How Do You Calculate Cubic Inch ? #1565236
01/18/14 09:59 PM
01/18/14 09:59 PM
USA
K
krw71ragtop Offline OP
K
USA
I am having a 360 bored .030" with a 3.580" crank. What would be the cubic inch. I would like to know how to calculate the answer so I don't have to ask again. Thanks
Re: How Do You Calculate Cubic Inch ? [Re: krw71ragtop] #1565237
01/18/14 10:01 PM
01/18/14 10:01 PM
Western PA
O
OldMoparMan Offline
OldMoparMan  Offline
O
Western PA
Living with ALS help support the search for a cure
Thanks http://web.alsa.org/site/TR/Walks/WesternPennsylvania?team_id=347781&pg=team&fr_id=12069
Re: How Do You Calculate Cubic Inch ? [Re: OldMoparMan] #1565238
01/18/14 10:07 PM
01/18/14 10:07 PM
new berlin wisconsin
Mr T2U Online content
Mr T2U  Online Content
bore size X bore size X stroke X # of cylinders X .7854 = ci of motor
perception is 90% of reality
Re: How Do You Calculate Cubic Inch ? [Re: krw71ragtop] #1565239
01/18/14 10:07 PM
01/18/14 10:07 PM
bore X bore X stroke X .7854 (1/4 of Pi) X 8 (# of cyls)
Re: How Do You Calculate Cubic Inch ? [Re: RapidRobert] #1565240
01/18/14 10:43 PM
01/18/14 10:43 PM
USA
K
K
USA
My calculation is 365 ci . Am I close ?
Re: How Do You Calculate Cubic Inch ? [Re: krw71ragtop] #1565241
01/18/14 10:52 PM
01/18/14 10:52 PM
Kirkland, Washington
Pacnorthcuda Offline
PI R squared x stroke x number of cylinders.
Re: How Do You Calculate Cubic Inch ? [Re: krw71ragtop] #1565242
01/19/14 12:30 AM
01/19/14 12:30 AM
I would have sat next (or behind) you in school.
Re: How Do You Calculate Cubic Inch ? [Re: krw71ragtop] #1565243
01/19/14 12:35 AM
01/19/14 12:35 AM
Go to United Machine web site, KB web site and click on the claculator button and then click on the cubic inch calculator and put your numbers in and then hit calculate Thats the way I do it, or use Wallace racing calculators web site, lots of choices out there
Re: How Do You Calculate Cubic Inch ? [Re: Cab_Burge] #1565244
01/19/14 11:19 AM
01/19/14 11:19 AM
USA
K
K
USA
I got it. I have a How to Build Big Inch Mopar small blocks book, and it has a conversion chart on cubic inch displacement, but it's blank for the 4.030" bore and 3.580" stroke column. I find it odd that it didn't list the .030" bore but lists the .040" bore (which is 367 ci) and .060" which is 371 ci with the 3.580" stroke.
I did use the conversion calculator after I tried it the old fashion way, just to verify my answer.
Thanks for the replies.
