I had to pull the RR out to work on another car. I was doing a bunch of under dash work and did not notice the speedo cable fell out of the firewall.
I was backing up and ran over the cable, pulling it out of the trans.
Are these things available thru NAPA?
Allen Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first. Life was a little easier when I was just a wrench.
