Re: Gen 3 Hemi Rocker Arms
[Re: SC304]
#1565862
01/20/14 12:50 AM
01/20/14 12:50 AM
Posts: 52,972 Romeo MI
MR_P_BODY
In the other post it shows the Harland Sharp rockers with adjusters.. I dont know if TD has them or not.. would be worth a call EDIT here is the pic from the other post
[Re: SC304]
#1565867
01/21/14 09:16 AM
01/21/14 09:16 AM
Posts: 6,151 Melbourne , Australia
LA360
The T&D stuff will be pricey like the Jesel stuff. There was an article on dragzine.com or Enginelabs.com about them. They were around $2600 or there abouts
Alan Jones
[Re: Moparmal]
#1565873
01/22/14 05:05 PM
01/22/14 05:05 PM
Posts: 2,776 Ontario Canada
MattW
Ontario Canada
I agree!.... Lemme ask this....what rocker systems are the 9 sec LX cars like Red Baron running....and the 8 sec Drag Pak cars like Dave Barton......and are they breaking them?
I'll take a guess "STOCK"
What do I win if I'm right? Matt
[Re: MattW]
#1565874
01/22/14 07:08 PM
01/22/14 07:08 PM
Posts: 4,302 Nebraska
72Swinger
Nebraska
I would bet the really high rpm builds are using Jesel. Although the stockers have been known to be fine to 7800....
Mopar to the bone!!!
[Re: LA360]
#1565877
01/22/14 09:07 PM
01/22/14 09:07 PM
MattW
Ontario Canada
So here's a couple of questions. The reason for adjustable rockers is for a solid roller, right? Is it possible to use the factory rockers with a solid and set your lash with custom pushrods? Isn't the whole idea with super stock or any HP engine is lightweight parts? Rev quicker? I don't think any of the aftermarket would compare with the weight of stock rockers. Matt
[Re: SC304]
#1565881
01/22/14 09:49 PM
01/22/14 09:49 PM
72Swinger
Nebraska
Im curious what oiling setup will live at 8500+ ?
[Re: SC304]
#1565891
01/22/14 11:16 PM
01/22/14 11:16 PM
MattW
Ontario Canada
I run the Melling pump with filter on the block. No remote. All passages massaged. We run jesel lifters so bores are bushed. Oil thru trend pushrods. 6.1 crank treated
Have not experienced any oiling issues
Is your 6.1 a production crank? Matt
[Re: sixpackgut]
#1565895
01/23/14 05:45 PM
01/23/14 05:45 PM
Posts: 1,506 TN
SCATPACK 1
TN
Wow that is a lot of oil leakage on the exhaust side rockers.
Old Geezer Racing
[Re: MattW]
#1565897
01/23/14 07:13 PM
01/23/14 07:13 PM
Posts: 287 Michigan
SC304
[Re: SC304]
#1565901
01/24/14 09:24 AM
01/24/14 09:24 AM
Posts: 3,875 Smyrna, South Carolina
STEFF
The 6.1 crank has been just fine. At the time it's all that was available
The 426 is a Callie's piece cause it is a 4" stroke.
Molnar is supplying my new cranks for the next 6.1 builds.
Going back to dyno next week with some stiffer rocker shafts.
Mike
Mike, you trying out the Trend Shafts?
[Re: SC304]
#1565905
01/25/14 01:23 AM
01/25/14 01:23 AM
Posts: 833 MN
hemidup
MN
Are you using stock diameter rockershafts or a smaller diameter shaft with sleeves like HS?
Jerry Williams.
