Harms/Scott, thanks a lot: Hemi carbs.
#1562895
01/13/14 10:09 PM
01/13/14 10:09 PM
Posts: 8,828 Houston, Tx
hemi68charger
Houston, Tx
Hey gang..
Just wanted to pass along some of the items I got from Scott at Harms Auto... I can't wait to fire up this puppy when I put her in the Daytona. The carbs look great and I really dig the carb tags I got today from him...
Thanks Scott..
PS: Scott, notice something else?
TroyHouston Mopar Connection Club'69 Charger Daytona 440 - auto - 4.10 Dana (now with 426 hemi) '69 Charger 500 440 - 4speed - 3.54 Dana '70 Road Runner 383 - 4speed - a/c (now with 440)
Re: Harms/Scott, thanks a lot: Hemi carbs.
[Re: MLR426]
#1562900
01/14/14 09:33 AM
01/14/14 09:33 AM
hemi68charger
Houston, Tx
When you mount the carbs slide them back to hit the studs on both that way if you take them off you know the placement they were in when you removed them. After mounting open both carbs, check for FREE movement of the throttle plates. Also remember to paint those bolt heads
MLR426
Good tip. Regarding the intake bolts, I am waiting on getting the proper water pump housing. Once I find one, I will button everything up, to include attachment of the negative battery and body ground cables, then paint. As Scott has pointed out, I also need to get the proper valve cover hardware... Things are just mocked up now to verify fit.
