Re: NEED PICS OV VERTICALLY MOUNTED SHOCKS.................
[Re: 1967dartgt]
#1555783
02/25/14 11:26 PM
02/25/14 11:26 PM
Posts: 1,563 Janesville, WI
SpareParts
Janesville, WI
I gotta learn to post pics, I made some really simple brackets for mounting my shocks in front of the axle, they bolt to the frame and I didn't have to run a tube across. (my car is nicely painted underneath so I try to avoid cutting/welding where I can) and the only class I'd run around me doesn't allow an ARB
With how stiff these shocks are valved we felt it was need to run a bar across. You really need to control the extension on drag radial car.
No doubt, I made a wide plate to mount to the frame and spread any load out. One year of street and track time, no issues yet.
[Re: SpareParts]
#1555784
02/26/14 12:32 AM
02/26/14 12:32 AM
Posts: 12,593 Great Neck,LI,new york
hemi-itis
I see most of the vertical's are coil overs on bar cars. What's the advantage of vertical's without coil overs and Cal Trac's??
[Re: Thumperdart]
#1555789
02/26/14 07:19 PM
02/26/14 07:19 PM
Posts: 1,058 bigfork mn
dragram440
bigfork mn
I really need to make a new upper shock mount for mine since my back brace is denting my shocks in and also I have cheap shocks and my car has a rediculous amount of rear lift. From what I am reading that is from my cheapo shocks. What is a good affordable shock that works decent on a leaf spring b body. My car doesnt run 9's but its heavy as hell and my 8 3/4 has over 100 passes on it now.
67' charger 499 RB
10.57 at 127
[Re: dragram440]
#1555792
02/27/14 03:38 PM
02/27/14 03:38 PM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
Really depends on what springs you have. The ride height can change a lot from car to car. Best to measure extended length and length with weight on car.
Brett Miller W9 cnc'd heads STR Chassis fabraction
