Edelbrock Hemi heads #1545302
12/08/13 06:44 PM
12/08/13 06:44 PM
STL ,MO
Handygun Offline OP
Handygun  Offline OP
STL ,MO
Has anyone seen the "victor jr" Hemi heads that were at the SEMA show? Edel claims hp increase over competitors? head. They have revised valve angles and bigger intakes supposedly. I take it this is not the one they have been making for MoPar.
Re: Edelbrock Hemi heads [Re: Handygun] #1545303
12/08/13 07:10 PM
12/08/13 07:10 PM
Trumbull,CT.
jim sciortino Offline
Trumbull,CT.
Haven't seen em', but it's WELL past time (decades) that someone would market a HEMI head incorporating MODERN technology, for a 4.800 block.
Somehow, I doubt these Edelbrock castings will fill that bill.
Re: Edelbrock Hemi heads [Re: jim sciortino] #1545304
12/08/13 07:12 PM
12/08/13 07:12 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Edelbrock caters toward the masses....Probably will be just a replacement head with next to no improvements...
Re: Edelbrock Hemi heads [Re: Dragula] #1545305
04/07/14 05:12 PM
04/07/14 05:12 PM
Odessa, Fl
blowndart Offline
blowndart  Offline
Odessa, Fl
I noticed these are starting to show up on eBay. Anyone know anything on them yet?
Re: Edelbrock Hemi heads [Re: Dragula] #1545306
04/08/14 12:30 AM
04/08/14 12:30 AM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
Supposed to be better. Which is what the masses want.
2011 Drag Pak Challenger
Re: Edelbrock Hemi heads [Re: Handygun] #1545307
04/08/14 11:22 AM
04/08/14 11:22 AM
WI.
Scotts71chall Offline
WI.
Also new is the Victor Jr. CNC head for Chrysler 426-572 Hemi engines. This head features CNC combustion chambers and CNC-blended seats for improved airflow. The exhaust valve angle has been revised to allow 2.32-inch intake valves. Intake port volume is 245cc, and brass tubes are installed in the exhaust pushrod holes to allow more clearance without intruding on the port.
Re: Edelbrock Hemi heads [Re: Scotts71chall] #1545308
04/08/14 12:14 PM
04/08/14 12:14 PM
Oceanside CA
relax383 Offline
relax383  Offline
Oceanside CA
Talked to the Edelbrock guys about them at Good Guys the heads have bigger intake valves 2.34. Also as stated above lots of CNC goodness.
Re: Edelbrock Hemi heads [Re: relax383] #1545309
04/08/14 02:26 PM
04/08/14 02:26 PM
Trumbull,CT.
Trumbull,CT.
Somebody wake me up when there's a better head than Stage V's Millennium.
A head that was revised 15 YEARS AGO!!!!
Re: Edelbrock Hemi heads [Re: jim sciortino] #1545310
04/08/14 02:35 PM
04/08/14 02:35 PM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
Re: Edelbrock Hemi heads [Re: Defbob] #1545311
04/08/14 03:10 PM
04/08/14 03:10 PM
Odessa, Fl
blowndart Offline
blowndart  Offline
Odessa, Fl
Few would argue they the Millennium head is a great head but it's not exactly close to a stock replacement type head. The Stage V SR heads would be more in the same category as the Edelbrock Vic Jr heads I think. I'd like to know if all stock components will bolt up to the new Vic Jr. heads, flow numbers and if special pistons would be required with the revised exhaust angle. I wonder if these are similar to the Indy HIPO heads that I've read require special pistons.
Re: Edelbrock Hemi heads [Re: blowndart] #1545312
04/08/14 04:29 PM
04/08/14 04:29 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
Millenniums don't help anybody. Who wants to have a sheet metal intake and custom headers fabricated? Nobody I know. I love Stage V but we need usable heads. The Edelbrocks (which are kinda like the Indy Hi-Po's except you don't have to deal with Indy) are supposed to be modeled after a good ported head. Good flow, accept all stock components, kinda like we should have had 40 years ago.
Re: Edelbrock Hemi heads [Re: rickseeman] #1545313
04/08/14 05:02 PM
04/08/14 05:02 PM
Trumbull,CT.
Trumbull,CT.
There is MORE than enough stock JUNK for MOPARS .....including HEMI heads.
What the HEMI world needs is a state of the art head that works on a 4.800, or 4.840 bore centers....for guys that are sick and tired of stock JUNK!!!!!
And as we all know (OR SHOULD).....the only people that want a sheet metal intake are the ones who actually want to go fast.
