Original Finish on Assy Line ' 70-1 4 Speed Shift Mech #1558433
01/04/14 12:08 AM
01/04/14 12:08 AM
Land of 10,000 Lakes
44D6PAKCUDA Offline OP
What is the correct factory/assy line finish/plating on 1970-1 4 speed shifter mechanisms?I've seen NOS ones both silver-clear zinc and also phosphate.Thanks for any help.
Re: Original Finish on Assy Line ' 70-1 4 Speed Shift Mech [Re: 44D6PAKCUDA] #1558434
01/04/14 03:16 PM
01/04/14 03:16 PM
California
1970mopar Offline
1970mopar  Offline
California
Jim,
I believe it was actually a parkerize finish, but manganese phosphate is close.
fwiw my NOS set is actually a grey phosphate
I've never seen zinc on original 4spd rods (69-71)
Edited, i went back and re-read your question. I had thought you were asking about the rods. not the shifter mech itself. I answered about the , rods.
Shifter mechs are zinc plated as shown in examples below.
Re: Original Finish on Assy Line ' 70-1 4 Speed Shift Mech [Re: 44D6PAKCUDA] #1558435
01/04/14 05:24 PM
01/04/14 05:24 PM
MD
floyd Offline
floyd  Offline
MD
Great question. I have an NOS one that looks like silver-clear zinc. I'll post some pics in a bit. A member posted a pic of his NOS one a while ago and it looked dark. Is that what parkerized looks like? I'll see if I can find that post....
I believe Moparts member ID "xs29j8" is the one who had the darker NOS shifter but I can't find the post. Maybe he will chime in.
Re: Original Finish on Assy Line ' 70-1 4 Speed Shift Mech [Re: floyd] #1558436
01/04/14 06:20 PM
01/04/14 06:20 PM
california
Mr D21 Offline
Mr D21  Offline
california
Both my NOS and the one restored by Jules is dark (phosphate color) finish - but I think your correct that Parkerized is the correct term for it.
Re: Original Finish on Assy Line ' 70-1 4 Speed Shift Mech [Re: floyd] #1558437
01/04/14 07:14 PM
01/04/14 07:14 PM
MD
floyd Offline
floyd  Offline
MD
Box appears to have a date on it 126th day of 1969
Re: Original Finish on Assy Line ' 70-1 4 Speed Shift Mech [Re: floyd] #1558438
01/04/14 07:18 PM
01/04/14 07:18 PM
MD
floyd Offline
floyd  Offline
MD
What's the correct part number for a 70-71 E-body shifter mechanism BTW?
Re: Original Finish on Assy Line ' 70-1 4 Speed Shift Mech [Re: floyd] #1558439
01/04/14 07:21 PM
01/04/14 07:21 PM
There would be 2 different numbers as the '70 had the slip in style and '71 was bolt in handle
Re: Original Finish on Assy Line ' 70-1 4 Speed Shift Mech [Re: 44D6PAKCUDA] #1558440
01/04/14 07:23 PM
01/04/14 07:23 PM
MD
floyd Offline
floyd  Offline
MD
Jim - I'm no expert, but both my 71's came with the slip-in style shifter (one early build and one built in May 71). I'm not sure when they switched over to the bolt in.
Re: Original Finish on Assy Line ' 70-1 4 Speed Shift Mech [Re: 44D6PAKCUDA] #1558441
01/04/14 07:24 PM
01/04/14 07:24 PM
california
Mr D21 Offline
Mr D21  Offline
california
Floyd - the silver zinc look is what happens after all the original plating wears / rubs off...
Re: Original Finish on Assy Line ' 70-1 4 Speed Shift Mech [Re: Mr D21] #1558442
01/04/14 07:32 PM
01/04/14 07:32 PM
MD
floyd Offline
floyd  Offline
MD
Bryon - I bought this a few years ago and have no idea how it was stored, but it appears to have spent its life in the box. Its hard to imagine the darker finish wearing off so evenly?
Re: Original Finish on Assy Line ' 70-1 4 Speed Shift Mech [Re: floyd] #1558443
01/04/14 08:24 PM
01/04/14 08:24 PM
california
Mr D21 Offline
Mr D21  Offline
california
someone may have attempted to clean it and sprayed carb or brake cleaner on it - that would give you the look yours has...
Re: Original Finish on Assy Line ' 70-1 4 Speed Shift Mech [Re: Mr D21] #1558444
01/04/14 08:54 PM
01/04/14 08:54 PM
mopar346 Offline
Let me tell ya about fat chicks!
mopar346  Offline
Not NOS but relatively low mileage original just cleaned up, assembly is tight.
Careful, your character's showing!
Re: Original Finish on Assy Line ' 70-1 4 Speed Shift Mech [Re: mopar346] #1558445
01/04/14 09:35 PM
01/04/14 09:35 PM
Ontario, Canada
mccannix Online content
mccannix  Online Content
Ontario, Canada
...again "NOS" verses "assembly line" raises its' ugly head.
I have seen them both ways in NOS as Jim explains.
Years ago I had a case of 12 NOS and they were perfect phosphate.
Some singles I have seen in NOS are like Floyds
Re: Original Finish on Assy Line ' 70-1 4 Speed Shift Mech [Re: mccannix] #1558446
01/04/14 09:41 PM
01/04/14 09:41 PM
Sacramento,California
JRepucci Offline
JRepucci  Offline
Another example. Original box rebuilt by Hurst. Rods and levers done by Pete's Restoration here in California.
Re: Original Finish on Assy Line ' 70-1 4 Speed Shift Mech [Re: floyd] #1558447
01/04/14 10:50 PM
01/04/14 10:50 PM
I always thought they switched them over in '71 to the bolt in style because of the '70 slip in style "loosening" up.Once again,you never know.
Re: Original Finish on Assy Line ' 70-1 4 Speed Shift Mech [Re: 44D6PAKCUDA] #1558448
01/04/14 10:59 PM
01/04/14 10:59 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
They built quite a few 71's with the 70 style slip in shifter. I have 2 used 70 style shifters here and they were clearly silver like the example on Jason's trans above. That said I would rule out black as a production possibility
Re: Original Finish on Assy Line ' 70-1 4 Speed Shift Mech [Re: ScottSmith_Harms] #1558449
01/04/14 11:16 PM
01/04/14 11:16 PM
mopar346 Offline
mopar346  Offline
Not that it has any bearing but weren't aftermarket Hurst Comp Plus shifters black phosphate or appeared that way?
Re: Original Finish on Assy Line ' 70-1 4 Speed Shift Mech [Re: mopar346] #1558450
01/04/14 11:52 PM
01/04/14 11:52 PM
Toronto (YYZ) Ontario
YYZ Offline
YYZ  Offline
FWIW of the '71s I've owned, the bayonet or push-in style shifter was used into Dec '70 of production
Re: Original Finish on Assy Line ' 70-1 4 Speed Shift Mech [Re: mccannix] #1558451
01/05/14 01:54 AM
01/05/14 01:54 AM
Chicago Blackhawks
hemicar1971 Offline
hemicar1971  Offline
Chicago Blackhawks
Still have one of those shifter mech that I bought of Mccannix maybe 20 years ago or more. Not sure if it is from the same box of shifters you are talking about. I will see if I can dig out all my shifters used and new and take some pictures of them since I do not run a factory shifter in the Challenger they are all sitting on the shelf in the basement the last time I looked a few years ago.
1971 HEMI E BODY REGISTRY
Re: Original Finish on Assy Line ' 70-1 4 Speed Shift Mech [Re: 44D6PAKCUDA] #1558452
01/05/14 03:18 AM
01/05/14 03:18 AM
JRepucci Offline
JRepucci  Offline
original finish... B body mech.
