1970 440 Warranty Block???? #1562881
01/13/14 10:02 PM
01/13/14 10:02 PM
Wisconsin
Stewpar Offline OP
Stewpar  Offline OP
Wisconsin
What if anything were stamped into these blocks. The one in question has 2 0 2 stamped into the upper pad and nothing on the VIN rail area. Cast 1-14-70 and casting number of 2536430-6. Any help would be appreciated, thank you.
Admiration For Multiple Carburetor Vehicles...
Re: 1970 440 Warranty Block???? [Re: Stewpar] #1562882
01/16/14 01:32 AM
01/16/14 01:32 AM
Kansas 67208
8
8_Barrel Offline
super gas
8_Barrel  Offline
super gas
8
Kansas 67208
IIRC S440 was gang stamped by the factory on some warranty replacement blocks (usually short blocks); replacements became so frequent that it necessitated dealers using 'regular' over the counter blocks authorized by the factory, the dealer was supposed to stamp the block, few did. By the time 1970 rolled around, I believe warranties were only 12 & 12. There wasn't any odo requirements and odo's were 'spun' and an over the counter block was purchased and installed.
It seems to me that in the distant past we had a block that had 2 0 2 stamped on the pad. What it might reference can only be surmised IMO, as the possibilities are numerous.
Additionally, industrial 440's did not always have a stamping on the pad and obviously did not have a VIN.
If you "Ain't Skeered" or have "No Fear", it's 'cause you ain't goin' FAST enough!!
Re: 1970 440 Warranty Block???? [Re: 8_Barrel] #1562883
01/16/14 02:09 AM
01/16/14 02:09 AM
NB, Canada
moparfan53 Offline
moparfan53  Offline
NB, Canada
IIRC S440 was gang stamped by the factory on some warranty replacement blocks (usually short blocks)...
Here is an "S 440" stamping on a replacement/warranty engine in a '69 Charger R/T. I have read that the "S" is for "service". There is no vin on the pad. I don't know if it was a short block or long block installed.
Re: 1970 440 Warranty Block???? [Re: moparfan53] #1562884
01/17/14 05:58 AM
01/17/14 05:58 AM
Keminmaa
ArcticCuda Offline
ArcticCuda  Offline
Keminmaa
Mine 1969. Vinpad is empty.
1970 Plymouth GTX 440-6
1970 Plymouth PPR Cuda 489-4
1971 Plymouth Duster Bad Romance 408-W2-8bbl
