Re: T-56 and hydraulic clutch [Re: 1fastabody] #1563201
01/17/14 01:13 AM
01/17/14 01:13 AM
Lethbridge, AB, Canada
dangina Offline
dangina  Offline
Are you guys removing the return spring on the clutch pedal or using something different?
no spring because its now got the MC!
Interesting. You have your master mounted inside the firewall.
I wanted it on the inside to retain a more stock looking engine bay. And I didn't want to cut anymore holes through the firewall
Re: T-56 and hydraulic clutch [Re: dangina] #1563202
01/17/14 04:45 PM
01/17/14 04:45 PM
Texas, Dallas
G_T Offline OP
G_T  Offline OP
Texas, Dallas
Parts have been streaming in. Should have the Heim joint shortly - turns out it was 5/16"-24 in size. Gathering the parts vs buying a kit has been very easy and signficantly less $
Also picked up the 4 to 2 hole adaptor and heim/rod assembly for the master cylinder from Dr. Diff (Thanks Cass). VERY quick delivery.
1970 Charger - V10, 6spd, Alterkation, Street Lynx 4 Link, Moser Dana 60, Wilwood 14" disks, Forgeline 18" Wheels (Rear:335's), ISIS Multiplexing Wiring http://www.v10mopar.com 2012 Charger SRT8
Re: T-56 and hydraulic clutch [Re: G_T] #1563203
01/17/14 06:13 PM
01/17/14 06:13 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Glad to help someone save money!! I put in stops for my pedal just for insurance against tearing the seal from over travel. Just an FYI.
Mopar to the bone!!!
T-56 and hydraulic clutch [Re: 72Swinger] #1563204
02/10/14 08:07 PM
02/10/14 08:07 PM
Texas, Dallas
G_T Offline OP
G_T  Offline OP
Texas, Dallas
Well i finished the project a couple of weekends ago, thought I'd show the final results. I had to mock up both the brake and clutch - fought me the whole way. The end of the wilwood master is a tad too big in diamter for the 4-to-2 hole master cylinder adapter, requiring a little machining. Most of this is (or will be) grade-8 hardware or chromoly heim ends.
Thanks again everyone - especially 72swinger - you'll see some similarities i think
Re: T-56 and hydraulic clutch [Re: G_T] #1563205
02/10/14 08:08 PM
02/10/14 08:08 PM
Texas, Dallas
G_T Offline OP
G_T  Offline OP
Texas, Dallas
The back side... I have more pics, but this should suffice.
Re: T-56 and hydraulic clutch [Re: G_T] #1563206
02/10/14 08:14 PM
02/10/14 08:14 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
You might need to tighten the rubberband for the first drive though.
Re: T-56 and hydraulic clutch [Re: OzHemi] #1563207
02/10/14 10:47 PM
02/10/14 10:47 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Looks good! Don't forget to check clutch clearance, you want like .120 minimum.
Re: T-56 and hydraulic clutch [Re: 72Swinger] #1563208
02/11/14 09:35 PM
02/11/14 09:35 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Due you mean plate departure? IF so where did you come up with .120"? That's double what I use.
Don't be the exception.
Re: T-56 and hydraulic clutch [Re: Supercuda] #1563209
02/11/14 10:30 PM
02/11/14 10:30 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
No
Throwout bearing to pressure plate clearance. It gets less as the clutch wears. I believe in most cases .120-.250 is acceptable, and with a dual disc maybe more.
Re: T-56 and hydraulic clutch [Re: 72Swinger] #1563210
02/11/14 11:09 PM
02/11/14 11:09 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Ok, cause I was wondering.
Re: T-56 and hydraulic clutch [Re: Supercuda] #1563211
02/27/14 07:01 PM
02/27/14 07:01 PM
Wheatfield, NY
Cuda340 Offline
Cuda340  Offline
Wheatfield, NY
I used .060" clutch/disk clearance. I am not sure where I got that number from. I think an old Direct Connection book.
