1968 Charger RT 44-red stripe tire question/update #1566658
01/21/14 10:56 PM
01/21/14 10:56 PM
Manistee, Michigan.
High Impact Offline OP
Manistee, Michigan.
I bought a 68 Charger RT about 10 years ago and made sure that the motor and trans were original but never till today have I bothered to decode the Fender Tag.
It was built on JAN-19-68 and is a Factory painted AA1 Car. But when it came to the tires it had code # 44 which the book I had said red stripe tires. MY QUESTION IS: What wheels came with those tires? Was it just the Road Wheels or stock steel wheels?
I know the build sheet behind the back seat in LONG gone as the guy I bought it from had pulled the back seat out sometime around 1976 and thought to himself " what the hell is that piece of paper" and pulled it out.........Couldnt read it.......so he told me he threw it away!!!!!! SO, unless there is another one in the front seats somewhere I dont have a buildsheet.
Can anyone enlighten me.
Re: 1968 Charger RT Fender Tag Question. 44-red stripe tire [Re: High Impact] #1566659
01/22/14 12:05 AM
01/22/14 12:05 AM
Manistee, Michigan.
Manistee, Michigan.
Re: 1968 Charger RT Fender Tag Question. 44-red stripe tire [Re: High Impact] #1566660
01/22/14 02:55 AM
01/22/14 02:55 AM
NB, Canada
moparfan53 Offline
moparfan53  Offline
NB, Canada
Wheels/wheel covers were a separate option from tires, so you cannot determine which wheel the car had by the tire option.
FYI: Your Charger may or may not have built on Jan 19. That date is referred to as the SPD (Scheduled Production Date). It is common for cars to be built days, sometimes weeks, before or after that date.
The AA silver paint is a great color. You may or may not know that it was the only color that had an extra charge of $22 for buffing.
Re: 1968 Charger RT Fender Tag Question. 44-red stripe tire [Re: High Impact] #1566661
01/22/14 02:59 AM
01/22/14 02:59 AM
Downey, CA.
BB14404SPD Offline
BB14404SPD  Offline
Downey, CA.
My charger's fender tag shows 44 - F70 x 14” RSW . The build sheet shows 16B for steel wheels painted black.
Re: 1968 Charger RT Fender Tag Question. 44-red stripe tire [Re: BB14404SPD] #1566662
01/22/14 08:32 AM
01/22/14 08:32 AM
Manistee, Michigan.
Manistee, Michigan.
I may never know what wheels came on if I cant find another build sheet in the car then....
One more question, Were drip rail moulding a option?
According to my tag, my car show's wheel well mouldings, AM radio as the only options! but has a factory tach and AM/FM radio in it?
No power steering,brakes,tach,console,vinyl top....none of the cool options from that era. The guy I bought it from bought it in 76 and drove it one year and put it away till I bought it in 2004.
Re: 1968 Charger RT Fender Tag Question. 44-red stripe tire [Re: High Impact] #1566663
01/23/14 03:22 AM
01/23/14 03:22 AM
Downey, CA.
BB14404SPD Offline
BB14404SPD  Offline
Downey, CA.
My fender tag has:
2/5 - (535) – DRIP TROUGH MOLDINGS - STD
3/0 - (540) – BELT LINE MOLDINGS - STD
7/8 - (548) – WHEEL LIP MOLDINGS – STD
Re: 1968 Charger RT Fender Tag Question. 44-red stripe tire [Re: BB14404SPD] #1566664
01/23/14 03:27 AM
01/23/14 03:27 AM
Downey, CA.
BB14404SPD Offline
BB14404SPD  Offline
Downey, CA.
Also could still be in car in another location. Behind driver seat rear cover, above glove box top,in vinyl top or under carpet.
Re: 1968 Charger RT Fender Tag Question. 44-red stripe tire [Re: BB14404SPD] #1566665
01/23/14 03:28 AM
01/23/14 03:28 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
Unless your car is BLACK - the car had full wheel covers on it.
Re: 1968 Charger RT Fender Tag Question. 44-red stripe tire [Re: 6bblgt] #1566666
01/23/14 03:31 AM
01/23/14 03:31 AM
Downey, CA.
BB14404SPD Offline
BB14404SPD  Offline
Downey, CA.
Triple black with stripe delete
Re: 1968 Charger RT Fender Tag Question. 44-red stripe tire [Re: High Impact] #1566667
01/23/14 03:43 AM
01/23/14 03:43 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
One clue to the wheels would be evidence of red paint on the drums, factory RED paint = chrome "ROAD" wheels.
per the fender tag '68 Charger R/Ts were STANDARD with:
bucket seats (b/4 top line)
drip rail, belt line, & wheel lip mouldings (2/5 3/0 7/8 second line from the bottom)
3.23 rear gears (AX/4 second line from the bottom)
"bumblebee stripe" (S/? second line from the bottom) was STANDARD on a R/T (Hamtramck built cars were left blank for a 310 BLACK stripe)
83 440HP 4bbl engine, 5 automatic transmission, & 44 F70-14 "red stripe" Goodyear SPEEDWAY tires. (bottom line)
AM/FM wasn't available from the factory in a '68 b-body - it was in the dealer accessory catalog.
Re: 1968 Charger RT Fender Tag Question. 44-red stripe tire [Re: 6bblgt] #1566668
01/23/14 08:17 AM
01/23/14 08:17 AM
Manistee, Michigan.
Manistee, Michigan.
Very nice info to know!!
I will go down today and pull the wheels off and see if I can find any red paint. I guess there's a date on the K frame too that Im going to look for. I'll report back.
Re: 1968 Charger RT Fender Tag Question. 44-red stripe tire [Re: High Impact] #1566669
01/23/14 08:21 AM
01/23/14 08:21 AM
Manistee, Michigan.
Manistee, Michigan.
Here's my tag info:
Re: 1968 Charger RT Fender Tag Question. 44-red stripe tire [Re: High Impact] #1566670
01/23/14 02:21 PM
01/23/14 02:21 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
a little "thin" on the OPTIONs, but it has the important ones!
Re: 1968 Charger RT Fender Tag Question. 44-red stripe tire [Re: 6bblgt] #1566671
01/23/14 09:00 PM
01/23/14 09:00 PM
Manistee, Michigan.
Manistee, Michigan.
I pulled the wheels off today and could not find any red paint what so ever. They were however painted gloss black at one time.... BUT, under the gloss black where the wheel had seated on the drums was a semi or flat black. Were the drum painted a black at all on the face's or could that be paint from the back of the original wheel when it was installed at the factory?
#2 QUESTION.
With red line tires, could you have hubcaps with red lines?
#3 QUESTION.
Were the steel wheels always painted body color in 68 or could my silver car of had black wheels with red lines?
Thanks!
Re: 1968 Charger RT Fender Tag Question. 44-red stripe tire [Re: High Impact] #1566672
01/23/14 09:17 PM
01/23/14 09:17 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
The face of the brake drums were painted red SO rust wouldn't show thru the holes in the "ROAD" wheels - they were unpainted otherwise.
Re: 1968 Charger RT Fender Tag Question. 44-red stripe tire [Re: 6bblgt] #1566673
01/23/14 09:21 PM
01/23/14 09:21 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
'68 Charger R/T was STANDARD with "red streak" tires & "hub caps". The '68 hub cap doesn't have a red line, that was new for '69. Wheels with hub caps are the same color as the car in '68. Judging by the lack of OPTIONs, someone was shopping on a budget I'd bet silver wheels & hub caps when NEW! Followed closely by some "MAGS".
Re: 1968 Charger RT Fender Tag Question. 44-red stripe tire [Re: BB14404SPD] #1566674
01/23/14 09:40 PM
01/23/14 09:40 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
Is it currently RED? Got any pics? I know of 1 440 car & 2 HEMI '68 R/Ts that are black, black interior, black top & stripe delete.
Re: 1968 Charger RT Fender Tag Question. 44-red stripe tire [Re: 6bblgt] #1566675
01/23/14 09:48 PM
01/23/14 09:48 PM
Downey, CA.
BB14404SPD Offline
BB14404SPD  Offline
Downey, CA.
It's currently all black. The pics I have are 4 meg so I have to re-size them. I will post it up shorty. I have the fender tag maybe you can tell me what the extra tag on top right with the 16 means.
Re: 1968 Charger RT Fender Tag Question. 44-red stripe tire [Re: BB14404SPD] #1566676
01/23/14 09:56 PM
01/23/14 09:56 PM
Downey, CA.
BB14404SPD Offline
BB14404SPD  Offline
Downey, CA.
Are they all 4 speeds?
Re: 1968 Charger RT Fender Tag Question. 44-red stripe tire [Re: BB14404SPD] #1566677
01/23/14 10:14 PM
01/23/14 10:14 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
1 of each now! HEMI auto/440 auto/HEMI 4-spd/440 4-spd
The 440 auto car is currently RED (I should looked at your user name ). The additional tags are for inspector's stamps.
