Recomendations for VIN plate paint removal #1544637
12/07/13 12:47 PM
12/07/13 12:47 PM
Smack dab in the middle of Ill...
JamaicaBlue Offline OP
I am currently restoring my dash and I want freshen up the VIN plate on my Challenger.
What is the best method of removing the paint?
What paint do you recommend for the VIN plate?
Re: Recomendations for VIN plate paint removal [Re: JamaicaBlue] #1544638
12/07/13 06:50 PM
12/07/13 06:50 PM
Is the paint a semi-gloss or flat black?
Re: Recomendations for VIN plate paint removal [Re: JamaicaBlue] #1544639
12/07/13 06:54 PM
12/07/13 06:54 PM
Wisconsin
Stewpar Offline
Stewpar  Offline
Wisconsin
Semi-Gloss. Mautz makes a really nice semi-gloss black that is a perfect match.
Admiration For Multiple Carburetor Vehicles...
Re: Recomendations for VIN plate paint removal [Re: Stewpar] #1544640
12/08/13 11:55 AM
12/08/13 11:55 AM
mopar346 Offline
Let me tell ya about fat chicks!
mopar346  Offline
Cut the rivets off from the backside and push them through. Do not drill them, it will cause them to stin and damage/scar the plate. I blasted mine lightly and it came out great, I only blasted the front side the back was excellent.
Careful, your character's showing!
Re: Recomendations for VIN plate paint removal [Re: mopar346] #1544641
12/08/13 12:02 PM
12/08/13 12:02 PM
Thanks for the advice. What paint did you use and were you happy with the results?
I tried finding the paint recommended in the post above but I could not find any place local that sells it.
Re: Recomendations for VIN plate paint removal [Re: mopar346] #1544642
12/08/13 12:44 PM
12/08/13 12:44 PM
N.E.Ohio
P
pacifica Offline
pacifica  Offline
P
N.E.Ohio
I think cutting off rivets from a dash that you are restoring is opening the door for
All it takes is a little extra time and effort to carefully mask the tag for stripping or painting.
Re: Recomendations for VIN plate paint removal [Re: pacifica] #1544643
12/08/13 11:33 PM
12/08/13 11:33 PM
mopar346 Offline
mopar346  Offline
Never had any trouble cutting them off, just use a cut off wheel and becareful. Besides with a padded dash (Es, late Bs) you have to remove it to replace the pad.
Jamaica, I used Rustolium satin black and was pleased with the results. Painted it flat first but it was too flat so I went back with the satin.
