Re: what oil for road trip?
[Re: 05dakota]
#1568712
01/25/14 10:28 PM
01/25/14 10:28 PM
Posts: 3,696 jersey
Spaceman Spiff
jersey
i doubt one oil change at 7,000 will hurt it. with today's oil thats not an uncommon change interval. Just keep an eye on the level each morning, or at fuel stops.
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
[Re: 05dakota]
#1568715
01/26/14 02:26 AM
01/26/14 02:26 AM
Posts: 11,836 Florida
mopar346
Let me tell ya about fat chicks!
Buy your own oil and filter and take it to anyone that changes oil and just have them use your stuff and pay the labor, probably $10-15.
Careful, your character's showing!
[Re: mopar346]
#1568716
01/26/14 03:36 AM
01/26/14 03:36 AM
RapidRobert
Take 5qts of Bradd Penn & a wix filter & a shallow pan & a crescent wrench & an oil filter wrench & several clean rags & a can of spray brake kleen & change it in Portland. You could put the used oil in 2 empty gallon antifreeze jugs & O'reillys & others will take the used oil. Need a funnel also. You go in & dump it in their 55 gal barrell
[Re: RapidRobert]
#1568717
01/26/14 01:36 PM
01/26/14 01:36 PM
Posts: 9,436 Blair County,PA
62maxwgn
Blair County,PA
You forgot a floor jack and clean cloths.
[Re: RapidRobert]
#1568720
01/26/14 08:21 PM
01/26/14 08:21 PM
Posts: 21,830 Kirkland, Washington
Pacnorthcuda
I'm glad you got my back. Those small (2&1/4 ton iirc) hyd floor jacks fit in the trunk easily & are handy
Surely nobody is suggesting he crawl under a vehicle supported by a jack...
[Re: Pacnorthcuda]
#1568721
01/26/14 08:29 PM
01/26/14 08:29 PM
Posts: 30,444 Florida STAYcation
dOoC
The village idiot's idiot
Florida STAYcation
SHIRLEY they are NOT ...
My trick here in the condo is building a set of "ramps" out of 2x4's(3-stacked have wurked ferr me) .. eNuff room furr a pan-slide and a filter dump
[Re: BDW]
#1568723
01/27/14 12:41 AM
01/27/14 12:41 AM
Posts: 6,906 IL, Aurora
ademon
IL, Aurora
with all the hwy miles and a stock 318 i think you will be fine without a change.
[Re: Pacnorthcuda]
#1568725
01/27/14 03:51 AM
01/27/14 03:51 AM
Posts: 13 Florida
Tom65
well you could park with the fromt tires up on the curb. no jack no stands no problem... lol keep a few qts. with you and keep the level up you will be fine till you get home!
