Re: rod shopping
[Re: dogdays]
#1547969
12/16/13 02:45 PM
12/16/13 02:45 PM
Posts: 3,916 usa
lewtot184
usa
Your question leaves so much to be guessed at that it doesn't have an answer.
Here are some things I think about when I read your question: 1. Why do you need new rods? 2. What are you doing with your engine that stock rods won't work? 3. What's wrong with the rods you're running now?
For a street engine that doesn't see more than 5000 rpm, the stock rods usually lasted basically forever.
The part of a connecting rod that usually gives trouble is the big end. The highest force the rod sees is at the end of the exhaust stroke. Rod bolts stretch and loosen the crush on the rod bearing, and/or big ends distort.
For years and years the Carrillo rod was the best that could be bought. It was an H-beam.
When more got into the aftermarket rod market, most of the first generation rods were also H-beam. I maintain that's because you could create an H-beam rod out of a piece of steel plate. No forging equipment required.
When the aftermarket rod industry took off (and a lot went overseas) there started to appear reasonably priced I-beam rods. Economics of scale allowed the manufacture by forging.
In the beginning, H-beam rods were heavy. I maintain they have the beam material in the wrong places. But as time went by, the H-beam became lighter and lighter as better design techniques were used. Now, the difference in weight between a really good H-beam and a really good I-beam is meaningless.
Go on Ebay and look at the used racing rods. There are some of each style. That means to me that either style can be used in the most demanding applications.
If you have to or want to change your rods for I-beam rods, the best two that come to mind are the Oliver parabolic billet and Crower billet rods. They don't come cheap.
R.
the engine in question has h-beam rods in it now. i don't like them and want to change them; simple. do you have any experience with the 440 source i-beam rods? i'm looking for feedback on the 440 source i-beam rods.
Re: rod shopping
[Re: lewtot184]
#1547970
12/16/13 03:50 PM
12/16/13 03:50 PM
Posts: 75,069 U.S.S.A.
JohnRR
U.S.S.A.
R.
Are the source i beam rods even still available ? if they are what material are they made from ?
Are you actually trying to compare them to a rod like an OLIVER ???
Re: rod shopping
[Re: JohnRR]
#1547971
12/16/13 05:11 PM
12/16/13 05:11 PM
Posts: 5,163 CT
GTX MATT
CT
The source I beams are 5140
Re: rod shopping
[Re: JohnRR]
#1547972
12/16/13 07:35 PM
12/16/13 07:35 PM
Posts: 4,318 Prospect, PA
BSB67
Prospect, PA
My guess is that he is looking at it like this: after you recondition a set of LYs with good bolts, you're most of the way to the cost of the 440 Source rods, and they are still 45 years old.
Re: rod shopping
[Re: BSB67]
#1547973
12/16/13 07:41 PM
12/16/13 07:41 PM
Posts: 3,916 usa
lewtot184
usa
ding, ding! you win a cookie! i'll send you a pm.
Re: rod shopping
[Re: GTX MATT]
#1547974
12/16/13 08:45 PM
12/16/13 08:45 PM
JohnRR
U.S.S.A.
If that is the case then I would prefer a set of reconed LY's out of Cbody donor motor.
Re: rod shopping
[Re: JohnRR]
#1547975
12/16/13 08:50 PM
12/16/13 08:50 PM
dogdays
The stockers aren't made of any better stuff. Probably worse. The new 440Source rods also have 7/16" rod bolts, which are what should have been in the stockers but weren't. R.
Re: rod shopping *DELETED*
[Re: Supercuda]
#1547978
12/17/13 03:11 AM
12/17/13 03:11 AM
JohnRR
U.S.S.A.
Post deleted by lewtot184
Isn't that SPECIAL
fixed
