Re: converting auto on column to auto on floor
[Re: shaggy1]
#1553124
12/26/13 04:48 PM
12/26/13 04:48 PM
Posts: 85 Lavonia, GA
cjbill
Lavonia, GA
Wow...crickets! I'm "thinking" once you remove the column shift/interlocking equipment/column trans linkage, it won't matter. You'll just have a pre-column-lock type of column. Thankfully there are no brake interlock relays like on modern cars. ![](/ubbthreads/images/graemlins/grin.gif) I went through something similarly, replacing my floor shift steering column in the 300 with a column shift column, but my ignition was on the dash so I didn't have a bit of the issues that you are facing. I do know that after I removed the linkage at the bottom of the column to the transmission, the column shifter just moved around all loosey-goosey like... Probably not exactly the information you were seeking, though...
ex-Ford guy, but Mopars nowadays
[Re: shaggy1]
#1553126
12/26/13 08:04 PM
12/26/13 08:04 PM
Posts: 1,751 Graham, WA
Polarapete
Graham, WA
I just did something similar to my Ramcharger. Actually the truck came with a tilt column and another friend gave me a standard auto column. I then gave the original column with key back to him and it will live on in another friends '75 D100 short bed. Anyway, take the column completely apart until you get down to the lock ring,(it has a bunch of notches in it that the lock pin fits in) remove that completely or just cut all the notches off and put it back in or make a spacer to replace it. In my case, I left it in and took out the key, lock cylinder and all and ground the collar smooth, removing the auto shifter, too. I did the same to my Coronet racer 30 years ago and then filled the hole in the collar with JB Weld. I won't be using a key to start or stop the Ramcharger (and I am leaving the hole open as a weight saving measure), but I can't have the column lock at a bad time. Your needs may differ ![](/ubbthreads/images/graemlins/Twocents.gif)
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction 1998 Ram 2500 QuadCab, new daily driver. 2008 Honda Element 2014 Carry-On 7x14 Cargo Trailer
[Re: shaggy1]
#1553130
12/27/13 12:55 AM
12/27/13 12:55 AM
Posts: 1,520 West Palm Beach, Florida
Copper Dart
I wouldn't cut anything! Pull the roll pin out and remove the arm but don't cut. ![](/ubbthreads/images/graemlins/Twocents.gif)
Common sense, the least common of all the senses. Mom.
For fear of ridicule, society stifles creativity. Ricky Valdes
