Barton is not working with T&D on there Gen 3 rockers. First time they seen them was at PRI show in INDY. He told me he does not know how you could get a socket or wrench on adjuster nut.....
You certainly can use lash caps or adjustable push rods with stock rockers but would take hours to set valve lash.
