Page 1 of 3 1 2 3
progress on my 42 dodge truck. #1555320
12/29/13 09:57 PM
12/29/13 09:57 PM
Shelby, Ohio
2
2abodymcodes Offline OP
Shelby, Ohio
already installed a 8 3/4 rear out of a 69 roadrunner and used rear springs for a 69 cuda.built new crossmembers and all the spring hangers. perfect fit.
got some 3/16" plate steel and boxed the front frame rails in.
Re: progress on my 42 dodge truck. [Re: 2abodymcodes] #1555321
12/29/13 09:59 PM
12/29/13 09:59 PM
Shelby, Ohio
2
Shelby, Ohio
recieved my FatMan front end the other day. got it mounted. i won't be installing the front springs untill i have everything mounted on the truck.
Re: progress on my 42 dodge truck. [Re: 2abodymcodes] #1555322
12/29/13 10:02 PM
12/29/13 10:02 PM
Shelby, Ohio
2
Shelby, Ohio
working on positioning the engine and tranny. 360 magnum and a 904. i was going to cut the firewall and recess it in order to run a fan and shroud but decided to leave the firewall alone and use an electric push fan instead.
Re: progress on my 42 dodge truck. [Re: 2abodymcodes] #1555323
12/30/13 01:45 AM
12/30/13 01:45 AM
Friendly, WV
wedgeheaded Offline
wedgeheaded  Offline
Friendly, WV
You're getting her punched out. Looks great.
Re: progress on my 42 dodge truck. [Re: wedgeheaded] #1555324
12/30/13 11:01 AM
12/30/13 11:01 AM
moparx Online content
moparx  Online Content
nice work you did ! keep at it and in no time [i should talk ! ] you will be having fun going down the road !
Re: progress on my 42 dodge truck. [Re: moparx] #1555325
01/12/14 08:12 PM
01/12/14 08:12 PM
Shelby, Ohio
2
Shelby, Ohio
got my Griffin radiator and tranny cooler mounted. i have about 4" between the water pump pulley and radiator. i should be able to find a fan blade that fits in there.
Re: progress on my 42 dodge truck. [Re: 2abodymcodes] #1555326
01/12/14 08:14 PM
01/12/14 08:14 PM
Shelby, Ohio
2
Shelby, Ohio
installed my Lokar shifter and e-brake mounted and my Flaming River tilt column in yesterday. today i got my brake pedal assembly mounted.
Re: progress on my 42 dodge truck. [Re: 2abodymcodes] #1555327
01/12/14 10:57 PM
01/12/14 10:57 PM
85086
moparpollack Offline
Lil Herman
Lil Herman
85086
Cool stuff!
I have the same handle you have, wish I had a shorter handle. It's a tight squeeze for the motor and radiator but you can run a fan. I recessed my firewall and run a clutch fan and here is more room if I needed it.
Wish my truck wasn't hacked so I coud of just used a mustang II like you did.
Re: progress on my 42 dodge truck. [Re: 2abodymcodes] #1555328
01/12/14 11:01 PM
01/12/14 11:01 PM
85086
Lil Herman
Lil Herman
85086
What are you going to used for gauges? The gauge panel area almost a .25" thick. Unless you cut the whole cluster get the plasma out and it's still a fight.
Re: progress on my 42 dodge truck. [Re: moparpollack] #1555329
01/12/14 11:39 PM
01/12/14 11:39 PM
Shelby, Ohio
2
Shelby, Ohio
i bought a set of dolphin guages off e-bay that fit into the original openings. they look a lot like stock but are 12 volt. the only part of the dash i will be cutting is the center below the windshield crank for my stereo.
Re: progress on my 42 dodge truck. [Re: 2abodymcodes] #1555330
01/12/14 11:45 PM
01/12/14 11:45 PM
Lon207 Offline
Lon207  Offline
Looking good so far.
I recently picked up a 47 pickup-so your project is going the same direction as I hope to go.
How much does that FatMan setup lower the front vs the original straight axle? How much did it cost?
thanks
Re: progress on my 42 dodge truck. [Re: Lon207] #1555331
01/14/14 01:13 AM
01/14/14 01:13 AM
Shelby, Ohio
2
Shelby, Ohio
the fatman i used is supposed to lower the front about 3" but i can go lower by cutting the springs. cost was 17 hundred.
Re: progress on my 42 dodge truck. [Re: 2abodymcodes] #1555332
01/17/14 04:56 AM
01/17/14 04:56 AM
levittown pa
fstfish66 Offline
fstfish66  Offline
levittown pa
looks great so far,,nice drive line
1966 barracuda prostreeter super charged 340(SOLD)
1940 dodge coupe 241 hemi street rod
2014 ram express hemi 4x4 dailey driver
2015 cherokee
2013 R/T classic
Re: progress on my 42 dodge truck. [Re: fstfish66] #1555333
02/11/14 01:34 AM
02/11/14 01:34 AM
Shelby, Ohio
2
Shelby, Ohio
with the exeption of my exhaust , i finished up my chassis tonight. i used a Lokar throttle cable , kickdown cable , and e-brake cables. they fit real nice and look good.
Re: progress on my 42 dodge truck. [Re: 2abodymcodes] #1555334
02/11/14 01:35 AM
02/11/14 01:35 AM
Shelby, Ohio
2
Shelby, Ohio
a shot from the rear
Re: progress on my 42 dodge truck. [Re: 2abodymcodes] #1555335
02/11/14 09:57 PM
02/11/14 09:57 PM
85086
Lil Herman
Lil Herman
85086
Where did you get the emergency brake mechanism?
Re: progress on my 42 dodge truck. [Re: moparpollack] #1555336
02/12/14 01:42 AM
02/12/14 01:42 AM
Shelby, Ohio
2
Shelby, Ohio
the shifter,e-brake handle,and all the cables are from Lokar.
Re: progress on my 42 dodge truck. [Re: 2abodymcodes] #1555337
02/12/14 11:27 AM
02/12/14 11:27 AM
levittown pa
fstfish66 Offline
fstfish66  Offline
levittown pa
looking good
2015 cherokee
2013 R/T classic
Re: progress on my 42 dodge truck. [Re: fstfish66] #1555338
04/20/14 01:27 PM
04/20/14 01:27 PM
Shelby, Ohio
2
Shelby, Ohio
got the grille and the cab painted and installed. everything is fitting together real nice. i should be driving it in about a month.
Re: progress on my 42 dodge truck. [Re: 2abodymcodes] #1555339
04/20/14 01:29 PM
04/20/14 01:29 PM
Shelby, Ohio
2
Shelby, Ohio
a shot of the engine. got my brake booster installed.
Page 1 of 3 1 2 3
