Seat track stud removal #1571745
01/31/14 08:54 PM
01/31/14 08:54 PM
Houston, Texas
racerx20 Offline OP
Standard but OK
racerx20  Offline OP
Standard but OK
Houston, Texas
Doing some modifications to my driver's side seat track for more leg room. Can the original seat studs that go through the floor be hammered out? Looking at the multiple mounting holes I assume so. I don't want to bend up the studs, they seem to be in there pretty good. Here is a pic of the track and stud.
Thanks!
1972 Road Runner
1988 Shelby CSX-T
Re: Seat track stud removal [Re: racerx20] #1571746
01/31/14 09:46 PM
01/31/14 09:46 PM
Worcester, Mass
68goldfish Offline
68goldfish  Offline
Worcester, Mass
Hi, That stud is called a PEM. It has a serrated area on the shank that grabs the metal when it is pressed in. You can press it out. A hammer will get it out. But the hole can warp. With a new hole in a different location, you could press in the used PEM. Good luck!
Re: Seat track stud removal [Re: 68goldfish] #1571747
01/31/14 09:49 PM
01/31/14 09:49 PM
Houston, Texas
racerx20 Offline OP
Standard but OK
racerx20  Offline OP
Standard but OK
Houston, Texas
Thank you for the info!
1972 Road Runner
1988 Shelby CSX-T
Re: Seat track stud removal [Re: racerx20] #1571748
02/01/14 03:51 PM
02/01/14 03:51 PM
N
NITROUSN Offline
NITROUSN  Offline
N
There was a write up at one time in the resto section.
Re: Seat track stud removal [Re: NITROUSN] #1571749
02/01/14 06:06 PM
02/01/14 06:06 PM
State of Confusion
hp383 Offline
Just a normal tag again
hp383  Offline
State of Confusion
Yea, they are like little wheel studs.
Re: Seat track stud removal [Re: hp383] #1571750
02/01/14 09:59 PM
02/01/14 09:59 PM
Stow,Ohio
RBSat66 Offline
RBSat66  Offline
Stow,Ohio
Check the floor of your car, I found that my floorboard had a second set of dimples or holes in it to move the front seat back.
Re: Seat track stud removal [Re: RBSat66] #1571751
02/01/14 11:57 PM
02/01/14 11:57 PM
Houston, Texas
racerx20 Offline OP
Standard but OK
racerx20  Offline OP
Standard but OK
Houston, Texas
Haven't noticed any more holes or dimples but I'll check it out again.
1972 Road Runner
1988 Shelby CSX-T
