block lightening #1571376
01/30/14 11:46 PM
01/30/14 11:46 PM
oklahoma
forphorty Offline OP
oklahoma
Has anyone here done any lightening on an OEM block? Some of the bosses, lumps, etc. on the outside of the block look nonessential and i'm wondering how much weight i might lose if i eliminate some of them.
Re: block lightening [Re: forphorty] #1571377
01/30/14 11:51 PM
01/30/14 11:51 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I did it on a Mega Block. a lot of work for little gain. I saved less than 10 lbs. I wouldn't do it again.
Doug
Re: block lightening [Re: dvw] #1571378
01/31/14 12:02 AM
01/31/14 12:02 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
How many hours for 10 lbs??
I'm sure FMJ the lunatic Jenny Craig wants to know
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: block lightening [Re: forphorty] #1571379
01/31/14 01:38 AM
01/31/14 01:38 AM
I did a 1970 440 block years ago, cut all the side protrusions off inside and outside, cut the front corners off and removed some of the rear trans munt surfaces beside the oil pan and outer tran bellhousing bolts. I don't have a clue on how much it saved, probally less than 10 lbs. I got to see a block professionally lighten years later, it was 440 block that the old Rod Shop had put in a mill and thinned every spot on that block they cold including remove a bunch from the decks They went so far as to remove all the metal behind the cam gear even I know some old Pro Stock racers that where grinding on the side of one of thier blocks with a big electric hand body grinder back in the early 1970s, they said that Bob Lambeck had told them to do that before bringing him the block to work on. The ended up setting and holding the NHRA Pro Stock recod for around six weeks later in the mid 1970s Your imagination is the only thing, and hopefully some common sense also, that limits how much material and where you remove it from when it comes to lightening your block Edited, I believe those old Pro Stock guys got about 40 lbs off of there blocks when done Maybe not, maybe more
Re: block lightening [Re: hemi-itis] #1571380
01/31/14 03:15 AM
01/31/14 03:15 AM
fullmetaljacket Offline
Yeah, I wanna know. I've actually thought through it for a while now, but my block is in the car.
Real question is: by removing the ears and motor mount bosses and such, will it weaken the block structure in any way?
Re: block lightening [Re: fullmetaljacket] #1571381
01/31/14 04:32 AM
01/31/14 04:32 AM
geezer acres rest home
dakotawilly Offline
dakotawilly  Offline
I believe indy mentions they can machine away 45 lbs on their blocks.....
SFI 25.5 depends,no leak,even at 213 mph....
Re: block lightening [Re: dakotawilly] #1571382
01/31/14 10:00 AM
01/31/14 10:00 AM
Tulsa, Ok
WadeMetzinger Offline
Tulsa, Ok
I believe that was on the Mega blocks and it cost like $1,000. I thnk the mega blocks weighted close to 100 lbs more than a stock block so for some this was a viable option.
Wade Metzinger 918-809-0987
71 Cuda 9.28@145 -1s, Pglide
68 Cuda 10.64@124 1.45 60's 318->390 eddys
Moparts discount code on WIX - moparts www.Filter1.com
Re: block lightening [Re: WadeMetzinger] #1571383
01/31/14 02:16 PM
01/31/14 02:16 PM
NE Oklahoma
V
Von Offline
Von  Offline
V
NE Oklahoma
My question is...what are we working on there Mr. Tim??
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72. Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
Re: block lightening [Re: Von] #1571384
01/31/14 11:10 PM
01/31/14 11:10 PM
tulsa ok
U
upnover Offline
upnover  Offline
U
tulsa ok
I guess u could with a motor plate? remove the mount bosses at least.
Re: block lightening [Re: Von] #1571385
01/31/14 11:43 PM
01/31/14 11:43 PM
oklahoma
oklahoma
Stock 318. If only it were something more exciting. Well, it will have cam, intake and headers. I have been doing bodywork on my 72 duster and i pulled the engine and tranny to do some repairs in the engine bay. Before i repaint the engine i plan on grinding the casting flash off the outside of the block and heads. I thought i might get a little more serious with the grinder if i could knock off a few pounds for a couple of hours of my time. BTW, someone showed me a picture of the parking lot at Danny Millers funeral .I spotted your RR in the pic. I'm guessing it's been a while since the ole bird has been this far north.
Re: block lightening [Re: hemi-itis] #1571386
01/31/14 11:53 PM
01/31/14 11:53 PM
Florida STAYcation
dOoC Offline
The village idiot's idiot
dOoC  Offline
Florida STAYcation
Now if some from Long Island would stop eating Twinkies ...he could lose that hUn at no cost !
Re: block lightening [Re: dOoC] #1571387
01/31/14 11:57 PM
01/31/14 11:57 PM
Tampa
DusterDave Offline
DusterDave  Offline
Tampa
Funny, but true. The lump in the driver's seat would be the best place to reduce weight.
Gone to the dark side with an LS3 powered '57 Chevy 210
Re: block lightening [Re: DusterDave] #1571388
02/01/14 02:08 AM
02/01/14 02:08 AM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
here's one
home of the
Sox and Martin Hemi Duster
Re: block lightening [Re: HEMIFRED] #1571389
02/01/14 02:11 AM
02/01/14 02:11 AM
Florida STAYcation
dOoC Offline
dOoC  Offline
Florida STAYcation
So H F ... how "fragile" is a block done like that ?
Re: block lightening [Re: DusterDave] #1571390
02/01/14 02:15 AM
02/01/14 02:15 AM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
home of the
Re: block lightening [Re: DusterDave] #1571391
02/01/14 02:22 AM
02/01/14 02:22 AM
hemi-itis Offline
hemi-itis  Offline
Not twinks,bLOnDe ORiOs,,,,,,,,,Might be 20 lbs At my weight 40 or 50 lbs won't make that much difference,but another 10 lbs of boost might
Re: block lightening [Re: hemi-itis] #1571392
02/01/14 02:41 AM
02/01/14 02:41 AM
Florida STAYcation
dOoC Offline
dOoC  Offline
Florida STAYcation
.....excuse me 'itis ... you can pack-on a hUn ...and all you have to do is put a BIGGER pulley on the bottom ... or a smaller pulley on top ...OR BOTH ....
Re: block lightening [Re: HEMIFRED] #1571393
02/01/14 11:54 PM
02/01/14 11:54 PM
USA
SSAAHemiFan Offline
SSAAHemiFan  Offline
USA
here's one
WOW - I have seen some shaved blocks but none that much - Great pic - Thanks
Re: block lightening [Re: SSAAHemiFan] #1571394
02/02/14 12:07 PM
02/02/14 12:07 PM
warren, mich.
dwayne welder Offline
warren, mich.
Hello All!!! When i used to work at, SVI, in the 70's, thats Ted Spehard's shop, they had blocks like that!!! We use to get them from Don Calton. He had a very old mill that they used that for! I made the trip down there a couple of time's, Lot's of cool tuff going on in those day's!!!!
Re: block lightening [Re: dwayne welder] #1571395
02/02/14 12:40 PM
02/02/14 12:40 PM
Cincinnati OH
Bishop Offline
Bishop  Offline
Cincinnati OH
