Page 3 of 8 1 2 3 4 5 6 7 8
Re: NEED PICS OV VERTICALLY MOUNTED SHOCKS................. [Re: 1967dartgt] #1555761
01/05/14 04:02 AM
01/05/14 04:02 AM
MR_P_BODY Offline
MR_P_BODY  Offline
GM did the shock staggering originally back in the 1960s for the Trans Am Road racing cars, it helped thier lap times There have been some drag cars try the shocks mounted in the front but we don't see that anymore
You might want to check out the latest built heads-up cars. Quite a few leaf spring cars have gone with the shocks in the front.
It really makes no difference if they are in front
or rear.. in front they just need stronger valving
to cover for the percentage of change
Re: NEED PICS OV VERTICALLY MOUNTED SHOCKS................. [Re: MR_P_BODY] #1555762
01/05/14 04:11 AM
01/05/14 04:11 AM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
What spring segment are you trying to control? Front or back? Why not mount shock on that segment. Some chassis builders are trying it in small tire stuff. It's really easy for me to do. Swap leaf spring/shock mounts side to side so shock mounts face forward. Weld bar for upper shock mount in done. Doesn't work stock uppers still there and swap plates back.
Re: NEED PICS OV VERTICALLY MOUNTED SHOCKS................. [Re: 1967dartgt] #1555763
01/05/14 04:17 AM
01/05/14 04:17 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Assume you are looking for something on more of a stock framed car? If so here is one I have on the Valiant after the ladder bar install. It had the same set up with Caltracs on it just no springs on the shocks. Hope it helps some.
Re: NEED PICS OV VERTICALLY MOUNTED SHOCKS................. [Re: Thumperdart] #1555764
01/05/14 02:35 PM
01/05/14 02:35 PM
south central pa
bdaz smblk Offline
bdaz smblk  Offline
south central pa
Soon, after the new year it will get done on my car.
Brad are you going to mount them in front of the rear too or no.
Where are yours mounted Mr. 8 3/4 9.0 guy..........
I think I like them better mounted in front of the rear.Then if u want to run a anti roll bar you have room to do that to.
3120lb, small block, 10.5" tire, NA, through exhaust, full int, WITH 83/4 REAR, 9.0 at 150mph
Re: NEED PICS OV VERTICALLY MOUNTED SHOCKS................. [Re: bdaz smblk] #1555765
01/05/14 02:38 PM
01/05/14 02:38 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Getting one of those at Tory's too.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: NEED PICS OV VERTICALLY MOUNTED SHOCKS................. [Re: bdaz smblk] #1555766
01/05/14 03:03 PM
01/05/14 03:03 PM
State of confusion
Thumperdart Offline OP
State of confusion
Gotcha............
Re: NEED PICS OV VERTICALLY MOUNTED SHOCKS................. [Re: 1967dartgt] #1555767
01/05/14 03:28 PM
01/05/14 03:28 PM
south central pa
bdaz smblk Offline
bdaz smblk  Offline
south central pa
You will be ready to getter done.Tory is a bad mofo for sure goodluck this year.
Re: NEED PICS OV VERTICALLY MOUNTED SHOCKS................. [Re: bdaz smblk] #1555768
01/05/14 03:32 PM
01/05/14 03:32 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Re: NEED PICS OV VERTICALLY MOUNTED SHOCKS................. [Re: bdaz smblk] #1555769
01/05/14 03:42 PM
01/05/14 03:42 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I have mounted the shocks in front and in the rear
but I just mount the anti roll on the opposite side
of the diff than the shocks.. so yes if you mount
them in front then yes you mount the anti roll in
the rear and visa versa
Re: NEED PICS OV VERTICALLY MOUNTED SHOCKS................. [Re: MR_P_BODY] #1555770
01/06/14 03:51 PM
01/06/14 03:51 PM
Metro Detroit
OUTLAWD Offline
OUTLAWD  Offline
Metro Detroit
Not too far off topic, but are there any risks to going to a vertical shock on the street? I still plan to drive the car on the street a fair amount, but I am not trying to carve canyons or anything.
I am currently running SS springs, but may make the switch to Caltracs if I can't get this thing to hook.
After crawling underneath and taking some measurments, I will not be able to move the upper mount outward very much (without re-working the exhaust, fuel lines, trunk floor where the fuel cell is sectioned in, etc.) So my next option looks to be to move the lower mount inward, away from the tire/spring. I understand that this is not ideal, but how big of an issue would this be?
I have the means to make some small brackets, weld them to the rear and make a new upper mount, but if I have to re-engineer everything aft of the axle, I may re-think my approach.
Any input is appreciated.
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts
66 Belv. II - just a streetcar
88 Mustang - turbo LS beater
Re: NEED PICS OV VERTICALLY MOUNTED SHOCKS................. [Re: OUTLAWD] #1555771
01/06/14 03:59 PM
01/06/14 03:59 PM
State of confusion
State of confusion
Don`t see why that can`t work by moving the lower bracket and as far as street driving, the only difference is that now it wants to hook and w/further tuning it WILL................
Re: NEED PICS OV VERTICALLY MOUNTED SHOCKS................. [Re: Thumperdart] #1555772
02/24/14 09:31 PM
02/24/14 09:31 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Finally have mine done.
Re: NEED PICS OV VERTICALLY MOUNTED SHOCKS................. [Re: 1967dartgt] #1555773
02/24/14 09:34 PM
02/24/14 09:34 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Upper shock mount.
Re: NEED PICS OV VERTICALLY MOUNTED SHOCKS................. [Re: OUTLAWD] #1555774
02/24/14 09:49 PM
02/24/14 09:49 PM
MR_P_BODY Offline
MR_P_BODY  Offline
You would like the shocks out as far as possible so
its easier to control and roll rate(depending on the
rear set up)but if running a ladder bar you want them
out as far also... thats why we tend to run the shocks
on the back of the ladder bar brackets.... the reason
the shocks were angled was to give a straight line
load when the car was in a corner which is when it
had the most roll rate to it
Re: NEED PICS OV VERTICALLY MOUNTED SHOCKS................. [Re: 1967dartgt] #1555775
02/24/14 10:18 PM
02/24/14 10:18 PM
State of confusion
State of confusion
Looks good but I see a serious problem there................you can`t go 9`s w/an 8 3/4.............
Re: NEED PICS OV VERTICALLY MOUNTED SHOCKS................. [Re: Thumperdart] #1555776
02/24/14 10:29 PM
02/24/14 10:29 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Should have let it know seven years ago when it started running nines! Still hanging in there.
Re: NEED PICS OV VERTICALLY MOUNTED SHOCKS................. [Re: 1967dartgt] #1555777
02/24/14 11:07 PM
02/24/14 11:07 PM
State of confusion
State of confusion
I hear ya..................let`s keep r fingers crossed...........
Re: NEED PICS OV VERTICALLY MOUNTED SHOCKS................. [Re: Thumperdart] #1555778
02/24/14 11:27 PM
02/24/14 11:27 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Re: NEED PICS OV VERTICALLY MOUNTED SHOCKS................. [Re: 1967dartgt] #1555779
02/25/14 04:01 PM
02/25/14 04:01 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
We moved mine verticle when we did my cage. The upper bar ties in the rear speaker tray bars going down into the trunk & is the upper shock bar mount. Also added the anti-roll bar at the same time.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: NEED PICS OV VERTICALLY MOUNTED SHOCKS................. [Re: 6PKRTSE] #1555780
02/25/14 09:51 PM
02/25/14 09:51 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
ARB is next on the list, this weekend hopefully. Needed the shocks in front for more room for ARB.
