Indy R2 and R3 Cams #1557528
01/01/14 10:37 PM
01/01/14 10:37 PM
Kokomo, IN
540dust Offline OP
540dust  Offline OP
Kokomo, IN
Anybody here running them? What springs/setup are you using? Thoughts and comments on either? Thanks
Re: Indy R2 and R3 Cams [Re: 540dust] #1557529
01/02/14 06:13 AM
01/02/14 06:13 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
i was running their R1 cam. got down to 9.4 but it had harmonics. a cam grinder fixed it & it runs perfect now. it was a real consistant winner for me. i have a Bullet cam now thats similar to R2 with a little less lift.
Re: Indy R2 and R3 Cams [Re: rebel] #1557530
01/03/14 03:20 PM
01/03/14 03:20 PM
Alberta, Canada
451Guy Offline
451Guy  Offline
Alberta, Canada
Harmonics ???
Thanx 451 Guy
512 cu in 71 Demon Super Street Car - NO LONGER - Broke Crank
Best ET 9.57 @ 139.96
451 cu in Pump Gas - 71 Demon Super Street Car
Best ET 9.99 @ 136.80
512 cu in 69 Charger R/T
Best ET 11.39 @ 118.11
Re: Indy R2 and R3 Cams [Re: 451Guy] #1557531
01/03/14 04:44 PM
01/03/14 04:44 PM
aotearoa
rebel Offline
rebel  Offline
aotearoa
yes, we were constantly experiancing bolts coming loose & then 1 day we broke a pushrod which knocked the lifter bar off causing the roller to turn. it left a small mark on the lobe so i sent it to the cam man to fix. he told me there's some harmonics with this grind & he could fix it & remove the mark at the same time. he did the job & we no longer have nuts n bolts coming loose on the engine. go figure.
Re: Indy R2 and R3 Cams [Re: rebel] #1557532
01/04/14 03:50 AM
01/04/14 03:50 AM
Central Ohio, USA
Bigbeep Offline
Bigbeep  Offline
Central Ohio, USA
I currently am running the R2 with a set of K Motion springs. Running the red zone lifters, 1.6 HS rockers and Smith brothers push rods. Time for a check up as the springs are 4 years old this coming spring. Checked at 2 years when heads were freshened and all was good. Car sees 7200 shift and at the stripe. Has been 7600 a few times with no issues just wasn't any quicker. Current set up is in a .055" 440 but plan on using the cam in future build with a larger CI. Beep
Re: Indy R2 and R3 Cams [Re: 540dust] #1557533
01/04/14 08:23 AM
01/04/14 08:23 AM
E
EJ440 Offline
EJ440  Offline
E
What are the specs on those cams ?
Re: Indy R2 and R3 Cams [Re: EJ440] #1557534
01/04/14 03:16 PM
01/04/14 03:16 PM
Kokomo, IN
540dust Offline OP
540dust  Offline OP
Kokomo, IN
The R2 is .682 valve lift w/1.5 rocker, 284 288 @ 0.050. 108.
Re: Indy R2 and R3 Cams [Re: 540dust] #1557535
01/05/14 04:02 AM
01/05/14 04:02 AM
PA
O
Ody1003 Offline
Ody1003  Offline
O
PA
if you need any info on the r2/r3 cams get ahold of me via private messgae.
i will point you in the right direction and might even be able to hook you up with a cam.
Tim
Re: Indy R2 and R3 Cams [Re: Ody1003] #1557536
01/20/15 06:48 PM
01/20/15 06:48 PM
South Florida
indcontrols Offline
indcontrols  Offline
South Florida
I think I'm getting ready to try the R2 - with Jesel 1.7's - looks like the hot ticket.
Re: Indy R2 and R3 Cams [Re: indcontrols] #1557537
01/20/15 07:07 PM
01/20/15 07:07 PM
Huntsville, AL
Airwoofer Offline
Airwoofer  Offline
Huntsville, AL
So is the R2 cam any good? I have one in my 540 with 14-1 CR and 440-1 heads that flow 370 (ex is 85% of intake) with the 1.6 HS rockers. About to put the engine in the Demon. Gonna use stepped proparts headers and 3 1/2" ex through mufflers. Street car...
Re: Indy R2 and R3 Cams [Re: Airwoofer] #1557538
01/21/15 11:55 PM
01/21/15 11:55 PM
Kokomo, IN
540dust Offline OP
540dust  Offline OP
Kokomo, IN
I ran the R2 last year after running the Comp .650 324 solid for years. I use 1.5 single shaft T&D 1.55 PACs and Smith Bros pushrods. 304 lbs seat and about 740 open. As far as et the difference was in hundredths (not much) and most of the difference was in mid range making it slightly more difficult to dial, not good, but with some timing curve adjustments it seems to make a very robust and consistent bracket motor setup, Im sticking with it. This may or may not be what your looking for depending on what you want but this is my experience with the cam in my now 533 cubic inch low deck motor, btw I put it in at 108 cl, I had to give it a little more intake valve clearance too as the R2 reduced clearance slightly.
Re: Indy R2 and R3 Cams [Re: 540dust] #1557539
01/22/15 01:15 AM
01/22/15 01:15 AM
ky
68roadrunner Offline
ky
i have run the r2 alot in my 499, the kmotion spings jndy sold me was a joke, after going to the pac spring all is good now, run it with hs 1.5 rockers
i tried a couple other cams that was close to this one, but this was the quickest.
