Quote: In the other post it shows the Harland Sharp rockers with adjusters.. I dont know if TD has them or not.. would be worth a call EDIT here is the pic from the other post
I have heard that TD will be soon. Call them at the end of March. I have heard HS has had problems with castings. Rocker ARM specialist should be out end of April. No confirmation just rumor. What about adjustable rocker arms? Matt
