02 ram 4.7 still overheating #1544219
12/05/13 09:36 PM
12/05/13 09:36 PM
Abilene, Texas
fastmark Offline OP
fastmark  Offline OP
Abilene, Texas
My truck is still overheating. I've changed the radiator and it still pegged the gauge but did not boil out. I put the old thermostat in with out the guts and it is a little better. It is not pressuring up the rad or leaking out the exhaust like a cracked head and there is no water in the oil. Do you think the impeller on the water pump is spining?
Re: 02 ram 4.7 still overheating [Re: fastmark] #1544220
12/06/13 09:21 AM
12/06/13 09:21 AM
Guitar Jones Offline
I hear that brought up a lot but in my 37 years of experience as a tech I've never seen it. Doesn't mean it can't happen, just that odds are against it. I have seen the impeller eaten away from corrosion or cavitation, but that's pretty rare too. I would pull it and look at it as well as the timing cover.
Are you sure the fan clutch is working? Does it overheat at idle/low speeds or highway speeds?
Re: 02 ram 4.7 still overheating [Re: Guitar Jones] #1544221
12/06/13 12:30 PM
12/06/13 12:30 PM
Abilene, Texas
fastmark Offline OP
fastmark  Offline OP
Abilene, Texas
Well. I agree that it is very unlikely, but this truck belongs to my daughters boyfriend and that is what is dad is thinking. I'm doing this for free and money is a real big issue. The rad was full of red crap that I assume was rust. 187 miles on the same coolant is not good. In test driving to check the heating, I found a pinion bearing out so I had to rebuild the rear before we could fix the overheating problem.
The fan is stiff when it is cold and I have not checked after it warms up, but it seems fine. It overheats driving down the road at 30 to 50. It was 23 degrees last night driving at 40mph on an ice slick road and still was overheating. At least with the thermostat out it does not lose any coolant.
Re: 02 ram 4.7 still overheating [Re: fastmark] #1544222
12/06/13 12:39 PM
12/06/13 12:39 PM
I have to ask, did you put a new radiator in or a used one? If it had that much rust in it then the impeller could be a problem as well as build up in the block.
Re: 02 ram 4.7 still overheating [Re: Guitar Jones] #1544223
12/06/13 02:01 PM
12/06/13 02:01 PM
Abilene, Texas
fastmark Offline OP
fastmark  Offline OP
Abilene, Texas
Its a new rad and I flushed out the block with a hose as best I could. I fear the block has some stoppage as well. One thing is that the heater does not work well at all. With the thermostat in, it works a little. With the gutted one, it does not work at all. I think I will try and figure out which lines go to the heater and flush those if I change the pump. Thanks for you help.
Re: 02 ram 4.7 still overheating [Re: fastmark] #1544224
12/06/13 02:37 PM
12/06/13 02:37 PM
Yeah the heater core is probably plugged up as well or there just isn't enough circulation.
Re: 02 ram 4.7 still overheating [Re: Guitar Jones] #1544225
12/06/13 03:36 PM
12/06/13 03:36 PM
Abilene, Texas
fastmark Offline OP
fastmark  Offline OP
Abilene, Texas
I'll let you know what is was. Thanks for the help.
Re: 02 ram 4.7 still overheating [Re: fastmark] #1544226
12/06/13 03:38 PM
12/06/13 03:38 PM
You're welcome. Good luck.
Re: 02 ram 4.7 still overheating [Re: Guitar Jones] #1544227
12/06/13 07:07 PM
12/06/13 07:07 PM
Abilene, Texas
fastmark Offline OP
fastmark  Offline OP
Abilene, Texas
Well just got back from a from a little diagnostics from my friends at a tranny/engine rebuild business and they run the codes (the check engine light has been on for some time, I am told). Fuse to the a/c fan was out and cly #4 and 8 have a misfire. I could tell it had one cly not hitting when I started this ordeal. This truck is a prefect example of neglected maintenance. He put a sniffer in the radiator tank and it turned the blue fluid into a greenish yellow. He said that meant it had some hydro-carbons in the coolant. I never knew they had a test like that. It went to about 236( we had the scanner plugged in) just driving around the block in 20 degree weather. I bet if I pulled the plugs in 4 and 8, I would find signs of coolant in the chamber.
Re: 02 ram 4.7 still overheating [Re: fastmark] #1544228
12/06/13 10:13 PM
12/06/13 10:13 PM
WV
Danny Offline
Danny  Offline
WV
we have a 2001 durango 4.7 and yes it did spin the impeller! It was overheating and I was very doubting it was the water pump. Finally took it apart and sure enough the impeller was PLASTIC and cracked! Dan
Re: 02 ram 4.7 still overheating [Re: Danny] #1544229
12/07/13 02:24 AM
12/07/13 02:24 AM
NB, Canada
Mirada 80 Offline
Mirada 80  Offline
NB, Canada
I have a 2003 Durango 4.7, same problem, the center of the impeller broke, water pump was only a year old. I'll post pictures tomorrow.
Keep your Mopar all Mopar
Re: 02 ram 4.7 still overheating [Re: fastmark] #1544230
12/07/13 10:36 AM
12/07/13 10:36 AM
If that's the case the engine is probably sludged as well from lack of maintenance. Going to get expensive from here.
Re: 02 ram 4.7 still overheating [Re: Guitar Jones] #1544231
12/07/13 07:35 PM
12/07/13 07:35 PM
Abilene, Texas
fastmark Offline OP
fastmark  Offline OP
Abilene, Texas
Well, just got back from the shop and here is what we found. The @#$#$^% PLASTIC impeller was spinning on the shaft. I can't believe mopar would engineer something like this. I decided to change the plugs while we were at it and it did not appear to have any coolant on the plugs. I don't think he got it hot enough to crack the heads. It ran much better after we changed the plugs and the heater works great. We have good flow into the reservoir. I think the pump was working just enough to move a little coolant. Thanks for all you guys help. This place is a wealth of info. Now for a bowl of hot chili!
Re: 02 ram 4.7 still overheating [Re: fastmark] #1544232
12/08/13 12:24 AM
12/08/13 12:24 AM
NB, Canada
Mirada 80 Offline
Mirada 80  Offline
NB, Canada
Glad you found it without any more damage, I was lucky with mine too, mine blew out in August, I was climbing a long steep hill, rpms jumped from 1500 to 3400 as it down shifted, temperature gauge was nearly pinned as I crested the hill. Plastic parts should not be in there, I don't know what they were thinking, that pump was only a year old, replaced it with a lifetime over the counter warrantee one, but that doesn't help with labour.
Re: 02 ram 4.7 still overheating [Re: Mirada 80] #1544233
12/08/13 11:09 AM
12/08/13 11:09 AM
Abilene, Texas
fastmark Offline OP
fastmark  Offline OP
Abilene, Texas
Well, if this would been in August in Texas,it would have never lived long enough to have a happy ending. He had to drive it about 125 miles but it was very cold outside and when test drove it after the rear end repair, it was in the low 20's. It still got hot.
Re: 02 ram 4.7 still overheating [Re: Guitar Jones] #1544234
12/08/13 11:58 AM
12/08/13 11:58 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
If you think thats bad wait till you see a steel impeller thats not there.We had a few GMs at the shop that drove us nuts.Did all kinds of diag on them.I finally decided to check the pump.Thought it might be spinning.Took it out and it was pretty much a piece of round metal.No impellers left.Rocky
Chrysler Firepower
Re: 02 ram 4.7 still overheating [Re: therocks] #1544235
12/08/13 12:07 PM
12/08/13 12:07 PM
Abilene, Texas
fastmark Offline OP
fastmark  Offline OP
Abilene, Texas
That was my first thought because it had so much rusty sludge in the rad when we changed it and the thermostat.
Re: 02 ram 4.7 still overheating [Re: fastmark] #1544236
12/09/13 10:34 AM
12/09/13 10:34 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
but getting back to the block test that was performed..... the damage has been done. It's time to pull the heads.
