Re: Troubleshooting temp issue
[Re: cal_gecko]
#1544143
12/05/13 09:23 PM
12/05/13 09:23 PM
RapidRobert
I'm assuming the timing is in the ballpark & the mixture is also (no vac leak). Is that stoplight to stoplight driving? If you take it out on the highway what does the temp do? I'd maybe shoot it with an IR gun to confirm what the temp actually is & my first step would be to toss the stat for a day which wont hurt things. What's the history of the radiator? You mentioned the cap, is it loosing coolant?
[Re: RapidRobert]
#1544144
12/05/13 10:21 PM
12/05/13 10:21 PM
Posts: 5,791 Hamilton, Ontario Canada
Magnum
If you just want to make some random guess. I'd start with the radiator. They age and clog up with build up.
Not often is there problems with the block.
Does it get hot while idling or how about coasting down a hill in neutral, will it pull the temp down?
[Re: cal_gecko]
#1544145
12/05/13 10:35 PM
12/05/13 10:35 PM
Challenger 1
Cincinnati, Ohio
mild 360 in my '71 Dart with a 26" radiator (with shroud and flex fan) is running hot... takes about 20 minutes of driving but it gets up to about 235 degrees (even when it's 35 degrees out).. I tried a new radiator cap - same problem...
What's the most effective way for me to troubleshoot to determine whether there's a blockage in the radiator or in the block - or if there's something else going on?
If it's the radiator, I'm just gonna buy one of the Champion aluminum units sold here by a member for less than $200 delivered.. I just want to make sure that's the issue before I drop another $200
Please don't buy a new radiator yet.
First get rid of the flex fan, it won't work and it won't last. IMO Run a real mopar fan, I use the "216" fan, but there is another MP fan sold that works way better than any flex fan.
Please start there.
[Re: Challenger 1]
#1544146
12/05/13 10:45 PM
12/05/13 10:45 PM
Posts: 5,163 CT
GTX MATT
CT
Check the initial and total timing and repor back! Is the vacu advance connected?
[Re: RJS]
#1544149
12/06/13 02:42 AM
12/06/13 02:42 AM
Posts: 12,589 Sacramento, CA
cal_gecko
Sacramento, CA
When your car gets to 235 does it boil over? Buy the cap that was suggested to you about two weeks ago that tells you the temp. right on it to determine if it's a gauge issue. Or at the very least when it's 235 can you with it running slowly open the cap to see what's going on in there and/or use a meat type thermometer. Ron
I had that cap on it tonight... it also showed 230
[Re: cal_gecko]
#1544155
12/06/13 07:26 PM
12/06/13 07:26 PM
Posts: 768 Maryville tn
67coronetman
Maryville tn
I would use a clutch fan just saying it helped me i had a flex fan & it never did the job..
Old car are me......
[Re: 67coronetman]
#1544156
12/06/13 07:32 PM
12/06/13 07:32 PM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
Check the thermostate.. Ive seen new 1s that were bad.. Yours may not be opening up all the way..
I am truckless..
[Re: 340SHORTY]
#1544157
12/06/13 07:34 PM
12/06/13 07:34 PM
67coronetman
Maryville tn
Yes good point i agree.. good to check that too. Quote:
