Re: Kevko oil pans anyone?
[Re: DJVCuda]
#1551997
12/23/13 06:08 PM
12/23/13 06:08 PM
Posts: 1,123 Seaford Delaware
JSR1485
Seaford Delaware
I have one in my Street car and in my race car. No problems at all -fit good, good ground clerance and no leaks. Just make sure you adjust the oil pump pickup off the bottom of the pan.I used clay on the pickup and bolted thepan on the block to check & set it off the bottom.
Switched to the dark side...
[Re: AndyF]
#1551999
12/23/13 08:21 PM
12/23/13 08:21 PM
Triple Threat
Renton Washington
I have the non Kick out version of that pan, I agree its a good piece for the money. Mine was on a 10.70 street strip small block.
[Re: cudadoug]
#1552002
12/23/13 10:33 PM
12/23/13 10:33 PM
Posts: 8,094 Sunnyvale, CA
Jeepmon
Sunnyvale, CA
Anyone run this one?
http://kevko.net/images/M301_302_large.jpg
Do they fit?? Do they leak??
Thats the one I run on the 73... At first appearance, the welds are just "ok".. its no where near as clean or pretty as the milodon pan, but it fits well, doesnt hang down as low as the milodon and is less expensive.. I would definitely buy another one, if I was shopping for one..
[Re: Triple Threat]
#1552004
12/24/13 12:54 AM
12/24/13 12:54 AM
Posts: 1,267 North, Alabama
D-50
North, Alabama
I am also running the Kevko without the kickouts, it is a 6 qt. pan. It fit good with no leaks so far.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
[Re: D-50]
#1552005
12/24/13 01:31 AM
12/24/13 01:31 AM
Posts: 3,719 Space Station #5
471Magnum
Space Station #5
I'm running one of the 301 pans as well. Ugly as can be, but functionally it's perfect. Good pan for the money.
-Jim
I can fix it... my old man is a television repairman. He's got the ultimate set of tools... I can fix it.
Currently Mopar-less
