Page 1 of 3 1 2 3
Gen 3 Hemi Rocker Arms #1565861
01/20/14 12:42 AM
01/20/14 12:42 AM
SC304 Offline OP
SC304  Offline OP
Looking for information on adjustable rocker arms that will fit gen 3 heads with out machine work. I currently run Jesel rockers in Super Stock but I'm building a Factory stock motor which is an all aluminum 426. Cannot modify the castings. The stock rockers don't have any adjustment obviously. I have heard of Harland Sharp and T&D rockers. Anyone have any experience with these or anything else? Thanks for any input.
Mike
Re: Gen 3 Hemi Rocker Arms [Re: SC304] #1565862
01/20/14 12:50 AM
01/20/14 12:50 AM
MR_P_BODY Offline
MR_P_BODY  Offline
In the other post it shows the Harland Sharp rockers
with adjusters.. I dont know if TD has them or not..
would be worth a call
EDIT
here is the pic from the other post
Re: Gen 3 Hemi Rocker Arms [Re: MR_P_BODY] #1565863
01/20/14 04:34 PM
01/20/14 04:34 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
EDIT
I have heard that TD will be soon. Call them at the end of March.
I have heard HS has had problems with castings.
Rocker ARM specialist should be out end of April.
No confirmation just rumor.
What about adjustable pushrods?
Matt
Re: Gen 3 Hemi Rocker Arms [Re: MattW] #1565864
01/20/14 04:39 PM
01/20/14 04:39 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
EDIT
What about adjustable rocker arms?
Matt
Adjustable pushrods???
Mopar to the bone!!!
Re: Gen 3 Hemi Rocker Arms [Re: 72Swinger] #1565865
01/20/14 09:03 PM
01/20/14 09:03 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
Sorry fixed it.
Re: Gen 3 Hemi Rocker Arms [Re: MR_P_BODY] #1565866
01/20/14 10:04 PM
01/20/14 10:04 PM
SC304 Offline OP
SC304  Offline OP
Thanks Mr P
Can you identify the other post please?
Admittedly Harland Sharp will have issues with heavy springs and high RPM.
Thanks Mike
Re: Gen 3 Hemi Rocker Arms [Re: SC304] #1565867
01/21/14 09:16 AM
01/21/14 09:16 AM
Melbourne , Australia
LA360 Offline
LA360  Offline
The T&D stuff will be pricey like the Jesel stuff. There was an article on dragzine.com or Enginelabs.com about them.
They were around $2600 or there abouts
Alan Jones
Re: Gen 3 Hemi Rocker Arms [Re: SC304] #1565868
01/21/14 10:28 AM
01/21/14 10:28 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Thanks Mr P
Thanks Mike
Its this post(Hearing This More and More )
https://board.moparts.org/ubbthreads/show...0&fpart=all
Re: Gen 3 Hemi Rocker Arms [Re: SC304] #1565869
01/21/14 01:59 PM
01/21/14 01:59 PM
MN
hemidup Offline
hemidup  Offline
MN
Mike
With factory stock, can you run other than stock appearing rocker arms.
Jerry Williams.
Re: Gen 3 Hemi Rocker Arms [Re: hemidup] #1565870
01/21/14 07:42 PM
01/21/14 07:42 PM
LA360 Offline
LA360  Offline
Alan Jones
Re: Gen 3 Hemi Rocker Arms [Re: LA360] #1565871
01/21/14 09:57 PM
01/21/14 09:57 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Re: Gen 3 Hemi Rocker Arms [Re: Dragula] #1565872
01/22/14 12:13 AM
01/22/14 12:13 AM
Melbourne.....Oz-land
Moparmal Offline
Moparmal  Offline
I agree!.... Lemme ask this....what rocker systems are the 9 sec LX cars like Red Baron running....and the 8 sec Drag Pak cars like Dave Barton......and are they breaking them?
67 RO23 clone with 6.1 SRT Hemi and dual quads. Soon to have Drag Pak induction and Throttle body.
Re: Gen 3 Hemi Rocker Arms [Re: Moparmal] #1565873
01/22/14 05:05 PM
01/22/14 05:05 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
I'll take a guess "STOCK"
What do I win if I'm right? Matt
Re: Gen 3 Hemi Rocker Arms [Re: MattW] #1565874
01/22/14 07:08 PM
01/22/14 07:08 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
I would bet the really high rpm builds are using Jesel. Although the stockers have been known to be fine to 7800....
Re: Gen 3 Hemi Rocker Arms [Re: 72Swinger] #1565875
01/22/14 07:23 PM
01/22/14 07:23 PM
GO BUCKS !!!!!!!
3
340RICK Offline
340RICK  Offline
GO BUCKS !!!!!!!
Barton is running either stock or Harland Sharp on his stuff.
Re: Gen 3 Hemi Rocker Arms [Re: 340RICK] #1565876
01/22/14 08:57 PM
01/22/14 08:57 PM
LA360 Offline
LA360  Offline
I would be surprised if Barton's shop didn't help with the development of the T&D rocker system, as they did with the Gen II stuff.
Alan Jones
Re: Gen 3 Hemi Rocker Arms [Re: LA360] #1565877
01/22/14 09:07 PM
01/22/14 09:07 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
So here's a couple of questions. The reason for adjustable rockers is for a solid roller, right?
Is it possible to use the factory rockers with a solid and set your lash with custom pushrods?
Isn't the whole idea with super stock or any HP engine is lightweight parts? Rev quicker? I don't think any of the aftermarket would compare with the weight of stock rockers.
Matt
Re: Gen 3 Hemi Rocker Arms [Re: 340RICK] #1565878
01/22/14 09:33 PM
01/22/14 09:33 PM
SC304 Offline OP
SC304  Offline OP
I have been told that Ray uses the Harland sharp and I've been told he had T&D?
I've heard T&D has systems running on the tracks.. I threw the post up here to try and find feedback on any rocker arm info available. The RPM's are expected to exceed 8500.
For a clarification. My post started with a reference to Factory Stock. It's actually the new factory shoot out class. Mopar 426 in a Challenger, against the Copo 427 and the Ford 429 in a Cobra Jet.
As I stated earlier I run Jesel on my 6.1 and 6.4 heads in super stock. Jesel does not have an offering for a Stock replacement rocker.
Totally different rule book though in factory shoot out with the 426 in Stock. Cylinder head and intake is Cnc'd, valves are Ti, compression is 15:1 all in the Aluminum block with a solid roller and lifter under a large throttle body. Controlling lash is the most Difficult. We have made dyno pulls and witnessed Geometry Fluctuation lets call it. Lol.
Re: Gen 3 Hemi Rocker Arms [Re: MattW] #1565879
01/22/14 09:35 PM
01/22/14 09:35 PM
GO BUCKS !!!!!!!
3
340RICK Offline
340RICK  Offline
GO BUCKS !!!!!!!
Barton is not working with T&D on there Gen 3 rockers. First time they seen them was at PRI show in INDY. He told me he does not know how you could get a socket or wrench on adjuster nut.....
You certainly can use lash caps or adjustable push rods with stock rockers but would take hours to set valve lash.
Re: Gen 3 Hemi Rocker Arms [Re: MattW] #1565880
01/22/14 09:44 PM
01/22/14 09:44 PM
SC304 Offline OP
SC304  Offline OP
Yes we are running a solid cam. And yes Lash Adjustment is tough to accomplish.
Don't think that push rods are the answer but certainly an option?
The acceleration is great but it has to be stable thru the acceleration and at max RPM you hope right? So lighter is always not the best scenario. Harland's are Aluminum while T&D is steel. Speaking with Harland's Engineer I don't think they intended the rocker for the application described in this post? Not knocking the product as they had a different target market? Just like Jesel had no plan to sell their rockers as a stock replacement.
Page 1 of 3 1 2 3
