Looking for information on adjustable rocker arms that will fit gen 3 heads with out machine work. I currently run Jesel rockers in Super Stock but I'm building a Factory stock motor which is an all aluminum 426. Cannot modify the castings. The stock rockers don't have any adjustment obviously. I have heard of Harland Sharp and T&D rockers. Anyone have any experience with these or anything else? Thanks for any input.
Mike
With factory stock, can you run other than stock appearing rocker arms.
Jerry Williams.
