Bell Housing Bolt Pattern #1545650
12/09/13 08:23 AM
12/09/13 08:23 AM
Greer, SC
TooMany62s Offline OP
Greer, SC
Am I safe in assuming that the transmission bolt pattern on a V10 truck transmission is different than an 833? Is there a bell housing to mount an 833 on a V10 truck motor?
Thanks!!
Re: Bell Housing Bolt Pattern [Re: TooMany62s] #1545651
12/09/13 09:46 AM
12/09/13 09:46 AM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Why would you bother with an old 4spy when a 5-6 spd is available and probably more feasible. I don't believe there is a bell that works with the 833
Re: Bell Housing Bolt Pattern [Re: 76dodgeboy] #1545652
12/09/13 11:55 AM
12/09/13 11:55 AM
Greer, SC
Greer, SC
I already have an 833.....plus I don't think there's a bell housing that will work with the 5 or 6 speed on a truck motor other than the NV4500.
Re: Bell Housing Bolt Pattern [Re: TooMany62s] #1545653
12/10/13 04:54 PM
12/10/13 04:54 PM
St. John's Newfoundland
440newport Offline
440newport  Offline
The v10 uses the "SAE" bellhousing pattern, the same as a Cummins. You might be able to find an adapter that will work with a small block bellhousing.
Re: Bell Housing Bolt Pattern [Re: 440newport] #1545654
12/10/13 05:29 PM
12/10/13 05:29 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Cummins have 5-6spds so you have options rite there
Re: Bell Housing Bolt Pattern [Re: 76dodgeboy] #1545655
12/10/13 09:25 PM
12/10/13 09:25 PM
colorado
savoy64 Offline
savoy64  Offline
colorado
you can use a getrag bellhousing with a 3/4 spacer between bell and tranny---made mine out of aluminum plate and a friend made the index hole on his mill....
Re: Bell Housing Bolt Pattern [Re: 76dodgeboy] #1545656
12/10/13 11:11 PM
12/10/13 11:11 PM
Truckville, the capital of NY
85_Ram_4speed Offline
Huh, I never knew that they use SAE stuff. I always had it in my mind the V-10 used a standard small block bellhousing pattern.
Maybe, because you still need a bellhousing (actually its called a Flywheel housing in the diesel end of the business)that matches the engine side and an then an adapter or trans with integrated bellhousing that shares the same SAE # on the other side.
To the OP, anything is possible if you want it to be. This is an adapter I made to put a 833 trans behind a big block Chevy. Of course what I did is nothing new, this used to be a real common swap many years ago for drag racing and circle track. I just went the homade route as finding what was a common adapter back then is very uncommon now.
Outcast Dodge guy.
Re: Bell Housing Bolt Pattern [Re: 85_Ram_4speed] #1545657
12/10/13 11:41 PM
12/10/13 11:41 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
The cummins and V10 share the same bolt pattern from what I've heard and what was said above there fore it'll bolt to the trans aswell
Re: Bell Housing Bolt Pattern [Re: 76dodgeboy] #1545658
12/11/13 01:37 AM
12/11/13 01:37 AM
colorado
savoy64 Offline
savoy64  Offline
colorado
hey 85 ram----your adapter looks like the one i made---and do you know there is an 883 with a chev bolt pattern on it---they were used in diesel blazers and some pickups---i hear they are pretty rare too...bob
Re: Bell Housing Bolt Pattern [Re: savoy64] #1545659
12/11/13 05:05 AM
12/11/13 05:05 AM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Nope only Harley!
Re: Bell Housing Bolt Pattern [Re: savoy64] #1545660
12/11/13 08:23 AM
12/11/13 08:23 AM
Yup, I had one of those GM 833 trans. They were only offered in the O/D version (thus my adapter to allow a std 4-speed 833 behind the GM motor). I bought it way cheap and made a good buck on it, but it was insturmental in making that adapter I did being able to have that and a Mopar 833 side by side. I talked to Jamie Passon about them, they have metric bearings in them, and the main case looks just like a 833 with standard muncie bolt pattern and a standard looking Muncie tailshaft on it. Interesting foot note in the 833 history for sure. I have only seen the one I had, and only read about a handful of more. They are rare nowadays.
Sorry to side track the topic though.
Outcast Dodge guy.
Re: Bell Housing Bolt Pattern [Re: 85_Ram_4speed] #1545661
12/11/13 01:01 PM
12/11/13 01:01 PM
dogdays Offline
dogdays  Offline
I believ the 6BT (meaning also the V10) uses an SAE #3 clutch housing.
Phoenix in Juniata Nebraska makes an adapter for Cummins to LA bellhousing. I am not sure how the clutch works.
R.
Re: Bell Housing Bolt Pattern [Re: dogdays] #1545662
12/11/13 01:25 PM
12/11/13 01:25 PM
colorado
savoy64 Offline
savoy64  Offline
colorado
the V10/cummins bellhousing is strictly a dodge thing----for an sae to fit on a 5.9 cummins you have to buy a special flywheel plate---they can be found on school buses with allisons---the 4bt units thAT ran on a ford or chevy tranny used a special flywheel plate that would bolt to the ford or gm tranny---they are not liked very much because the flywheel is small and probably the clutch will be overpowered by a moded engine---if someone is making a small block dodge pattern i would expect clutch problems----a 727 or 518 can be built to take it-----cant see why to do it unless you have a transmission tunnel problem ....
