What does this plug tell you #1565561
01/19/14 05:47 PM
01/19/14 05:47 PM
pacific northwest
Stroker Scamp Offline OP
pacific northwest
Here is a pic of my #8 plug, engine was started last month, not sure if you will be able to see in the pic but it almost looks like rust
Thoughts?
footbrake N/A SB 408 Scamp 10.10 @ 132 street/strip
73 Duster 340 street strip 12.79 @ 105
Re: What does this plug tell you [Re: Stroker Scamp] #1565562
01/19/14 06:18 PM
01/19/14 06:18 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Was it fired up with unleaded fuel... but its dog rich
E-85 will give it a yellow/gold color
Re: What does this plug tell you [Re: MR_P_BODY] #1565563
01/19/14 07:27 PM
01/19/14 07:27 PM
NW INDIANA
ta3834bbl Offline
ta3834bbl  Offline
NW INDIANA
Tells me that you are going to have a pretty bad miss , until you put it back in.
Ok seriously, I'm guessing that you have had some hi-humidity in the engine compartment and maybe that intake valve was open letting the wet mix in ???
What did the other plugs look like ?
67 Dart GT Convertible 273
68 Barracuda 383
68 Roadrunner 383 4spd
1 '01 Ram 2500 4x4 diesel
2 '02 Rams 1500 4x4's 4.7s
3 '03 Rams 2 1500's 4x4 and 1 2500 hemi 4x4
Oh, and a 03 Grand Cherokee and an '00 durango smile
Re: What does this plug tell you [Re: ta3834bbl] #1565564
01/20/14 10:30 PM
01/20/14 10:30 PM
pacific northwest
pacific northwest
all the other plugs look about the same color this one just had the rust like corrosion
I had a dominator on it and had it jetted at 86 squared so that's why I think I was fat
I was just a little worried about the moisture deal as it was the first time I have ever had this issue, might do a leak down just in case
VP C12 is in the tank
Re: What does this plug tell you [Re: Stroker Scamp] #1565565
01/20/14 11:09 PM
01/20/14 11:09 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Is that from idleing? If so, you need to work on the idle circuit plus a p/v is your friend..........
Re: What does this plug tell you [Re: Stroker Scamp] #1565566
01/20/14 11:22 PM
01/20/14 11:22 PM
MR_P_BODY Offline
MR_P_BODY  Offline
IF it was rust.. your engine is rusting to death
right before your eyes... no I doubt that... fuels
will a LOT of times leave a hue on the plugs... yours
might be because its dog fat.. I would suggest a PV
and jet down on the primaries to get it leaned out
Re: What does this plug tell you [Re: MR_P_BODY] #1565567
01/21/14 12:14 AM
01/21/14 12:14 AM
pacific northwest
pacific northwest
I have sent out my A/F meter to get looked at and I am going to put the 950 back on and most likely switch over to E85
And yes that was just ideling with a couple throttle whomps
Re: What does this plug tell you [Re: Stroker Scamp] #1565568
01/21/14 01:30 AM
01/21/14 01:30 AM
Monrovia, So-Cal, USA
racerhog Offline
racerhog  Offline
Wrong heat range plug.....
Bad Fuel.....
Turn the 4 corners in 1 turn each....
Bob(Cowboy)Hogan
Monrovia So-Cal
Re: What does this plug tell you [Re: Stroker Scamp] #1565569
01/21/14 01:35 AM
01/21/14 01:35 AM
Florida STAYcation
dOoC Online penguin-006
The village idiot's idiot
dOoC  Online Penguin-006
Florida STAYcation
That gives PIG FAT new meaning ... you could washing-the-rings leaving it like this ...
Re: What does this plug tell you [Re: dOoC] #1565570
01/21/14 01:58 AM
01/21/14 01:58 AM
SoCal
Brian Hafliger Offline
SoCal
Does the engine still smoke?
Brian Hafliger
Re: What does this plug tell you [Re: Brian Hafliger] #1565571
01/21/14 03:03 AM
01/21/14 03:03 AM
pacific northwest
pacific northwest
no smoke from the engine, but wanting to get this thing a bit more street friendly by loosing the dommy for now its a 3 circuit
Re: What does this plug tell you [Re: Stroker Scamp] #1565572
01/21/14 03:10 AM
01/21/14 03:10 AM
MR_P_BODY Offline
MR_P_BODY  Offline
You can go with the smaller carb or maybe you know
someone with a 8082 1050 to borrow OR change your 3
circuit over to a 2 circuit... I've never had a hard
time getting any of the 3 circuit doms to idle.. even
without a PV... mid is the problem point
