head bolts #1556873
12/31/13 04:46 PM
12/31/13 04:46 PM
GoDartGo Offline OP
GoDartGo  Offline OP
what's the most they can be reused?
Re: head bolts [Re: GoDartGo] #1556874
12/31/13 05:40 PM
12/31/13 05:40 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Depends on what application you are talking about.
old school, indefinitely for mild to stock applications.
Newer TTY (torque to yield) once, officially. I've reused them in stock applications after inspecting to ensure the threads were not stretched.
http://freeasestudyguides.com/a1_4.html
Don't be the exception.
Re: head bolts [Re: GoDartGo] #1556875
12/31/13 07:48 PM
12/31/13 07:48 PM
Space Station #5
471Magnum Offline
471Magnum  Offline
Space Station #5
Just know that stock replacement head bolts are pretty inexpensive (like 40 bucks from Rock Auto). If you're building a new motor, I wouldn't skimp.
That being said, if it's not a torque to yield application, and they visually check out with no damage that would create a stress riser, you should be fine re-using them. Just thoroughly clean the threads and lube properly to get the correct torque reading.
Edit: Just checked Rock Auto. The no longer list LA bolts, but they've got Magnum-type (23 bucks).
-Jim
I can fix it... my old man is a television repairman.
He's got the ultimate set of tools... I can fix it.
Currently Mopar-less
Re: head bolts [Re: 471Magnum] #1556876
12/31/13 08:10 PM
12/31/13 08:10 PM
GoDartGo Offline OP
GoDartGo  Offline OP
couldn't find them on Rock Auto, but found them at NAPA
on line to my house $34.
forgot to ad it's a Magnum headed LA.
didn't want to press my luck, this would have been
the fourth time for this set of bolts, 9.5-1, 480ish
cam, 3:91's out back and beat on like a hillbilly mule
Re: head bolts [Re: GoDartGo] #1556877
12/31/13 11:22 PM
12/31/13 11:22 PM
Cab_Burge Online work
Cab_Burge  Online Work
I reuse the stock head and main bolts until they won't toruqe properly anymore You can feel them start to fail, if you recognize the signs
Re: head bolts [Re: Cab_Burge] #1556878
12/31/13 11:47 PM
12/31/13 11:47 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
I think Magnums are TTY bolts and they are different lengths than an LA.
How I inspect TTY bolts is to lay a straight edge on the threads, if any do not all touch they get replaced.
Re: head bolts [Re: Supercuda] #1556879
01/01/14 12:20 AM
01/01/14 12:20 AM
Space Station #5
471Magnum Offline
471Magnum  Offline
Space Station #5
Magnums are not TTY, but they are different lengths than LA.
-Jim
Re: head bolts [Re: 471Magnum] #1556880
01/01/14 04:45 AM
01/01/14 04:45 AM
GoDartGo Offline OP
GoDartGo  Offline OP
I've always used new motor oil, is there something
else I should be using?
Re: head bolts [Re: GoDartGo] #1556881
01/01/14 07:51 AM
01/01/14 07:51 AM
State of retirement
52savoy Offline
52savoy  Offline
State of retirement
Re: head bolts [Re: GoDartGo] #1556882
01/01/14 10:11 AM
01/01/14 10:11 AM
South-Central (Sebring), FL
Commando1 Offline
Commando1  Offline
And it worked, right?
Keep using it.
Re: head bolts [Re: 471Magnum] #1556883
01/01/14 11:12 AM
01/01/14 11:12 AM
indiana
mcmopars Offline
mcmopars  Offline
indiana
intakes are,i would have assumed heads would have been too
Re: head bolts [Re: Commando1] #1556884
01/01/14 04:59 PM
01/01/14 04:59 PM
GoDartGo Offline OP
GoDartGo  Offline OP
Keep using it.
must be, I've never lost a head gasket yet!
Re: head bolts [Re: GoDartGo] #1556885
01/02/14 03:00 AM
01/02/14 03:00 AM
If the threads look good I clean em with a brush then dip the threads in 30 wt eng oil then blow the threads off good with shop air. A drop of oil under the bolt head when going together
