'83 D-150 silly question #1549436
12/17/13 08:34 PM
12/17/13 08:34 PM
Park Forest, IL
slantzilla Online content OP
slantzilla  Online Content OP
Park Forest, IL
My 318 has no choke thermostat in it. I have one to put in, but where does the wire attach to?
The wiring was heavily "modified" by a previous owner. There used to be a wire coming off a field wire, was that it?
Thanks!
Re: '83 D-150 silly question [Re: slantzilla] #1549437
12/17/13 08:47 PM
12/17/13 08:47 PM
Colleyville
3hundred Offline
3hundred  Offline
Colleyville
If I remember, that's an electrically assisted choke. There is a three prong switch back by the distributor the wire attaches too. It will feed power to the choke only when the key is on and there's oil pressure.
Robert
'68 Fury Convertible
'69 300 Convertible
'15 Durango 5.7 Hemi
'16 300 S Hemi
Re: '83 D-150 silly question [Re: 3hundred] #1549438
12/18/13 12:11 AM
12/18/13 12:11 AM
McGregor,Iowa 52157
500ciDuster Offline
500ciDuster  Offline
McGregor,Iowa 52157
I thought power feed is blue which split off the blue field wire
Re: '83 D-150 silly question [Re: 500ciDuster] #1549439
12/18/13 12:43 PM
12/18/13 12:43 PM
Park Forest, IL
Park Forest, IL
Thanks guys!
I am going to go with the field wire. I got hold of a complete intake and there is no evidence of a timer on it.
Re: '83 D-150 silly question [Re: slantzilla] #1549440
12/18/13 12:49 PM
12/18/13 12:49 PM
Colleyville
3hundred Offline
3hundred  Offline
Colleyville
Found it, see attachment.
Robert
'69 300 Convertible
'16 300 S Hemi
Re: '83 D-150 silly question [Re: 3hundred] #1549441
12/18/13 05:11 PM
12/18/13 05:11 PM
Colleyville
3hundred Offline
3hundred  Offline
Colleyville
Since it's just an emission control device I think I'd snip the wire and call it good.
Robert
'69 300 Convertible
'16 300 S Hemi
Re: '83 D-150 silly question [Re: 3hundred] #1549442
12/22/13 10:06 PM
12/22/13 10:06 PM
pa.
slantsic Offline
slantsic  Offline
pa.
try finding an older non electric thermostat. if you just snip the wire it may open to slow causing it to run rich longer.
Re: '83 D-150 silly question [Re: slantsic] #1549443
12/23/13 05:11 AM
12/23/13 05:11 AM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Its Not an emissions item. it helps control the Choke
