Page 4 of 8 1 2 3 4 5 6 7 8
Re: NEED PICS OV VERTICALLY MOUNTED SHOCKS................. [Re: 1967dartgt] #1555781
02/25/14 10:54 PM
02/25/14 10:54 PM
Janesville, WI
SpareParts Offline
SpareParts  Offline
Janesville, WI
I gotta learn to post pics, I made some really simple brackets for mounting my shocks in front of the axle, they bolt to the frame and I didn't have to run a tube across. (my car is nicely painted underneath so I try to avoid cutting/welding where I can)
and the only class I'd run around me doesn't allow an ARB
Re: NEED PICS OV VERTICALLY MOUNTED SHOCKS................. [Re: SpareParts] #1555782
02/25/14 11:02 PM
02/25/14 11:02 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
With how stiff these shocks are valved we felt it was need to run a bar across. You really need to control the extension on drag radial car.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: NEED PICS OV VERTICALLY MOUNTED SHOCKS................. [Re: 1967dartgt] #1555783
02/25/14 11:26 PM
02/25/14 11:26 PM
Janesville, WI
SpareParts Offline
SpareParts  Offline
Janesville, WI
No doubt, I made a wide plate to mount to the frame and spread any load out. One year of street and track time, no issues yet.
Re: NEED PICS OV VERTICALLY MOUNTED SHOCKS................. [Re: SpareParts] #1555784
02/26/14 12:32 AM
02/26/14 12:32 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
I see most of the vertical's are coil overs on bar cars.
What's the advantage of vertical's without coil overs and Cal Trac's??
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: NEED PICS OV VERTICALLY MOUNTED SHOCKS................. [Re: hemi-itis] #1555785
02/26/14 01:06 AM
02/26/14 01:06 AM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
It is easier for the shock to control your spring straight up and down. In a drag car that is key to be able to control what your spring is doing.
Re: NEED PICS OV VERTICALLY MOUNTED SHOCKS................. [Re: 1967dartgt] #1555786
02/26/14 02:01 AM
02/26/14 02:01 AM
State of confusion
Thumperdart Offline OP
State of confusion
I`d have to agree although only on the street at this point............
Re: NEED PICS OV VERTICALLY MOUNTED SHOCKS................. [Re: Thumperdart] #1555787
02/26/14 03:01 PM
02/26/14 03:01 PM
South Lyon, Michigan
6bblRoadrunner Offline
Thumper...I remember you posting about this a while ago. Been thinking of doing this to my Demon. Do you have any pictures?
Re: NEED PICS OV VERTICALLY MOUNTED SHOCKS................. [Re: 6bblRoadrunner] #1555788
02/26/14 03:09 PM
02/26/14 03:09 PM
State of confusion
State of confusion
Pics of the shocks? If so, not yet but will soon.............
Re: NEED PICS OV VERTICALLY MOUNTED SHOCKS................. [Re: Thumperdart] #1555789
02/26/14 07:19 PM
02/26/14 07:19 PM
bigfork mn
dragram440 Offline
dragram440  Offline
bigfork mn
I really need to make a new upper shock mount for mine since my back brace is denting my shocks in and also I have cheap shocks and my car has a rediculous amount of rear lift. From what I am reading that is from my cheapo shocks. What is a good affordable shock that works decent on a leaf spring b body. My car doesnt run 9's but its heavy as hell and my 8 3/4 has over 100 passes on it now.
67' charger 499 RB 10.57 at 127
Re: NEED PICS OV VERTICALLY MOUNTED SHOCKS................. [Re: dragram440] #1555790
02/26/14 08:24 PM
02/26/14 08:24 PM
MR_P_BODY Offline
MR_P_BODY  Offline
The minimum I'd buy would be the Rancho 9 way
Re: NEED PICS OV VERTICALLY MOUNTED SHOCKS................. [Re: MR_P_BODY] #1555791
02/27/14 02:55 PM
02/27/14 02:55 PM
bigfork mn
dragram440 Offline
dragram440  Offline
bigfork mn
That is what I have been looking at. I almost need to make the mount then figure out what length should be. Anyone know what part numbers work best in these cars?
Re: NEED PICS OV VERTICALLY MOUNTED SHOCKS................. [Re: dragram440] #1555792
02/27/14 03:38 PM
02/27/14 03:38 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Really depends on what springs you have. The ride height can change a lot from car to car. Best to measure extended length and length with weight on car.
Re: NEED PICS OV VERTICALLY MOUNTED SHOCKS................. [Re: dragram440] #1555793
02/27/14 03:40 PM
02/27/14 03:40 PM
State of confusion
State of confusion
Knowing what I know now I`d step up to a double adj. in the rear but the 9-ways work ok.............If the shock has lets say 6" of travel then set em up w/about 2" of compression and the rest for extension since leafs seperate and don`t squat. If you can, mount em straight up like I did..............
Re: NEED PICS OV VERTICALLY MOUNTED SHOCKS................. [Re: dragram440] #1555794
02/27/14 04:04 PM
02/27/14 04:04 PM
Motor City
6PKRTSE Online content
6PKRTSE  Online Content
Motor City
I have the 9 way adjustables under mine for now also.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: NEED PICS OV VERTICALLY MOUNTED SHOCKS................. [Re: Thumperdart] #1555795
03/02/14 10:00 AM
03/02/14 10:00 AM
robin hood country
deaks Offline
deaks  Offline
robin hood country
Finally have mine done.
Is there any chance you could post a clearer pic of the bottom brackets please, or have you just reversed the existing ones ?
Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200#
best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft
best 60ft 1.36
Re: NEED PICS OV VERTICALLY MOUNTED SHOCKS................. [Re: dragram440] #1555796
03/02/14 12:45 PM
03/02/14 12:45 PM
Metro Detroit
OUTLAWD Offline
OUTLAWD  Offline
Metro Detroit
Because of the way my 66 sits, on SS springs, and how much extension I needed, I ended up with a 15" compressed/23.75" extended length. Calvert #22150. A few minutes underneath measuring was all it took.
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts
66 Belv. II - just a streetcar
88 Mustang - turbo LS beater
Re: NEED PICS OV VERTICALLY MOUNTED SHOCKS................. [Re: 1967dartgt] #1555797
03/02/14 02:54 PM
03/02/14 02:54 PM
State of confusion
State of confusion
Did you change the i/c on your Dart by moving the ft. mounting point or are you still in the stock location.
Re: NEED PICS OV VERTICALLY MOUNTED SHOCKS................. [Re: deaks] #1555798
03/02/14 05:37 PM
03/02/14 05:37 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Mick
I just flipped my Calvert mounts to work there.
Re: NEED PICS OV VERTICALLY MOUNTED SHOCKS................. [Re: Thumperdart] #1555799
03/02/14 05:41 PM
03/02/14 05:41 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
My springs are mounted as high as I can get them in the pocket you can go. I have a 1/8 of a inch to the floor pan from the spring eye.
Re: NEED PICS OV VERTICALLY MOUNTED SHOCKS................. [Re: MR_P_BODY] #1555800
03/02/14 05:44 PM
03/02/14 05:44 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
A clearer pic of upper mount
