Is there an engine to chassis/body ground strap on AAR #1550818
12/21/13 02:30 AM
12/21/13 02:30 AM
mopar346 Offline OP
Let me tell ya about fat chicks!
mopar346  Offline OP
I have studied a lot of pictures and cant seem to find one, did they utilize one? Were there problems due to not running one? Wouldn't it improve the electrical system if one/some were added?
Thanks in advance, Kevin
Careful, your character's showing!
Re: Is there an engine to chassis/body ground strap on AAR [Re: mopar346] #1550819
12/21/13 03:04 AM
12/21/13 03:04 AM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
The negative battery cable has a small lead that connects to the radiator support to ground the body.
The large lead on the same cable grounds the engine.
Re: Is there an engine to chassis/body ground strap on AAR [Re: Alaskan_TA] #1550820
12/21/13 11:54 AM
12/21/13 11:54 AM
mopar346 Offline OP
mopar346  Offline OP
As do most, but no other engine to chassis ground strap, interesting.
Thank you
Re: Is there an engine to chassis/body ground strap on AAR [Re: mopar346] #1550821
12/21/13 01:48 PM
12/21/13 01:48 PM
Sweden
71redcuda Offline
71redcuda  Offline
Sweden
Thank you
No other ground straps on 70-71 e-bodies
Re: Is there an engine to chassis/body ground strap on AAR [Re: 71redcuda] #1550822
12/22/13 12:39 AM
12/22/13 12:39 AM
Canada
Seventythree Offline
Canada
73/74 has an additional ground strap that connects to the firewall.
Re: Is there an engine to chassis/body ground strap on AAR [Re: mopar346] #1550823
12/22/13 04:50 AM
12/22/13 04:50 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Thank you
The battery cable to body started in 70 , 69 down had a ground strap for the engine to firewall , no lead from the battery cable to the core support.
Re: Is there an engine to chassis/body ground strap on AAR [Re: JohnRR] #1550824
12/22/13 09:28 AM
12/22/13 09:28 AM
mopar346 Offline OP
mopar346  Offline OP
Maybe on Mopars, but other cars had both prior to 70 not sure when they started I just know I've seen them.
Re: Is there an engine to chassis/body ground strap on AAR [Re: Seventythree] #1550825
12/22/13 12:14 PM
12/22/13 12:14 PM
Connecticut
1972CudaV21 Offline
1972CudaV21  Offline
Connecticut
Plus 72
Re: Is there an engine to chassis/body ground strap on AAR [Re: mopar346] #1550826
12/22/13 01:40 PM
12/22/13 01:40 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
An AAR is a MOPAR , correct ???
I didn't see the question being asked pertaining to a Ford or GM product ....
Re: Is there an engine to chassis/body ground strap on AAR [Re: JohnRR] #1550827
12/22/13 04:05 PM
12/22/13 04:05 PM
JERSEY
RJS Offline
RJS  Offline
JERSEY
Careful John Santa is always watching!!!!
Re: Is there an engine to chassis/body ground strap on AAR [Re: RJS] #1550828
12/22/13 07:29 PM
12/22/13 07:29 PM
mopar346 Offline OP
mopar346  Offline OP
You're correct John, I guess I am a lot more aware of ground straps since building a CJ, they have notoriuosly bad grounds that cause all sort of electrical gremlins.
Re: Is there an engine to chassis/body ground strap on AAR [Re: mopar346] #1550829
12/22/13 08:38 PM
12/22/13 08:38 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
If you paint them up and not make an effort on the grounding all makes and models will have you
In your case make sure the tail light housings are grounded well or you'll be pulling them back out also..{there was a dedicated ground strap on the left,rear tail light housing not the right}...
Anyhow,the factory obviously saw an error in their ways and added the engine strap after a year or two past 70...If it bothers you add one back there and keep the grounding point low on the firewall so you can't see it...Unless you plan on having someone with a mirror climb in there at a show and cry foul on you...
Re: Is there an engine to chassis/body ground strap on AAR [Re: screamindriver] #1550830
12/23/13 12:49 AM
12/23/13 12:49 AM
mopar346 Offline OP
mopar346  Offline OP
Well it is an AAR so I am sure some foul will.
If I decide to add one it would be from the back of the head to an existing bolt/screw on the firewall and I would have no problem telling some one why I did it.
