Sreet/strip guys...mechanical fuel pump?? #1543413
12/03/13 11:30 PM
12/03/13 11:30 PM
Between a rock & a hard place
cudadoug Offline OP
cudadoug  Offline OP
Which one?
How much power/how fast have you gone on it??
Thanks!
Re: Sreet/strip guys...mechanical fuel pump?? [Re: cudadoug] #1543414
12/03/13 11:55 PM
12/03/13 11:55 PM
North, Alabama
D-50 Offline
D-50  Offline
North, Alabama
I am running a Carter mech. strip pump on my pump gas small block, 3/8 line and autozone fuel filter.I drove 40 miles round trip to the last race and ran my new best of 6.29,1.33 60ft.@ 108 in the 1/8 so far. I hope to have the fuel system upgraded by spring so I can put my 1050 carb. on it.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
Re: Sreet/strip guys...mechanical fuel pump?? [Re: D-50] #1543415
12/04/13 02:42 AM
12/04/13 02:42 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I just use the Holley black pump and the stock tank. I put a 3/8 sending unit in my stock tank and run 3/8 line in the stock location. Pump and filter mounts back by the tank. And I use a pump block off plate where the mech pump was. Works fine for 10.70's and still pulling good thru the traps. Ron
Re: Sreet/strip guys...mechanical fuel pump?? [Re: D-50] #1543416
12/04/13 02:44 AM
12/04/13 02:44 AM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
I also run the carter strip pump, with the stock 5/16 line from the tank. My fuel pressure guage isn't visible from the interior, so I don't know exactly where I'm at, so I guess I'm no help. I haven't experienced anything that suggests I'm running lean up top, but I plan on moving my pressure guage to the cowl this winter so I can keep an eye on it.
Re: Sreet/strip guys...mechanical fuel pump?? [Re: StealthWedge67] #1543417
12/04/13 05:26 AM
12/04/13 05:26 AM
Hamburg / Germany
Den300 Offline
Den300  Offline
Hamburg / Germany
Rick Eherenberg sells one for a very good price at the bay. 3/8" all the way.
built in pressure regulator. he claims it is good for 700hp. ordered one
but it is not delivered and installed right now.
Hamburg/Germany
69 Chrysler 300
446cui Dual Quad
12.64 @ 110.7
Re: Sreet/strip guys...mechanical fuel pump?? [Re: Den300] #1543418
12/04/13 06:04 AM
12/04/13 06:04 AM
sweden
sshemi Offline
sshemi  Offline
sweden
I have used the racepumps pump for a 650hp sb without problems.
Said to be good to 2000hp!
Only problem was when ran out of fuel. Hard to get it pumping again had to prime it.
Re: Sreet/strip guys...mechanical fuel pump?? [Re: cudadoug] #1543419
12/04/13 09:13 AM
12/04/13 09:13 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
what is the application? Carter and Holley make good street pumps, I ran an Autozone replacement on my old 440-6 (11:1 528 solid cam, 1.5 rollers, headers, 3800 stall, 3.91's). Worked just fine. It all depends on how much gas you need.
Coming soon!!!!
Re: Sreet/strip guys...mechanical fuel pump?? [Re: Mr.Yuck] #1543420
12/04/13 11:31 AM
12/04/13 11:31 AM
Like the title says...."street/strip"
Re: Sreet/strip guys...mechanical fuel pump?? [Re: cudadoug] #1543421
12/04/13 11:35 AM
12/04/13 11:35 AM
Cincinnati, Ohio
d7cook Offline
d7cook  Offline
Cincinnati, Ohio
I've ran a Carter strip pump into the 10's with a tunnel ram in the past. Right now I'm using a Clay Smith pump and love it. It needs a regulator, it needs to be clearanced at the block but it pumps a lot of gas.
1967 Coronet, 1989 Daytona tube chassis. Former cars, 66 Charger, 67 R/T, 69 Coronet, 67 Dart GT. -Banned for life from V8Buick.com-
Re: Sreet/strip guys...mechanical fuel pump?? [Re: d7cook] #1543422
12/04/13 01:20 PM
12/04/13 01:20 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
Interested in this one as well, thinking about an upgrade to my Carter pump since my MPH and pressure is falling off on the big end.
I was actually going to experiment with a small electric booster pump in parallel with the mechanical (since i have a second/unused supply line from the tank all the way to the motor) just to see if it helped before re-thinking the whole system.
WIZE
In Car:
Re: Sreet/strip guys...mechanical fuel pump?? [Re: Streetwize] #1543423
12/04/13 01:45 PM
12/04/13 01:45 PM
Joplin, Mo
rt66jim Offline
rt66jim  Offline
Joplin, Mo
Re: Sreet/strip guys...mechanical fuel pump?? [Re: ] #1543424
12/04/13 01:52 PM
12/04/13 01:52 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
yeah like I said and? I've seen guys w/ 12.20 "strip cars" and 10 second "street" cars. In any even the carter and holley pumps will get a BB car well into the 11's w/o an issue, even w/ tiny 5/16 line.
Re: Sreet/strip guys...mechanical fuel pump?? [Re: StealthWedge67] #1543425
12/04/13 01:53 PM
12/04/13 01:53 PM
organ
maximum entropy Offline
organ
carter strip pump with regulator, 10.60. still shows 6psi at the stripe. it gets driven a couple thousand miles a year, is about 15 years old, and has been stone wall reliable (as opposed to numerous failed attempts at electric pumps).
Re: Sreet/strip guys...mechanical fuel pump?? [Re: maximum entropy] #1543426
12/04/13 02:07 PM
12/04/13 02:07 PM
Sweden
Mopar Guy Offline
Mopar Guy  Offline
Sweden
CV makes a billet pump for Nascar that fits bb that i found and i gues that that would be one of the nasty once that will need a regulator but i havent tryed mine yet !
Re: Sreet/strip guys...mechanical fuel pump?? [Re: Mopar Guy] #1543427
12/04/13 04:22 PM
12/04/13 04:22 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Evan back in the early days we ran Carter mech. pump with electric in the back. Someone want to race just flip the switch, didn't have to put up with noise all the time.
Re: Sreet/strip guys...mechanical fuel pump?? [Re: cudaman1969] #1543428
12/04/13 04:35 PM
12/04/13 04:35 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
Has anybody ever run a small parallel electric pump (like the Mr. Gasket 12S ~ 35gph) as a booster? They also help a ton with hot starts to refill the bowls on a mechanical. It was a fairly common hop-up for running 50-100 shots in the early nitrous days when things weren't all high-dollar sophisticated like today. I used to have one of those old "Chinka-Chinka" Dupree's that I used to cut on with my N20 "armed" switch
You can also use it as a 'jockey' (for you firemen and fire protection guys out there) pump with a return loop. I used to put it on a 3 position switch (off/jog( i.e. momentary)/run).
BTW, they also make for a nice inexpensive "limp-in" system if you ever lose your high dollar pump on the street or at the track
@cudaman1969....that's one of the (sometimes forgotten) practical advantages of a rotary vane pump (as opposed to the more modern georotor)....you can series it upstream of your mechanical and still pull the gas through it without the electric pump running.
WIZE
In Car:
Re: Sreet/strip guys...mechanical fuel pump?? [Re: Streetwize] #1543429
12/04/13 06:36 PM
12/04/13 06:36 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Wise I ran the Carter plus a cheap Summit electric in my old boosted 440. I turned the Electric on at the track or when I went WOT on the street. Don't ask what happens when you forget to turn it on.
Re: Sreet/strip guys...mechanical fuel pump?? [Re: Mr.Yuck] #1543430
12/04/13 07:27 PM
12/04/13 07:27 PM
El Dorado Ca
65signet Offline
65signet  Offline
El Dorado Ca
Carter Pump -6 line 11.20s 360 with an 850 carb
1965 Plymouth Barracuda 273 M/SA
1970 Plymouth Duster 360/904 10.60s with J heads
Re: Sreet/strip guys...mechanical fuel pump?? [Re: 65signet] #1543431
12/04/13 09:36 PM
12/04/13 09:36 PM
cudadoug Offline OP
cudadoug  Offline OP
Application is a warmed up 408 or 360 (haven't 100% decided yet) in a STREET/strip 69 Dart. Goal: No quicker than 11.50's in 100% street trim as it doesn't have (nor will get) a roll bar.
I have a new Holley black pump and the AN hose and fittings in stock, but not sure I want to mess with all of that. AND it would add to the "sleeper-ness" if it was a mech pump and OEM 3/8 lines.
Re: Sreet/strip guys...mechanical fuel pump?? [Re: cudadoug] #1543432
12/05/13 09:16 AM
12/05/13 09:16 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
you could probably get away with either the carter or holley mech pump and your stock 5/16 line, however it won't hurt to upgrade to 3/8, just remember to get a 3/8 pick-up as well.
