Poor Headlights... #1557220
01/01/14 06:59 AM
01/01/14 06:59 AM
PORT ALBERNI , BC., CANADA
superwrench Offline OP
2007 Ram 3500....headlights suck!! I was reading somewhere before about a harness (wiring) kit that beefs up the gauge of wiring that Chrysler used so that the lamps get more juice.
Anyone got some info on this??
Gotta remember to start bookmarking this stuff!!!
Re: Poor Headlights... [Re: superwrench] #1557221
01/01/14 10:51 AM
01/01/14 10:51 AM
Greenville, PA
redraptor Offline
redraptor  Offline
Greenville, PA
Lights on my '02 suck unless you hold the dimmer switch so HI&LO are both on!
A wiring kit won't help unless you already have some sort of grounding issue.
Need to upgrade to aftermarket bulbs or assemblies. I would if I drove more at night.
Re: Poor Headlights... [Re: redraptor] #1557222
01/01/14 03:53 PM
01/01/14 03:53 PM
Yes....I could change out to PIAA bulbs or something, but I did read something about a "kit" or at least "Instructions" on how to change up to heavier wiring coming from the TIPM. Makes sense because the wires are sure puny....
Re: Poor Headlights... [Re: superwrench] #1557223
01/01/14 04:00 PM
01/01/14 04:00 PM
Littleton Colo
Geezer Offline
Geezer  Offline
Littleton Colo
Re: Poor Headlights... [Re: Geezer] #1557224
01/01/14 04:49 PM
01/01/14 04:49 PM
Grand Prairie,Texas
stumpy Online content
stumpy  Online Content
Grand Prairie,Texas
Sylvania silver stars are a bright bulb and not that expensive. I doubt you will gain much trying to rewire a newer vehicle. I think the wiring upgrade works best on older stuff.
Re: Poor Headlights... [Re: stumpy] #1557225
01/01/14 04:58 PM
01/01/14 04:58 PM
East Texas
Mopar2DBone Offline
Mopar2DBone  Offline
East Texas
Watching closely... Lights on my 04 are equivalent to a mopad..
Re: Poor Headlights... [Re: superwrench] #1557226
01/01/14 05:15 PM
01/01/14 05:15 PM
Graham, WA
P
Polarapete Offline
Polarapete  Offline
P
Graham, WA
When I had my 2002 Ram I belonged to the Turbo Diesel Register and I used to get catalogs from Geno's Garage. I remember there were kits listed there to convert to relays for the headlamps. Check it out.
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction
1998 Ram 2500 QuadCab, new daily driver.
2008 Honda Element
2014 Carry-On 7x14 Cargo Trailer
Re: Poor Headlights... [Re: superwrench] #1557227
01/01/14 10:03 PM
01/01/14 10:03 PM
Alberta
rustbuckett68 Offline
Alberta
See if you can check the voltage at the lights when at idle, then check the battery and/or alternator to see if there is any voltage drop. With relays and larger wiring I gained about a volt and a half in my '79 van, and over 2 1/4 volts in my '84 GMC.
Re: Poor Headlights... [Re: rustbuckett68] #1557228
01/02/14 01:16 AM
01/02/14 01:16 AM
Lehigh Acres, Florida
rickstershemi Offline
Installed HID's in my 04 and never looked back.....Amazing
