Re: 02 ram 4.7 still overheating
[Re: fastmark]
#1544220
12/06/13 09:21 AM
12/06/13 09:21 AM
Posts: 20,657 in a cattle trailer down by th...
Guitar Jones
I hear that brought up a lot but in my 37 years of experience as a tech I've never seen it. Doesn't mean it can't happen, just that odds are against it. I have seen the impeller eaten away from corrosion or cavitation, but that's pretty rare too. I would pull it and look at it as well as the timing cover.
Are you sure the fan clutch is working? Does it overheat at idle/low speeds or highway speeds?
[Re: fastmark]
#1544222
12/06/13 12:39 PM
12/06/13 12:39 PM
Guitar Jones
I have to ask, did you put a new radiator in or a used one? If it had that much rust in it then the impeller could be a problem as well as build up in the block.
[Re: fastmark]
#1544224
12/06/13 02:37 PM
12/06/13 02:37 PM
Guitar Jones
Yeah the heater core is probably plugged up as well or there just isn't enough circulation.
[Re: fastmark]
#1544226
12/06/13 03:38 PM
12/06/13 03:38 PM
Guitar Jones
You're welcome. Good luck.
[Re: Danny]
#1544229
12/07/13 02:24 AM
12/07/13 02:24 AM
Posts: 13 NB, Canada
Mirada 80
NB, Canada
I have a 2003 Durango 4.7, same problem, the center of the impeller broke, water pump was only a year old. I'll post pictures tomorrow.
Keep your Mopar all Mopar
[Re: fastmark]
#1544230
12/07/13 10:36 AM
12/07/13 10:36 AM
Guitar Jones
Well just got back from a from a little diagnostics from my friends at a tranny/engine rebuild business and they run the codes (the check engine light has been on for some time, I am told). Fuse to the a/c fan was out and cly #4 and 8 have a misfire. I could tell it had one cly not hitting when I started this ordeal. This truck is a prefect example of neglected maintenance. He put a sniffer in the radiator tank and it turned the blue fluid into a greenish yellow. He said that meant it had some hydro-carbons in the coolant. I never knew they had a test like that. It went to about 236( we had the scanner plugged in) just driving around the block in 20 degree weather. I bet if I pulled the plugs in 4 and 8, I would find signs of coolant in the chamber.
If that's the case the engine is probably sludged as well from lack of maintenance. Going to get expensive from here.
[Re: fastmark]
#1544232
12/08/13 12:24 AM
12/08/13 12:24 AM
Mirada 80
NB, Canada
Glad you found it without any more damage, I was lucky with mine too, mine blew out in August, I was climbing a long steep hill, rpms jumped from 1500 to 3400 as it down shifted, temperature gauge was nearly pinned as I crested the hill. Plastic parts should not be in there, I don't know what they were thinking, that pump was only a year old, replaced it with a lifetime over the counter warrantee one, but that doesn't help with labour.
[Re: Guitar Jones]
#1544234
12/08/13 11:58 AM
12/08/13 11:58 AM
Posts: 21,083 Niles , Ohio
therocks
Niles , Ohio
If you think thats bad wait till you see a steel impeller thats not there.We had a few GMs at the shop that drove us nuts.Did all kinds of diag on them.I finally decided to check the pump.Thought it might be spinning.Took it out and it was pretty much a piece of round metal.No impellers left.Rocky
Chrysler Firepower
