Page 1 of 9 1 2 3 4 5 6 7 8 9
Will a 8 3/4 Live? #1548237
12/16/13 11:33 AM
12/16/13 11:33 AM
Tucson, Arizona
clonestocker Offline OP
Tucson, Arizona
My son's making changes to his 67 Dart. He will eventually be going to a Gen3 Hemi w/Mods. This is a street car. He will be running Cal Tracs, TKO 600 5 spd and will use a 27 x10.5 ET Street tire. He was told to put a Back Brace on it and it will use a clutch posi. Opinions please. thx matt
[img] [/img]
Re: Will a 8 3/4 Live? [Re: clonestocker] #1548238
12/16/13 11:36 AM
12/16/13 11:36 AM
Deerfield, Ohio
70dusterjohn Offline
Deerfield, Ohio
Weight and sticky tires on a stick, I say sell it and put the money towards a Dana or 9in ! Even back braced it's not going to live with the stick !
Re: Will a 8 3/4 Live? [Re: clonestocker] #1548239
12/16/13 11:40 AM
12/16/13 11:40 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I ran my race car with a stock 8 3/4 with a posi
and it lasted 600 passes... but the car was light
leaving at 5000+ rpm.... if he puts the back brace
and the carrier cap or caps it would be fine for a
long time... weight is what kills them
Re: Will a 8 3/4 Live? [Re: clonestocker] #1548240
12/16/13 11:51 AM
12/16/13 11:51 AM
Cab_Burge Online work
Cab_Burge  Online Work
A freind of mine broke a bunch of 8 3/4 parts,(no back brace availble back then )ring and pinions, blew a clutch type posi unit completely apart , twisted axles and so on with a basically stock 340 pump gas motor stick shift car years ago in a very lightweight Duster, 2750 lbs without the driver He switched to a Dana 60 with 35 spline axles and posi and never had another problem with rear ends I would go to the Dana 60 now and not look back
Re: Will a 8 3/4 Live? [Re: Cab_Burge] #1548241
12/16/13 01:04 PM
12/16/13 01:04 PM
Indy
FlyFish Offline
FlyFish  Offline
Indy
After putting Caltracs on my car (stroked small block, 5k converter), it crushed the axle tubes at the spring perches on my 8 3/4. I switched the housing out for a Moser MO875 fabricated housing with a back brace...everything has been great since. This is on my 3200# Barracuda street/strip car that runs mid 10's.
67 Barracuda street car, 408, e85, 1.38 60', 6.44 @105.9 in the 1/8 mile, 10.19 @130.5 in the 1/4...so far....
Re: Will a 8 3/4 Live? [Re: clonestocker] #1548242
12/16/13 01:33 PM
12/16/13 01:33 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Mine's a 742 case w/ MW caps, a fresh clutch-type sure-grip unit, Moser axles and a back-braced housing. But I run a 440 & automatic w/a relatively soft-hitting converter. I know mine still has a limited life span, but adding a stick & clutch to the equation would probably kill it in short order. I vote to put the $$$ into something better right up front.
Re: Will a 8 3/4 Live? [Re: BradH] #1548243
12/16/13 01:46 PM
12/16/13 01:46 PM
dogdays Offline
dogdays  Offline
www.doctordiff.com
Take all the $ you were going to spend on back bracing, nodular or billet caps, etc and just buy a D60. You'll only have to do it once.
R.
Re: Will a 8 3/4 Live? [Re: FlyFish] #1548244
12/16/13 01:47 PM
12/16/13 01:47 PM
BradH Offline
BradH  Offline
... I switched the housing out for a Moser MO875 fabricated housing with a back brace...
I looked at one of those, too, but started thinking putting any more money into an 8.75" setup was simply taking money away from what it would cost to upgrade to a Dana 60.
If I came across one cheap enough, I'd probably try it. But at the price I recall them selling for, it was a tough sell.
Re: Will a 8 3/4 Live? [Re: 70dusterjohn] #1548245
12/16/13 01:59 PM
12/16/13 01:59 PM
long island new york
K
kingdust Offline
kingdust  Offline
K
I agree, I twisted 3 8.75s even with the perches gusseted. I had a 3120lb duster 340 4spd 486 gears, Detroit locker and the mark Williams caps. even with the brace which you will have to notch for the shocks. its just not worth the money when you can get a dana or 9 inch! and not have to worry about it.
LIFE IS A LESSON,YOU LEARN IT WHEN YOUR THROUGH!
Re: Will a 8 3/4 Live? [Re: MR_P_BODY] #1548246
12/16/13 02:28 PM
12/16/13 02:28 PM
Graham, WA
P
Polarapete Offline
Polarapete  Offline
P
Graham, WA
The 8 3/4 in your son's '67 Dart has several things going for it.
1) the '67 is one of the lightest A-bodies
2) the tires he wants to use are going to be a limiting factor in terms of bite and therefore stress
3) this is supposed to be a "street car" and banzai launches should not be every launch particularly if he wants to keep his license
4) since he is using a stick, even if he breaks the rear he won't have 727 parts coming through the floor from a rolled sprag
That being said, I am a real beleiver in the brute strength of the Dana 60 when needed. I have never raced with anything else and never will
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction
1998 Ram 2500 QuadCab, new daily driver.
2008 Honda Element
2014 Carry-On 7x14 Cargo Trailer
Re: Will a 8 3/4 Live? [Re: BradH] #1548247
12/16/13 05:07 PM
12/16/13 05:07 PM
Indy
FlyFish Offline
FlyFish  Offline
Indy
Yeah, just the housing is not too expensive. I actually got a heck of a deal on mine because they had one that was special ordered and the customer backed out. Instead of scrapping it, they offered it to me for a much reduced price (since it was not exactly what I had asked for)...all I had to do was a little cutting and welding to make it fit. For me, it was much cheaper than going to a Dana (I could use my axles and pumpkin), but I know someday I might have to make the switch...but I think I'll be safe since I foot-brake.
Re: Will a 8 3/4 Live? [Re: FlyFish] #1548248
12/16/13 05:27 PM
12/16/13 05:27 PM
Carson City, Nevada
Biginchmopar Offline
Carson City, Nevada
It will break - PERIOD!!!
Re: Will a 8 3/4 Live? [Re: Biginchmopar] #1548249
12/16/13 05:43 PM
12/16/13 05:43 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I guess I better sell my 8 3/4... its only been
1.19 60'... with BIG slicks... but the car is light,
with the street tires(even the MT EZ Streets) its
gonna have some spin.... but I guess there is plenty
on here that cant build a diff... dont dead hook
ANY car.... you will also notice that you dont see
the guys saying they blow the D60s... and they do
on a regular basis
Re: Will a 8 3/4 Live? [Re: MR_P_BODY] #1548250
12/16/13 06:58 PM
12/16/13 06:58 PM
Janesville, WI
SpareParts Offline
SpareParts  Offline
Janesville, WI
Ford 8.8 it's cheap simple and strong. It's also a light weight setup compared to the D60
Re: Will a 8 3/4 Live? [Re: SpareParts] #1548251
12/16/13 07:18 PM
12/16/13 07:18 PM
Moparts
SSDart Offline
SSDart  Offline
Moparts
Dana60 .......
Re: Will a 8 3/4 Live? [Re: MR_P_BODY] #1548252
12/16/13 07:21 PM
12/16/13 07:21 PM
Q
Quicktree Offline
Quicktree  Offline
Q
on a regular basis
Mike you are not doing an equal comparison, you have a after market aluminum housing a light car and not a bunch of power.
Re: Will a 8 3/4 Live? [Re: Quicktree] #1548253
12/16/13 07:29 PM
12/16/13 07:29 PM
MR_P_BODY Offline
MR_P_BODY  Offline
on a regular basis
Tony I made 600+ passes on a STOCK 8 3/4 with just
a back brace... that was with 550hp in a heavier
car than now by about 250# so that was close to 2700#
and EVERY pass was off the trans brake
Re: Will a 8 3/4 Live? [Re: Quicktree] #1548254
12/16/13 07:29 PM
12/16/13 07:29 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
on a regular basis
I'd bet he makes more than the O.P. is planning on.
Like he said......weight kills them.
Add a stick and I would not consider an 8 3/4.
Add up a cap or caps , decent case , back brace and I have to agree that a Dana is a better alternative.
But done correctly , an 8 3/4 can survive within certain parameters.
My gut feeling is a heavy car that makes some oats or a stick shift that hooks would be outside of those.
Re: Will a 8 3/4 Live? [Re: Quicktree] #1548255
12/16/13 07:31 PM
12/16/13 07:31 PM
Carson City, Nevada
Carson City, Nevada
I don't want to hurt fealings or step on toes but with his set-up IT WILL BREAK!
Any diff can break with enough abuse.
I speak from experience 3800lbs 69 Roadrunner with a 10" slick, 5 speed, Cal-Tracs, around 650lbs/ft torque. I have broke axles, bent things on a Dana 60. The 8 3/4 would have destoyed it self long, long ago.
Re: Will a 8 3/4 Live? [Re: Biginchmopar] #1548256
12/16/13 07:34 PM
12/16/13 07:34 PM
Q
Quicktree Offline
Quicktree  Offline
Q
I wouldn't recommend an 8-3/4 to anyone but everybody knows that.
