Dangnamit! speedo cable #154567
11/21/08 05:08 PM
11/21/08 05:08 PM
So Cal
HealthServices Offline OP
Why would you even post that?
So Cal
I had to pull the RR out to work on another car. I was doing a bunch of under dash work and did not notice the speedo cable fell out of the firewall.
I was backing up and ran over the cable, pulling it out of the trans.
Are these things available thru NAPA?
Allen Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first. Life was a little easier when I was just a wrench.
Re: Dangnamit! speedo cable [Re: HealthServices] #154568
11/21/08 05:39 PM
11/21/08 05:39 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
should be...if not, rockauto.com has them, less than $20...
2017 Grand Cherokee Overland
Re: Dangnamit! speedo cable [Re: patrick] #154569
11/21/08 06:55 PM
11/21/08 06:55 PM
So Cal
So Cal
Thanks I'll be ordering this next week.
Re: Dangnamit! speedo cable [Re: HealthServices] #154570
11/21/08 07:27 PM
11/21/08 07:27 PM
The NAPA one I bought was not correct. I made it work by pulling the end off the original one and re-engineering it. Typical off-shore junk as usual.
Sheldon
Re: Dangnamit! speedo cable #154571
11/21/08 07:30 PM
11/21/08 07:30 PM
So Cal
So Cal
good to know thanks
