Kevko oil pans anyone? #1551995
12/23/13 05:51 PM
12/23/13 05:51 PM
Between a rock & a hard place
cudadoug Offline OP
cudadoug  Offline OP
Anyone run this one?
http://kevko.net/images/M301_302_large.jpg
Do they fit?? Do they leak??
Re: Kevko oil pans anyone? [Re: cudadoug] #1551996
12/23/13 06:02 PM
12/23/13 06:02 PM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
My Kevko was not warped or had any fitment issues.
No leaks
only thing was there was weld spatter that I wire brushed while doing mockup - dont bolt it right on - but go through it and you will be a happy camper
Re: Kevko oil pans anyone? [Re: DJVCuda] #1551997
12/23/13 06:08 PM
12/23/13 06:08 PM
Seaford Delaware
JSR1485 Offline
JSR1485  Offline
Seaford Delaware
I have one in my Street car and in my race car.
No problems at all -fit good, good ground clerance and no leaks.
Just make sure you adjust the oil pump pickup off the bottom of the pan.I used clay on the pickup and bolted thepan on the block to check & set it off the bottom.
Switched to the dark side...
Re: Kevko oil pans anyone? [Re: cudadoug] #1551998
12/23/13 07:57 PM
12/23/13 07:57 PM
AndyF Offline
AndyF  Offline
I've used several Kevko pans. They are a good piece for the money. I had them build me a couple of custom pans for a project and they did nice work. Very easy guys to work with.
Re: Kevko oil pans anyone? [Re: AndyF] #1551999
12/23/13 08:21 PM
12/23/13 08:21 PM
Renton Washington
Triple Threat Offline
Renton Washington
I have the non Kick out version of that pan, I agree its a good piece for the money. Mine was on a 10.70 street strip small block.
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: Kevko oil pans anyone? [Re: Triple Threat] #1552000
12/23/13 10:18 PM
12/23/13 10:18 PM
cudadoug Offline OP
cudadoug  Offline OP
This one?
http://www.kevkoracing.com/images/M301_full.gif
Re: Kevko oil pans anyone? [Re: cudadoug] #1552001
12/23/13 10:25 PM
12/23/13 10:25 PM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
I have used several of them over the years for Mopar & X brands. All fit well and worked fine.
If you like drag racing, support your local track.
Re: Kevko oil pans anyone? [Re: cudadoug] #1552002
12/23/13 10:33 PM
12/23/13 10:33 PM
Sunnyvale, CA
Jeepmon Offline
Jeepmon  Offline
Sunnyvale, CA
Thats the one I run on the 73... At first appearance, the welds are just "ok".. its no where near as clean or pretty as the milodon pan, but it fits well, doesnt hang down as low as the milodon and is less expensive.. I would definitely buy another one, if I was shopping for one..
Re: Kevko oil pans anyone? [Re: cudadoug] #1552003
12/23/13 11:35 PM
12/23/13 11:35 PM
Renton Washington
Renton Washington
This one?
Yes, the kickout version wasn't offered when I bought mine. I would have bought it if it was.
-Dustin
Re: Kevko oil pans anyone? [Re: Triple Threat] #1552004
12/24/13 12:54 AM
12/24/13 12:54 AM
North, Alabama
D-50 Offline
D-50  Offline
North, Alabama
I am also running the Kevko without the kickouts, it is a 6 qt. pan. It fit good with no leaks so far.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
Re: Kevko oil pans anyone? [Re: D-50] #1552005
12/24/13 01:31 AM
12/24/13 01:31 AM
Space Station #5
471Magnum Offline
471Magnum  Offline
Space Station #5
I'm running one of the 301 pans as well. Ugly as can be, but functionally it's perfect. Good pan for the money.
-Jim
I can fix it... my old man is a television repairman.
He's got the ultimate set of tools... I can fix it.
Currently Mopar-less
Re: Kevko oil pans anyone? [Re: D-50] #1552006
12/24/13 05:38 PM
12/24/13 05:38 PM
Renton Washington
Renton Washington
Here is my pan:
Kevko Pickup, needed tweeked but no big deal. 5 minutes and a propane torch had it dialed in.
I've been toying with the idea of cutting it apart and deepening it another 3/4 or 1 inch.
-Dustin
Re: Kevko oil pans anyone? [Re: Triple Threat] #1552007
12/24/13 05:57 PM
12/24/13 05:57 PM
cudadoug Offline OP
cudadoug  Offline OP
Good info here...as always. Thanks!
Thanks Dustin... great pics.
