How do you remove cheap auto parts store window tint?? #1562016
01/11/14 09:38 PM
01/11/14 09:38 PM
N.W. INDIANA
moparjohn Offline OP
N.W. INDIANA
I have a very nice 68 69 70 style Charger back glass. The problem is it's covered with cheap auto store window tint. I don't want to try and scrape it off with a razor blade. This would be time consuming plus I could scratch the glass! Does any one out there have good results on removing this stuff?
Thanks!
Re: How do you remove cheap auto parts store window tint?? [Re: moparjohn] #1562017
01/11/14 11:07 PM
01/11/14 11:07 PM
Sunny South Florida
Golden-Arm Offline
Golden-Arm  Offline
Sunny South Florida
ammonia, and a razor blade. the safety kind, and work slowly. that's how the tint shops remove it, before re-tinting. spray it with a spray bottle, let is sit for a few minutes, and try peeling an edge. the razor is just used to "encourage" the tint to lift. cover anything you don't want wet, with old towels, and do small sections at a time.
Re: How do you remove cheap auto parts store window tint?? [Re: Golden-Arm] #1562018
01/11/14 11:18 PM
01/11/14 11:18 PM
Kirkland, Washington
Pacnorthcuda Offline
Actually, I had the FACTORY tint removed on my daughters rear window (with delicate defroster) and its pretty cool
Park car in the sun (warmer the better), spray ammonia based window cleaner on the glass, cover with plastic, pre-cut to the shape of the window, use black plastic if the sun is being used to warm. This ensures that the tint film remains wet.Let sit for about 20 minutes. The tint film will wipe right off.
Re: How do you remove cheap auto parts store window tint?? [Re: Pacnorthcuda] #1562019
01/11/14 11:39 PM
01/11/14 11:39 PM
Shingle Springs Ca
haddixj Offline
haddixj  Offline
Shingle Springs Ca
steam works great, you can peel it off in whole sheets
70 duster 25.1E,73 barracuda, 70 gran coupe, 71 cuda
Re: How do you remove cheap auto parts store window tint?? [Re: moparjohn] #1562020
01/11/14 11:54 PM
01/11/14 11:54 PM
central new york
pettyblue440 Offline
central new york
3m adhesive remover and a razor
Re: How do you remove cheap auto parts store window tint?? [Re: pettyblue440] #1562021
01/12/14 12:30 PM
01/12/14 12:30 PM
Back In Iowa
belv2vert66 Offline
belv2vert66  Offline
Back In Iowa
Youtube it.....lot's of info there using a wall paper steamer. I have done it with a razor on my 66 Dart and paid a tint shop 100 bucks to do my son's stratus. All I am gonna say is that it was the best 100 I ever spent. lol. I have no idea how they did it tho.
Re: How do you remove cheap auto parts store window tint?? [Re: belv2vert66] #1562022
01/12/14 01:26 PM
01/12/14 01:26 PM
Oakdale, MN
W
weazel Offline
weazel  Offline
W
Oakdale, MN
I have personally used one of those clothing steamers. Works great!
Re: How do you remove cheap auto parts store window tint?? [Re: weazel] #1562023
01/12/14 11:03 PM
01/12/14 11:03 PM
N.W. INDIANA
N.W. INDIANA
Thanks for the replies to my question!
I had a weeks vacation this week and that tinted Charger back glass was on the radar. This afternoon I started on this with the best of what I had here. I used a safety razor blade and some amonia based cleaner. It didn't start out well and the attached picture was after an hour of work!
Re: How do you remove cheap auto parts store window tint?? [Re: moparjohn] #1562024
01/12/14 11:09 PM
01/12/14 11:09 PM
N.W. INDIANA
N.W. INDIANA
I took a break and took my wife out for supper. When we returned I started out with a brand new razor blade! Things went better and as I developed some technique the blade started to dull. After another 45 minutes all the tint was off! So an hour an 45 minutes to do this glass. On the positive side it's done and I found a Chrysler logo and date code on it! I had thought it was an aftermarket piece. Another positive was that the tint protected the glass and it's inpretty good shape!
Thanks!
Re: How do you remove cheap auto parts store window tint?? [Re: moparjohn] #1562025
01/12/14 11:10 PM
01/12/14 11:10 PM
renton, Washington
ph23vo Offline
ph23vo  Offline
renton, Washington
just PULL IT OFF...mine came right off
Re: How do you remove cheap auto parts store window tint?? [Re: moparjohn] #1562026
01/13/14 01:44 PM
01/13/14 01:44 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
I know not everyone has one, but this is another job that a heated pressure washer would have done the job in less than 5 minutes.
Everyone should have one, I use mine almost everyday for many things.
Re: How do you remove cheap auto parts store window tint?? [Re: moparjohn] #1562027
01/13/14 02:47 PM
01/13/14 02:47 PM
Phoenix - surface of the sun
nomore65BelvJim Offline
If the glass is off the vehicle just put it in a big plastic bag and toss in a rag soaked in ammonia.
Not an ammonia based cleaner, ammonia.
Close the bag and let it sit for maybe a couple hours. Open the bag and the film should pretty much just lift right off.
I've done it that way several times and it always worked quite well. The fumes do the hard work.
If the glass is still installed I've taped plastic to the edges of the area to sort of seal it. Put the ammonia soaked rag inside.
