Car Doesn't Turn Over - 318 w/ Mini Starter #1562345
01/12/14 08:59 PM
01/12/14 08:59 PM
Tucson, AZ
73ChargerSE Offline OP
Tucson, AZ
Hey guys,
Working on my '72 Dart with a 318. Had the car running with the original starter. Shut the car off to see if it'll start again. Click. Nothing. The click was coming from the starter, so I figured it was the starter giving me problems. I changed the starter in favor for a mini starter and went to start the car. Same click. Jumped the lugs on the starter, still nothing. However when I jumped the lugs AND the relay, the car turned over. What could be going on with this? Bad ground? Bad battery cable? Any help is appreciated.
Thanks!
Paul
Re: Car Doesn't Turn Over - 318 w/ Mini Starter [Re: 73ChargerSE] #1562346
01/12/14 09:04 PM
01/12/14 09:04 PM
McGregor,Iowa 52157
500ciDuster Offline
500ciDuster  Offline
McGregor,Iowa 52157
Check the big wire for 12 volts at the starter and make sure it's getting a good connection at both ends
Re: Car Doesn't Turn Over - 318 w/ Mini Starter [Re: 500ciDuster] #1562347
01/12/14 09:38 PM
01/12/14 09:38 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Make sure that you have a good ground system. Clean battery terminals and cable clamps.
Re: Car Doesn't Turn Over - 318 w/ Mini Starter [Re: 73ChargerSE] #1562348
01/12/14 09:54 PM
01/12/14 09:54 PM
Your ground path is Ok cuz all your manipulatin has been on the power side. The symptoms ain't adding up cuz jumping the 2 lugs on the starter is the same as jumping the 2 lugs on the starter relay (assuming the small "solenoid" wire from relay to starter has continuity. I'd clean the ring terminals on the 2 big wires on the large "batt" terminal & that threaded stud on the starter relay and check/clean the smaller solenoid wire/terminal at the relay. Starter is good/the batt is charged, just a loose/poor connection in that circuit
