street/strip
Re: Need Cam Help 408 Street / Strip [Re: 733404spdCuda] #1572073
02/01/14 02:26 PM
02/01/14 02:26 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Call over to Modern Cyl Heads and see when he could
turn them around.... Bobs doing the work now days..
just have them CNCd
Re: Need Cam Help 408 Street / Strip [Re: 733404spdCuda] #1572074
02/01/14 04:15 PM
02/01/14 04:15 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
looks like a nice build, but I would definitely rethink what you have planned on the torque convertor front.
I had a similar build to yours, just a hair more compression( 11.5 ish) Saw a lot of street use, and more than one 70 mile round trip jaunt to the track.
Used an 8 inch convertor that flashed about 4800 with a comp flat tappet cam..107 lsa, installed at 104 260/266@50, 598/623 with 1.6 rockers. Dwayne Porter specc'ed the cam, was a comp. 10.70's at 3400 pounds,with exhaust, fun general purpose build. Eddies, tti 1 5/8 to 1 3/4 step headers, weiand excellerator, 1025 race demon 4150 style carb, 416 cubes. Ross pistons and eagle rods,727, 4.10 gears.
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Need Cam Help 408 Street / Strip [Re: B3422W5] #1572075
02/01/14 04:24 PM
02/01/14 04:24 PM
Q
Quicktree Offline
Quicktree  Offline
Q
needs a converter change
Re: Need Cam Help 408 Street / Strip [Re: Quicktree] #1572076
02/01/14 05:30 PM
02/01/14 05:30 PM
N. Of Detroit, Mi
N. Of Detroit, Mi
Great advice guys, the converter is currently in the car. Can defiantly change it out during the engine swap. was your car a little too much on the street? my car will see 90% street action, so i don't want to get crazy with the cam, converter and rear gear.
Re: Need Cam Help 408 Street / Strip [Re: 733404spdCuda] #1572077
02/01/14 07:10 PM
02/01/14 07:10 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Probably 70/30 strip street. Even a 4.10 type gear at 60 mph ish with a 28 inch tire runs 3000-3200 or so, paying attention with convertor choice. That isn't gonna hurt anything. The cam I ran used ultra mild spring pressures, could put thousands of miles on such a setup.
Even an 8 inch convertor with good tranny pan and. cooler should live just fine.
You have a lot of nice parts there and wanting heads ported. Why saddle the combo to run 12's when it can runs 10's 90% as reliably.
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Need Cam Help 408 Street / Strip [Re: 733404spdCuda] #1572078
02/01/14 09:25 PM
02/01/14 09:25 PM
BPE Offline
BPE  Offline
Talk to Brett Miller for the heads. He goes by W5DART66. That's where all my heads go now, he's a straight shooter and won't give you bogus info.
Rod
Re: Need Cam Help 408 Street / Strip [Re: 733404spdCuda] #1572079
02/01/14 10:55 PM
02/01/14 10:55 PM
SoCal
Brian Hafliger Offline
SoCal
Eagle H-beam rods
Thanks for the help
When porting those heads, the chambers get ported and will be larger so don't worry about compression.
If your wanting hyd. roller we normally use something like 236-242@ .050 and about .580-.600 lift.
This is a real nice street grind that makes great TQ and HP with a good idle (slightly rough).
Brian
Brian Hafliger
Re: Need Cam Help 408 Street / Strip [Re: BPE] #1572080
02/01/14 11:01 PM
02/01/14 11:01 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Curtis Boggs did my Edelbrocks and they work well. Call Hughes Engines for a cam.
Re: Need Cam Help 408 Street / Strip [Re: justinp61] #1572081
02/02/14 12:27 AM
02/02/14 12:27 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Another for "Dwayne Porter" as he worked my heads and speced out my cam which works real good. Ron
Re: Need Cam Help 408 Street / Strip [Re: justinp61] #1572082
02/02/14 12:59 AM
02/02/14 12:59 AM
Pa
Hot 340 Offline
Hot 340  Offline
Pa
What flow numbers you get if you don't mind me asking.. you can pm me if you want.
Re: Need Cam Help 408 Street / Strip [Re: Hot 340] #1572083
02/05/14 06:32 AM
02/05/14 06:32 AM
N. Of Detroit, Mi
N. Of Detroit, Mi
Thanks for all the good info! I talked to bob at MCH and he will be CNC porting the heads. i'm going to take your advice on the cam and go with a hyd roller and a converter change. I will give you guys an update after we dyno the motor...
Pic of the car the motor is going into:
Re: Need Cam Help 408 Street / Strip [Re: 733404spdCuda] #1572084
02/05/14 10:35 AM
02/05/14 10:35 AM
Indy
FlyFish Offline
FlyFish  Offline
Indy
My 410 stroker has a comp XR286R cam in it and Edelbrock heads ported by Ryan Johnson at Shadydell Speed Shop. My car is street/strip, 3200#'s, pump gas, 10.8:1 compression, 8" converter, and runs 6.70's in the 1/8 (mid 10's in the 1/4). Current times in sig below.
I like this cam because it is easy on parts and makes good power.
67 Barracuda street car, 408, e85, 1.38 60', 6.44 @105.9 in the 1/8 mile, 10.19 @130.5 in the 1/4...so far....
