Re: Drag Week 62 Valiant's Small Block is finally ready!
[Re: J_BODY]
#1571983
08/18/14 03:36 AM
08/18/14 03:36 AM
Posts: 13,202 aZLiViN
J_BODY
aZLiViN
[Re: J_BODY]
#1571984
08/18/14 05:24 AM
08/18/14 05:24 AM
Posts: 4,448 Phoenix, AZ
MoparBilly
Phoenix, AZ
What's up is that I am progressing at a snails pace!
I installed a new repop trunk lock(remember the lost key incident) and carefully readjusted the trunklid to eliminate the pesky problem it developed of grabbing the rear window gasket. Afterwards I checked carefully to make sure the latch lined up with the lock. Satisfied, I slammed the trunklid shut and stepped back to admire my handy work. It was at this time, I reminded myself that I had left the keys for the new repop lock in the trunk for safekeeping! Luckily the repop trunk lock was not nearly as robust as the factory original, and it only took a screw driver and three smacks with a 2lb sledge to render it useless. I may never have a trunk lock in the car again!
The wiring is finally complete. The button at the back of the shifter is the trans brake. The smaller one mounted to the side of it goes to a toggle switch that allows it to be used for the horn or the line lock. The button on the shifter itself is for the nitrous, and is wired through the accessory 2 on my switch panel, which can only be activated when the ignition is on. The dome light works, and is activated by either door switch, as installed at the factory 52 years ago. I hooked the factory dash lights into accessory 1 with my gauges, and every single bulb lit up on cue ( The two Drag Week trips previously in this car, I had the tack light and oil pressure, that was it) The dash is completely assembled, including a new repop glove box liner.
The engine still hasn't been fired in the car, this dang Race Demon carb is kicking my butt. I rebuilt it, and now I can't get the floats or needle and seats to work, every time I turn on the fuel pump, it shoots fuel out of the vents.
I wanted to swap the seats from side to side, as the passenger one has more hip room, but apparently the six bolt helicoil pattern on the bottom of plastic race seats is not universal...didn't see that coming until I had all the brackets removed.
Boone Had a hall effect switch failure in the Barnyard Viper's distributor.
Dale still hasn't replaced the alternator on the Gremlin that failed about 4 months ago.
Darren just ordered 3800$ worth of parts for the Dakota. All of which will still need to be installed when I get to Oklahoma.
"Livin' in a powder keg and givin' off sparks"
4 Street cars, 5 Race engines
[Re: MoparBilly]
#1571985
08/19/14 10:46 AM
08/19/14 10:46 AM
Posts: 8,037 Tulsa OK
Bad340fish
Tulsa OK
Looking good Billy! See you in a few weeks.
68 Barracuda Formula S 340
[Re: Darryls-Demon]
#1571988
08/23/14 04:36 PM
08/23/14 04:36 PM
MoparBilly
Phoenix, AZ
2.76s out 3.55s in. Should make consistent 11.50-11.60 passes a little easier for Rachael, and possibly allow me to take a little N20 jet away from her as well.
Boone is changing the cam and lifters on the Barnyard Viper, he's starting on it today, since he was afraid we were going into "Thrash Week" with too many cars assembled and ready to go.
[Re: 6pak2go]
#1571990
08/25/14 08:47 PM
08/25/14 08:47 PM
Posts: 3,325 Truckville, the capital of NY
85_Ram_4speed
Billy, getting stingy with the updates, LOL.
I was wondering what has been happening. Glad to see in all these years of hearing your stories and getting ready that nothing has changed. Panic right until the end!
Outcast Dodge guy.
[Re: 85_Ram_4speed]
#1571991
08/28/14 03:58 AM
08/28/14 03:58 AM
MoparBilly
Phoenix, AZ
Sorry I haven't been more forthcoming, just get frustrated on occasion.
The Belvedere. It's sitting behind the trailer, ready to load. Once I get back to Oklahoma, I'll finish wiring up the new gauges, but mechanically I feel pretty confident. After Rachael's DNF after the first day last year, I wanted to make sure this year was better.
The Valiant. Put Darryl's 950 HP on tonight, fuel leaking out of both accelerator pumps. Did fire it up but not for very long. When my son gets home from work in the morning we'll get the hood on it, so I can load it. Would like to head out around noon tomorrow, we will see.
The brothers aren't sending me any pictures, and are being very vague with where they are. I'm fairly Confident that the Gremlin, in all it's lexan window, 5 gallon fuel cell glory, will be ready, as will the Barnyard. Darren's Dakota however...not a chance. It was back at the chassis shop today, then goes back to the paint shop for 3 days. So we will get it Tuesday, and we are supposed to put new gauges in, interior, wiring, and convert it to E-85...I promise I'll take pictures!!
[Re: MoparBilly]
#1571992
08/28/14 09:53 AM
08/28/14 09:53 AM
Bad340fish
Tulsa OK
Billy, you have been doing this long enough to know you can't trust a body shop timeline lol.
See you soon!
[Re: Bad340fish]
#1571993
08/28/14 08:18 PM
08/28/14 08:18 PM
MoparBilly
Phoenix, AZ
Heading for Oklahoma as soon as the Grandson gets home from first grade, got to tell him bye or he will be upset!
Think I've got everything loaded...
[Re: MoparBilly]
#1571995
08/28/14 08:30 PM
08/28/14 08:30 PM
moparpollack
Lil Herman
Lil Herman
85086
See you at Thunder Valley! ![](/ubbthreads/images/graemlins/wave.gif)
[Re: moparpollack]
#1571996
08/29/14 03:39 PM
08/29/14 03:39 PM
Posts: 861 lancaster,california
johnnycuda
Have a safe trip, and good luck on Drag Week!!, ![](/ubbthreads/images/graemlins/thumbs.gif) one day I'll get to do this.
1970 'Cuda,Lime Light,499 Indy S/R's 10.70's @125,street driven ALOT! 1966 Barracuda 360,now a 5spd,Hemi Orange,Hot Rod Air, New daily driver-2003 Ram 2500 Cummins 5.9 '69 Valiant 2-dr, sleeper! New project---1938 Dodge truck, plan is a 360 with a A500, AC, Calvert rear susp., rack and pinion front with coils.
[Re: MoparBilly]
#1572000
09/04/14 02:34 PM
09/04/14 02:34 PM
Bad340fish
Tulsa OK
I wanted to go to test and tune Friday but I will be yanking the motor to fix a pan leak. Last weekend I yanked the motor to fix the thrust bearing and went with a different brand of gasket and it is biting me. All this for a race with zero prize money LOL.
